B3F-4055 switch bounce
Results 1 to 20 of 20
    Default B3F-4055 switch bounce
    Received my $2 scope and tested one of my switches.
    Does this result seem possible?
    I expected some flutter, but this switch has no bounce. Either the switch performs much better than I anticipated, or this scope device is garbage.
    Default Re: B3F-4055 switch bounce
    I suppose you have only a switch and a resistor, right?
    Either you got a perfect switch or the scope is slow enough with low memory depth.
    I will do a similar test. Maybe you have to use 5ms/div or lower?
    i would not expect to see any "bouncing" at 50mS per div , @ 0.5mS/div you are more likely to see something
    I went back and redid the tests. Here's the falling edge of a SR-25 rotary switch on a BK Precision 1560 at 1ms:
    (Let me know if there's a better setting for the scope. I just went with trial and error.)
    And the rising and falling edges on the DSO-TC3 at 1ms:
    It's not even remotely close to similar. I should have started testing with the BK; its buttons aren't making the screen jump around.
    The Tektronix 466 was giving mismatched readings; giving a jagged trace, then curves, then just dropping on/off. It would need a serious cleaning, which I can't afford. And that wouldn't repair worn switches and pots, they'd need to be replaced. Let alone if there's fried circuits in there. I figure the old owner got rid of it for a reason.
    Here's a pic of the SR25 switch. That wiper seems to bounce a lot as it moves out of one position and into another.
    Well we expected the BK screenshot response. That is what a good switch bounce should be!
    The Fnirsi I guess is either for the recycle bin or has some settings to smooth out the ripple so much that looks like a perfect rect wave.
    The SR25 switch, depending on their oxidation state, since the contacts are very much exposed, is normal to have such a behaviour.
    ...The Fnirsi I guess is either for the recycle bin or has some settings to smooth out the ripple so much that looks like a perfect rect wave....
    It's a toy to help teach electronics, nothing more. I'm starting my first return to AliExpress, along with those 3 DMMs that I tried out. I'll see how that goes.
    EDIT: I was wrong about this device (next post).
    ...The SR25 switch, depending on their oxidation state, since the contacts are very much exposed, is normal to have such a behaviour.
    This one is brand new though; straight from the manufacturer 2 months ago.
    Turns out this was caused by me touching the metal shaft. As soon as I installed a knob, that erratic bounce has mostly gone away. There's still a slight bounce, but nothing so drastic.
    It did show to me though that the chinesium scope is useless to analyse signals adequately.
    Only the switch, says Omron underneath. Zero resistors or capacitors.
    I wanted to do a baseline so I had something to compare any debounce circuitry.
    I'm gonna test some other switch types and omron clones.
    I suppose you have to add the whole circuit. Omron is a good company but in any case, mechanical switch always have a small time of bouncing.
  1. Toggle switch (latching switch) state
    By craigwb in forum General
    Last Post: - 6th November 2011, 15:18
  2. Switch sensor vs. switch PIC pin
    By fratello in forum Schematics
    Last Post: - 4th August 2011, 12:17
  3. switch ?
    By barneyfrance in forum mel PIC BASIC Pro
    Last Post: - 12th July 2011, 16:47
  4. Replies: 6
    Last Post: - 9th January 2011, 16:26
  5. Switch PIC16F877 ON/OFF
    Last Post: - 27th August 2005, 13:34
