SSD1306 OLED (72x40) I2C display from scratch
+ Reply to Thread
Results 1 to 40 of 74
    SWITZERLAND (french speaking)
    Default Re: SSD1306 OLED (42x40) I2C display from scratch
    Thank you so much Richard!!!
    I'll give it a try to create a super big font.
    Let you know for any progress in the next days
    Roger
    Default Re: SSD1306 OLED (72x40) I2C display from scratch
    First look at what it could look like
    Roger
    It looks great!
    Well done Roger!
    ...credits are all for Richard
    Roger
    something to consider about fonts
    it looks like you want 40x22 size font
    a pic16 has a flash word size of 14 bits therefore a font that size
    will take if encoded horizontally by row take 2x40 words per chr
    it will take 3x22 words if encoded vertically by column a reasonable saving.
    one of the benefits of the ssd1306 controller is that it can address its graphics ram either way with ease
    Default SSD1306 OLED (72x40) I2C display from scratch
    Richard,
    I'm still trying to understand your previous post but just for now, there's a question burning my mind: how do I address the display pixel by pixel?
    Roger
    you cannot, the smallest element is 1 byte ie one column[page] of 8 rows
    Default SSD1306 OLED starts up 10 times out of 11 or so
    For any reason, my OLED module won't start up once out of ten or twenty times.
    I have no clue why.
    I change OLED modules (I have five and do all the same), changes breadboards, changed µC... I don't know what to try next.
    Any idea?
    ' OLED-72x40_16F18446
    ' External oscillator
        __config _CONFIG1, _FCMEN_OFF & _CSWEN_OFF & _CLKOUTEN_OFF & _RSTOSC_EXT1X & _FEXTOSC_HS
        __config _CONFIG2, _MCLRE_OFF & _PWRTS_PWRT_64 & _LPBOREN_OFF & _BOREN_OFF & _BORV_LO & _ZCD_OFF & _PPS1WAY_OFF
        __config _CONFIG3, _WDTCPS_WDTCPS_31 & _WDTE_SWDTEN & _WDTCWS_WDTCWS_7 & _WDTCCS_LFINTOSC
        __config _CONFIG4, _BBSIZE_BB512 & _BBEN_OFF & _SAFEN_OFF & _WRTAPP_OFF & _WRTB_OFF & _WRTC_OFF & _WRTD_OFF & _WRTSAF_OFF & _LVP_OFF
        __config _CONFIG5, _CP_OFF
    @ ERRORLEVEL -306
    @ ERRORLEVEL -202
    ANSELB  = %00000000
    DEFINE OSC 32
    DEFINE NO_CLRWDT 1   ' don't waste cycles clearing WDT
    DEFINE HSER_CLOERR 1 ' automatic clear overrun error
    DEFINE I2C_SLOW 1    ' if >8MHz
    ' ====== VARIABLES =================================================================================
    SDA         VAR PORTB.5 ' I2C Clock
    SCL         VAR PORTB.6 ' I2C Data
    ' SSD1306 OLED 72x40 module (has built-in 10k pull-up on SDA/SCL)
    I2CDevice   CON $78
    Page        VAR BYTE ' OLED's Pages 0..4
    ' ====== SSD1306 I2C OLED initialization ===========================================================
    PAUSE 500 ' let display settle
    ' Initializing command set
    I2CWrite SDA,SCL,I2CDevice,[$00,$AE,$D5,$80,$A8,$3F,$D3,$00,$20,$00,$AD,$30,$8D,$14,$68,$A6,$A4,_
        $A1,$C8,$DA,$12,$81,$7F,$D9,$22,$DB,$40,$2E,$AF]
    PAUSEUS 50
    ' ====== PROGRAM STARTUP ===========================================================================
    STARTUP:
        Gosub CLEAR_DISPLAY_FULL
    ' ====== MAIN PROGRAM ==============================================================================
    MAIN:
        GOSUB SPLASH1
        PAUSE 2000
        GOSUB SPLASH2
        PAUSE 2000
        GOTO MAIN
    ' ====== CLEAR FULL DISPLAY ROUTINE ================================================================
    CLEAR_DISPLAY_FULL:
        I2CWrite SDA,SCL,I2CDevice,[$00,$21,28,99,$22,0,4]
        FOR Page = 0 TO 4
            I2CWrite SDA,SCL,I2CDevice,[$40,_
                0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0, _
                0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
        NEXT Page
    ' ====== SPLASH SCREEN DISPLAY =====================================================================
    SPLASH1:
            0,0,252,252,252,60,28,28,28,56,248,248,240,192,0,0,0,252,252,252,0,0,0,0,192,240,248,120,60,28,28,28,28,60,248,248,240,192,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
            0,0,255,255,255,56,56,56,56,60,31,31,15,3,0,0,0,255,255,255,0,0,0,62,255,255,255,128,0,0,0,0,0,0,192,192,192,192,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
            0,0,15,15,15,0,0,0,0,0,0,0,0,0,0,0,0,15,15,15,0,0,0,0,1,3,7,15,14,14,12,14,14,15,15,7,3,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
            0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,240,252,252,140,140,204,252,120,0,0,0,96,96,32,32,224,224,0,0,192,224,224,32,32,96,64,0,0,192,236,108,0,128,192,224,96,32,96,96,64,0]
            0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,62,63,55,49,49,57,31,31,6,0,28,62,54,34,18,63,63,7,0,16,56,49,35,55,62,30,0,0,56,63,15,0,0,31,63,48,48,48,56,24,0,0]
    SPLASH2:
            0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
            0,0,128,128,192,192,0,0,0,0,128,192,192,192,192,192,128,0,0,192,192,192,192,192,192,0,0,128,128,192,192,0,0,0,0,128,192,64,192,128,0,0,0,0,0,0,0,192,192,192,0,0,0,0,0,0,0,192,192,192,0,0,0,128,192,192,192,192,192,128,0,0]
            0,0,1,129,255,255,128,0,0,0,255,255,136,12,140,249,249,0,0,255,255,12,12,12,12,0,0,1,129,255,255,128,0,0,99,255,32,8,156,255,99,0,0,96,120,124,103,99,255,255,96,0,0,96,120,124,103,99,255,255,96,0,0,255,255,136,12,140,249,249,0,0]
            0,0,1,1,1,1,1,1,0,0,0,1,1,1,1,1,0,0,0,1,1,0,0,0,0,0,0,1,1,1,1,1,1,0,0,0,1,1,1,0,0,0,0,0,0,0,0,0,1,1,0,0,0,0,0,0,0,0,1,1,0,0,0,0,1,1,1,1,1,0,0,0]
    Roger
  1. big char oled display
    By mombasa in forum mel PIC BASIC Pro
    Last Post: - 19th September 2020, 07:02
  2. SSD1306 start display problem
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 14th December 2016, 19:16
  3. Cannot drive I2C Oled :(
    By elcrcp in forum mel PIC BASIC Pro
    Last Post: - 20th August 2016, 12:19
  4. OLED Display Noise problem
    By gunayburak in forum mel PIC BASIC Pro
    Last Post: - 5th July 2016, 10:15
  5. Help With OLED Display / 128X64 SSD1306
    By Denner in forum General
    Last Post: - 25th May 2013, 15:40
Members who have read this thread : 22
