Mini-CNC
Results 1 to 8 of 8
Thread: Mini-CNC
    Default Mini-CNC
    I bought a Vevor mini-CNC last year . Had a few boo-boos, but Vevor made it right at no cost to me.
    https://www.vevor.ca/wood-engraving-...p_010386974707
    I never thought I could make a PCB with 0.5mm traces using el-cheapo bits on a $200CAD machine.
    (this is the bottom side, double-sided circuit is flipped vertically)
    I made 2 mistakes; error in the footprint for a slide potentiometer, and forgot a command for 2 oval holes when I editted the files from FlatCAM (I have to separate the drill and mill sizes - I don't have an automated tool changer).
    But still, I'm impressed that we can now make at home such a delicate trace.
    Default Re: Mini-CNC
    Mapping the height of the PCB surface.
    Drilling an oval hole has never been easier.
    I think this was a 1mm mill bit. I mill only 0.1mm deep at a time to save the bit.
    As I do not have a CNC machine, nor I like chemicals anymore, I prefer JLC for my pcbs, mainly because they offer DDP or Europacket shipping. This helps pass customs wiht no worries.
    I just received my 5 test boards and found a tragic and embarrasing mistake in the power supply connection of the 12F675 chip. Reversed them. Cannot believe that stupid mistake I did...
    Rule number 1: Never work late at night!
    Rule number 2: Double check next day of the design, before sending to production!
    Other than the terrible mistake, they look great. Better than the image here.
    - Did you have a lot made?
    - Is cutting the trace and adding a jumper an option?
    - are these for resale or personal use?
    Name:  Jumper wires.jpg
    This board was to test custom drill footprints, different solder temps, and various solder paste and flux products.
    I only share here a fragment of the boo-boos I've made. I don't mind serving as an example of "don't do this".
    Yes, I' ll do that. Cut two traces and wire jump one, short the other.
    Fortunatelly, only 5 pcs were made as they are the prototypes. Corrected for the production now.
    But I wonder how such a stupid mistake was done... I have an explanation. It was very late when finished and sent over to production.
  1. Mini problem with DT_INTS-14
    By towlerg in forum mel PIC BASIC Pro
    Last Post: - 19th December 2013, 15:39
  2. VM142 velleman mini PLC
    By MikkelH in forum mel PIC BASIC Pro
    Last Post: - 13th October 2009, 16:01
  3. U2 Programmer Interface for Ethernet MINI
    By edtp in forum mel PIC BASIC Pro
    Last Post: - 21st July 2007, 22:29
  4. mini speaker
    By Ron Marcus in forum Off Topic
    Last Post: - 4th March 2007, 23:43
