SSD1306 OLED (72x40) I2C display from scratch
Results 1 to 40 of 74
Threaded View
  1. #8
    Default Re: SSD1306 OLED (42x40) I2C display from scratch
    Basically the display is 360 bytes of ram where every bit is a oled, the ram is divided into 5 pages each of 72 bytes
    the 5 pages are overlaid onto a larger array that is 8 pages of 128 bytes, precisely where is not known to me [i have never seen one of those modules]
    the ssd1306 is very versatile and allows vertical and horiz offsets to be set along with scan direction and various mem access methods to suit you.
    to write to a byte you must address its x and y position , the width to be written and number of pages is also expected to be set
    ie to write a 10x14 chr 14 high 10 wide at page 1 posn 12
    SET_XY:
    COM = $21 : GOSUB SEND_COMMAND
    COM = 12 : GOSUB SEND_COMMAND ;x=12
    COM = 22 : GOSUB SEND_COMMAND ;12+10
    COM = $22 : GOSUB SEND_COMMAND
    COM = 1 : GOSUB SEND_COMMAND ;y=1
    COM = 2 : GOSUB SEND_COMMAND ;1+1
    then send the 20 bytes needed to represent your chr
    In my case, I will use this LCD to display, as big as possible, a number as a percentage (0.0%...99.9%).
    easy you need to create a big font with the chrs you need in it
    Is there a way to send "text" to the display like common LCDs?
    no not even close
    if you want easy use a pic18 and my code from here
    where you can define the screen size and create fonts as you need
    or use an enhanced core pic16 and my earlier code that can do double size chrs
  1. big char oled display
    By mombasa in forum mel PIC BASIC Pro
    Last Post: - 19th September 2020, 08:02
  2. SSD1306 start display problem
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 14th December 2016, 20:16
  3. Cannot drive I2C Oled :(
    By elcrcp in forum mel PIC BASIC Pro
    Last Post: - 20th August 2016, 13:19
  4. OLED Display Noise problem
    By gunayburak in forum mel PIC BASIC Pro
    Last Post: - 5th July 2016, 11:15
  5. Help With OLED Display / 128X64 SSD1306
    By Denner in forum General
    Last Post: - 25th May 2013, 16:40
