WiFi to setup a PIC based device
Results 1 to 7 of 7
    Default Re: WiFi to setup a PIC based device
    about 6 months or a year ago I mentioned an 8266 UART-WIFI bridge. After programming a few files into it, after that it just starts up able to send and receiving at set baud over your wifi settings. You can use some terminal program to send and receive although I made a visual studio program to do that to/from an f2525 at 115K baud. The few 8266's I programmed have been working constantly for several years. All the work is then done directly with serial. I set up the f2525's with timer and UART interrupts. The timer int loops the program 10X a second and when a character comes in, it is checked in small asm at int. It checks for a start '[' and end ']' characters and raises flags to start taking characters and then process the received string...... so it is basically real time receive thing. The files programmed in the 8266 have a web page for setting and other more advanced things I never used. The modules were $5 amazon.
    Thank for the great info. Time for a crash test...
  1. Serial to WiFi <> Wifi to virtual com port
    By flotulopex in forum WiFi
    Last Post: - 4th April 2018, 13:18
  2. Replies: 22
    Last Post: - 5th January 2012, 06:49
  3. Wifi & PIC
    Last Post: - 26th December 2010, 03:16
  4. Sms based device switching
    By Farhan in forum GSM
    Last Post: - 28th November 2008, 18:14
  5. Interrupt & device setup for a PIC16F628A in Microcode Studio Plus
    By wildpikachu in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2008, 16:28
