Mini-CNC
Results 1 to 8 of 8
Thread: Mini-CNC
    Default Re: Mini-CNC
    Drilling an oval hole has never been easier.
    I think this was a 1mm mill bit. I mill only 0.1mm deep at a time to save the bit.
    As I do not have a CNC machine, nor I like chemicals anymore, I prefer JLC for my pcbs, mainly because they offer DDP or Europacket shipping. This helps pass customs wiht no worries.
    I just received my 5 test boards and found a tragic and embarrasing mistake in the power supply connection of the 12F675 chip. Reversed them. Cannot believe that stupid mistake I did...
    Rule number 1: Never work late at night!
    Rule number 2: Double check next day of the design, before sending to production!
    Other than the terrible mistake, they look great. Better than the image here.
    - Did you have a lot made?
    - Is cutting the trace and adding a jumper an option?
    - are these for resale or personal use?
    Name:  Jumper wires.jpg
    This board was to test custom drill footprints, different solder temps, and various solder paste and flux products.
    I only share here a fragment of the boo-boos I've made. I don't mind serving as an example of "don't do this".
    Yes, I' ll do that. Cut two traces and wire jump one, short the other.
    Fortunatelly, only 5 pcs were made as they are the prototypes. Corrected for the production now.
    But I wonder how such a stupid mistake was done... I have an explanation. It was very late when finished and sent over to production.
    Drilling and milling PCBs is awesome. It takes a bit of time to draw the test circuit on Kicad, import into FlatCam and generate g-code, import separate files into Candle, change the bits, align the Z axis.
    But this is waaaay more precise than a hand-held dremel, or even mounted on a vertical press. The only thing with the dremel is that it's much quicker setup, and you can tape a sheet of paper over the PCB with all the holes.
    It's a great way to test custom footprints before sending them out. Some specs ask for a huge hole. My components will be hand installed; I don't need such a huge margin.
    Name:  Drilling-milling mini-CNC a.jpg
    Name:  Drilling-milling mini-CNC b.jpg
    I didn't even bother passing a steel wool to remove the burrs on the holes.
    Oh man! That's awesome!!!
  1. Mini problem with DT_INTS-14
    By towlerg in forum mel PIC BASIC Pro
    Last Post: - 19th December 2013, 16:39
  2. VM142 velleman mini PLC
    By MikkelH in forum mel PIC BASIC Pro
    Last Post: - 13th October 2009, 17:01
  3. U2 Programmer Interface for Ethernet MINI
    By edtp in forum mel PIC BASIC Pro
    Last Post: - 21st July 2007, 23:29
  4. mini speaker
    By Ron Marcus in forum Off Topic
    Last Post: - 5th March 2007, 00:43
