PIC16F886 Pulldown inputs
Results 1 to 8 of 8
    Default Re: PIC16F886 Pulldown inputs
    Maybe I was not very clear.
    With your original design, you would change the 2K to 100 ohms.
    But with the new design, the pullup will be around 10K. NOT 100 ohms. I am pretty sure you will destroy the optos.
    Apr 2016
    Plainfield, Illinois
    - So just to be clear - I'm driving the optos using the 2k to the anode, the output is the "collector" tied hi to a resistor - to the PIC w 5V. I'm not sure 100 ohms to the PIC would damage the PIC, but I dont think the opto would care?
    In any case - I'll use 10K like you suggest.. no real reason to use 100.
    My dad never liked you...
    With 100 ohms from +5 to the collector of opto, you will force 50mA through opto. This is the absolute max according to the data sheet. It will lead sooner or later to the destruction of the opto.
    Please do use 10K from +5 to the collector of the opto and drive from the collector the PIC port. The emitter of the opto will be earthed.
    Everytime you feed current to the LED of the opto, the PIC port will be low and when the LED is off, port will be high.
  1. PIC16F886 not running.
    By Lilleljung in forum PBP3
    Last Post: - 6th January 2015, 21:35
  2. pic16f886
    By NURULHAIZA in forum General
    Last Post: - 21st May 2010, 08:09
  3. neebee wants to know pullup or pulldown?
    By lecoind in forum mel PIC BASIC Pro
    Last Post: - 24th May 2009, 03:36
  4. pullup and pulldown resistor help
    By studysession in forum General
    Last Post: - 29th January 2009, 02:46
  5. Pic16f886
    By Larry in forum mel PIC BASIC Pro
    Last Post: - 10th October 2008, 22:40
