SSD1306 OLED (72x40) I2C display from scratch
Results 1 to 40 of 74
Threaded View
  1. #10
    Default Re: SSD1306 OLED (42x40) I2C display from scratch
    is this more clear ?
    draws a 7x5 chr A and 14x10 A in a 72x40 window located @ x=0y=0 after clearing screen [ outside of window is just random noise ]
    here's a pic on a 128x64 screen , there is no telling how it line up for your screen
    #CONFIG __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_OFF & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOD_ON & _IESO_ON & _FCMEN_ON
    define OSC 8
    OSCCON = 110000 'Internal RC set to 8MHZ
    'ANSEL = 000000 'Select analog inputs Channels 0 to 7 (AN2 + AN4 selected)
    'ANSELH = 000000 'Select analog inputs Channels 8 to 11
    'TRISB = 000000 'Set Input/Output (4 to 7)
    'PORTB = 000000 'Ports High/Low (4 to 7)
    ' ====== VARIABLES ================================================== ===============================
    I2CDevice var byte
    SDA VAR PORTB.6 ' I2C Data
    SCL VAR PORTB.4 ' I2C Clock
    LCD_DATA VAR BYTE
    COM VAR BYTE ' COMMAND
    I VAR BYTE
    J VAR BYTE
    X VAR BYTE 'LCD POSITION X(0 TO 127)
    Y VAR BYTE 'LCD POSITION Y(0 TO 7)
    ' ====== INITIALIZE VARIABLES ================================================== ====================
    I2CDevice = $78
    '======= SSD1306 I2C OLED initialization ================================================== =========
    COM = $AE : GOSUB SEND_COMMAND ' turn off oled panel
    COM = $D5 : GOSUB SEND_COMMAND ' set display clock divide ratio/oscillator frequency
    COM = $80 : GOSUB SEND_COMMAND ' set divide ratio
    COM = $A8 : GOSUB SEND_COMMAND ' set multiplex ratio
    COM = $3F : GOSUB SEND_COMMAND ' 1/40 duty
    COM = $D3 : GOSUB SEND_COMMAND ' set display offset
    COM = $0 : GOSUB SEND_COMMAND
    COM = $20 : GOSUB SEND_COMMAND
    COM = $AD : GOSUB SEND_COMMAND ' Internal IREF Setting
    COM = $30 : GOSUB SEND_COMMAND ' --
    COM = $8D : GOSUB SEND_COMMAND ' set Charge Pump enable/disable
    COM = $14 : GOSUB SEND_COMMAND ' set(0x10) disable
    COM = $40 : GOSUB SEND_COMMAND ' set start line address
    COM = $A6 : GOSUB SEND_COMMAND ' set normal display
    COM = $A4 : GOSUB SEND_COMMAND ' Disable Entire Display On
    COM = $A1 : GOSUB SEND_COMMAND ' set segment re-map 128 to 0
    COM = $C8 : GOSUB SEND_COMMAND ' Set COM Output Scan Direction 64 to 0
    COM = $DA : GOSUB SEND_COMMAND ' set com pins hardware configuration
    COM = $12 : GOSUB SEND_COMMAND '
    COM = $81 : GOSUB SEND_COMMAND ' set contrast control register
    COM = $7F : GOSUB SEND_COMMAND '
    COM = $D9 : GOSUB SEND_COMMAND ' set pre-charge period
    COM = $22 : GOSUB SEND_COMMAND '
    COM = $DB : GOSUB SEND_COMMAND ' set vcomh
    COM = $AF : GOSUB SEND_COMMAND ' turn on oled panel
    ' ====== PROGRAM ================================================== =================================
    GOSUB CLEAR_LCD
    MAIN:
    ;7x5 "A"
    X = 15 : Y = 0 : GOSUB SET_7
    I2CWrite SDA,SCL,I2CDevice,[$40,$fc,$12,$12,$12,$fc]
    ;14x10 "A"
    X = 15 : Y = 2 : GOSUB SET_14
    I2CWrite SDA,SCL,I2CDevice,[$40,$f0,$f8,12,12,14,14,12,12,$f8,$f0_
    ,$ff,$ff,6,6,6,6,6,6,$ff,$ff]
    PAUSE 1000
    GOTO MAIN
    ' ====== CLEAR LCD ================================================== ===============================
    CLEAR_LCD:
    COM = $21 : GOSUB SEND_COMMAND
    COM = 0 : GOSUB SEND_COMMAND
    COM = 71 : GOSUB SEND_COMMAND
    COM = 4 : GOSUB SEND_COMMAND
    LCD_DATA = $00
    FOR J = 0 TO 4
    FOR I = 0 TO 71
    I2CWrite SDA,SCL,I2CDevice,[$40,LCD_DATA]
    NEXT I
    NEXT J
    ' ====== SEND COMMAND ================================================== ============================
    SEND_COMMAND:
    I2CWrite SDA,SCL,I2CDevice,[0,COM]
    '======= SET_XY ================================================== ==================================
    SET_7: '7x5
    COM = X : GOSUB SEND_COMMAND
    COM = x+4 : GOSUB SEND_COMMAND
    COM = Y : GOSUB SEND_COMMAND
    COM = y : GOSUB SEND_COMMAND
    SET_14: ;14x10
    COM = x+9 : GOSUB SEND_COMMAND
    COM = y+1 : GOSUB SEND_COMMAND
  1. big char oled display
    By mombasa in forum mel PIC BASIC Pro
    Last Post: - 19th September 2020, 08:02
  2. SSD1306 start display problem
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 14th December 2016, 20:16
  3. Cannot drive I2C Oled :(
    By elcrcp in forum mel PIC BASIC Pro
    Last Post: - 20th August 2016, 13:19
  4. OLED Display Noise problem
    By gunayburak in forum mel PIC BASIC Pro
    Last Post: - 5th July 2016, 11:15
  5. Help With OLED Display / 128X64 SSD1306
    By Denner in forum General
    Last Post: - 25th May 2013, 16:40
