Filtering noise from a wire
Results 1 to 31 of 31
Threaded View
  1. #24
    Default Re: Filtering noise from a wire
    what problem is the active pullup bus chip going to solve ? ...
    I was hoping:
    - it would allow me to use the MCP23017 at 400MHz,
    - it would be enough to read rotary encoders with an MCP23017,
    - it would work using I2CREAD command.
    But that's too many IFs. The chip is not available in DIP package for me to test.
    I've since decided to go with a dedicated 16F1937 TQFP-44 at 32MHz with 36 IOC pins to manage my encoders. I have room for 14 encoders on this secondary PIC (primary is a USB PIC), and the jumper at bottom right will permit me to use a 2nd circuit if needed in the future.
    I only need 13 for this first project. I could use the 2 pins for encoder #14 to create a 3 bit jumper, giving me addressing for 8 circuits (total of 103 encoders). I'll most likely make the change now that I've thought about it.
    Name:  PCB Encoders.png
    EDIT: I didn't forgetting mounting holes. The PCB will be mounted vertically along the perimeter of the enclosure with the pins pointed inwards. The high-mounted header pins will be easy to access. and a single line of hot-glue will secure the connectors.
  1. Noise on input signal
    By fanman in forum mel PIC BASIC Pro
    Last Post: - 28th February 2012, 02:55
  2. Notch filtering
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2010, 16:45
  3. Noise on OSC pins.
    By Tobias in forum General
    Last Post: - 31st December 2009, 01:29
  4. Input Noise
    By PJALM in forum mel PIC BASIC Pro
    Last Post: - 28th February 2006, 19:26
  5. Loop noise
    By Jųan in forum mel PIC BASIC Pro
    Last Post: - 20th October 2005, 12:19
Members who have read this thread : 8
