SSD1306 OLED (72x40) I2C display from scratch
+ Reply to Thread
Results 1 to 40 of 74
    SWITZERLAND (french speaking)
    Default SSD1306 OLED (72x40) I2C display from scratch
    Thanks a lot guys 👍
    I'll give it a try this week-end.
    And thanks Richard for condensing the information here
    Roger
    Only garbage at this time...but it's alive
    Roger
    Default Re: SSD1306 OLED (42x40) I2C display from scratch
    Seems that the character size is too big to fit there..
    ...still struggeling with the ssd1306's datasheet to understand the "page" concept and how to display things.
    This is the simplest and shortest code I'm working with for now, composed of different sources I found in this forum and also on ARDUINO's one:
    ' ====== DESCRIPTION ===============================================================================
    ' Use mini OLED 72x40 pixel display
    ' PIC 16F690 Fuses
    ' Internal oscillator  (activate OSCCON register)
    @ __config _FCMEN_OFF &_IESO_OFF &_CPD_OFF &_WDT_OFF &_INTRC_OSC_NOCLKOUT &_BOR_OFF &_CP_OFF &_PWRTE_OFF &_MCLRE_OFF
    @ ERRORLEVEL -306
    @ ERRORLEVEL -202
    '             76543210
    OPTION_REG = %10000000 'PORT A&B Pull-Ups disabled (see WPUA & WPUB)
    OSCCON     = %01100000 'Internal RC set to 4MHZ
    'ANSEL      = %00000000 'Select analog inputs Channels 0 to 7 (AN2 + AN4 selected)
    'ANSELH     = %00000000 'Select analog inputs Channels 8 to 11
    'ADCON0     = %10000000 'A/D Module (Bit5:2 select channels 0:11)
    'ADCON1     = %00000000 'A/D control register
    'CM1CON0    = %00000000 'Comparator1 Module is OFF
    'CM2CON0    = %00000000 'Comparator2 Module is OFF
    'INTCON     = %00000000 'INTerrupts CONtrol (TMR0 OFF)
    'TRISA      = %00000000 'Set Input/Output (0 to 5)
    'PORTA      = %00000000 'Ports High/Low (0 to 5)
    'TRISB      = %00000000 'Set Input/Output (4 to 7)
    'PORTB      = %00000000 'Ports High/Low (4 to 7)
    'TRISC      = %00000000 'Set Input/Output (0 to 7)
    'PORTC      = %00000000 'Ports High/Low (0 to 7)
    'DEFINE NO_CLRWDT 1   'Don't waste cycles clearing WDT
    'DEFINE HSER_CLOERR 1 'Automatic clear overrun error
    ' ====== VARIABLES =================================================================================
    I2CDevice   var byte
    SDA         VAR PORTB.4 ' I2C Data
    SCL         VAR PORTB.6 ' I2C Clock
    TEXT        VAR BYTE[20]
    LENGTH      VAR BYTE[2]
    DC          VAR Byte    ' "DATA OR COMMAND", $40=DATA; $0=COMMAND --> changed from bit to byte
    LCD_DATA    VAR BYTE
    COM         VAR BYTE    ' COMMAND
    I           VAR BYTE
    J           VAR BYTE
    X           VAR BYTE  'LCD POSITION X(0 TO 127)
    Y           VAR BYTE  'LCD POSITION Y(0 TO 7)
    ' ====== INITIALIZE VARIABLES ======================================================================
    I2CDevice = $78
    '======= SSD1306 I2C OLED initialization ===========================================================
    COM = $AE : GOSUB SEND_COMMAND ' turn off oled panel
    COM = $D5 : GOSUB SEND_COMMAND ' set display clock divide ratio/oscillator frequency
    COM = $80 : GOSUB SEND_COMMAND ' set divide ratio
    COM = $A8 : GOSUB SEND_COMMAND ' set multiplex ratio
    COM = $27 : GOSUB SEND_COMMAND ' 1/40 duty
    COM = $D3 : GOSUB SEND_COMMAND ' set display offset
    COM = $00 : GOSUB SEND_COMMAND ' not offset
    COM = $AD : GOSUB SEND_COMMAND ' Internal IREF Setting
    COM = $30 : GOSUB SEND_COMMAND ' --
    COM = $8D : GOSUB SEND_COMMAND ' set Charge Pump enable/disable
    COM = $14 : GOSUB SEND_COMMAND ' set(0x10) disable
    COM = $40 : GOSUB SEND_COMMAND ' set start line address
    COM = $A6 : GOSUB SEND_COMMAND ' set normal display
    COM = $A4 : GOSUB SEND_COMMAND ' Disable Entire Display On
    COM = $A1 : GOSUB SEND_COMMAND ' set segment re-map 128 to 0
    COM = $C8 : GOSUB SEND_COMMAND ' Set COM Output Scan Direction 64 to 0
    COM = $DA : GOSUB SEND_COMMAND ' set com pins hardware configuration
    COM = $12 : GOSUB SEND_COMMAND '
    COM = $81 : GOSUB SEND_COMMAND ' set contrast control register
    COM = $AF : GOSUB SEND_COMMAND '
    COM = $D9 : GOSUB SEND_COMMAND ' set pre-charge period
    COM = $22 : GOSUB SEND_COMMAND '
    COM = $DB : GOSUB SEND_COMMAND ' set vcomh
    COM = $20 : GOSUB SEND_COMMAND '
    COM = $AF : GOSUB SEND_COMMAND ' turn on oled panel
    ' ====== PROGRAM ===================================================================================
    PAUSE 20
    GOSUB CLEAR_LCD
    GOSUB TITLE
    MAIN:
        PAUSE 1000
        GOTO MAIN
    ' ====== CLEAR LCD =================================================================================
    CLEAR_LCD:
        FOR J = 0 TO 7
            FOR I = 0 TO 71 '127
                LCD_DATA = $00 : GOSUB SEND_DATA
            NEXT I
        NEXT J
    ' ====== SEND COMMAND ==============================================================================
    SEND_COMMAND:
        dc = $0
        I2CWrite SDA,SCL,I2CDevice,DC,[COM]
        dc = $40
    SEND_DATA:
        DC = $40
        I2CWrite SDA,SCL,I2CDevice,DC,[LCD_DATA]
    ' ====== SEND DATA =================================================================================
    FILL:
        FOR J = 0 TO 7
                LCD_DATA = $FF : GOSUB SEND_DATA
            NEXT I
        NEXT J
    ' ====== TITLE =====================================================================================
    TITLE:
        X = 0 : Y = 0 : GOSUB SET_XY
            LOOKUP I,[$00,$40,$60,$50,$7E,$50,$60,$40,$02,$06,$0E,$1E,$3E,$00,$00,$00,_
            $00,$00,$00,$00,$00,$1F,$3F,$60,$60,$60,$60,$60,$60,$3C,$1C,$00,_
            $00,$7F,$7F,$61,$61,$61,$61,$61,$61,$3F,$1E,$00,$00,$1E,$3F,$61,_
            $61,$61,$61,$61,$61,$38,$18,$00,$00,$00,$00,$00,$00,$00,$00,$00,_
            $00,$00,$00,$00,$00,$00,$00,$1F,$3F,$60,$60,$60,$60,$60,$60,$3C,_
            $1C,$00,$00,$1E,$3F,$61,$61,$61,$61,$61,$61,$38,$18,$00,$00,$3F,_
            $7F,$60,$18,$06,$06,$18,$60,$7F,$3F,$00,$00,$00,$00,$00,$00,$00,_
            $00,$00,$00,$1C,$63,$41,$5D,$41,$5D,$41,$5D,$41,$5D,$41,$7F,$00],LCD_DATA
            lcd_data = lcd_data rev 8
            GOSUB SEND_DATA
        NEXT I
        X = 0 : Y = 1 : GOSUB SET_XY
        for i = 0 to 71 '127
            lookup i,[$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,_
            $00,$00,$00,$00,$00,$F8,$FC,$06,$06,$06,$C6,$C6,$C6,$FC,$F8,$00,_
            $00,$FE,$FE,$80,$80,$80,$80,$80,$80,$00,$00,$00,$00,$18,$1C,$86,_
            $86,$86,$86,$86,$86,$FC,$78,$00,$00,$00,$00,$00,$00,$00,$00,$00,_
            $00,$00,$00,$00,$00,$00,$00,$F8,$FC,$06,$06,$06,$C6,$C6,$C6,$FC,_
            $F8,$00,$00,$18,$1C,$86,$86,$86,$86,$86,$86,$FC,$78,$00,$00,$FE,_
            $FE,$00,$00,$00,$00,$00,$00,$FE,$FE,$00,$00,$00,$00,$00,$00,$00,_
            $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00],lcd_data
            lcd_data=lcd_data rev 8
            GOSUB SEND_DATA
        NEXT I
        X = 0 : Y = 3 : GOSUB SET_XY
            lookup i,[$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$3C,$7E,$C3,$C3,$C3,$C3,_
            $C3,$C3,$71,$30,$00,$00,$7F,$FF,$C3,$C3,$C3,$C3,$C3,$C3,$C3,$C3,_
            $00,$00,$7F,$FF,$C1,$C1,$C1,$C1,$C1,$C1,$FF,$7F,$00,$00,$7F,$FF,_
            $C3,$C3,$C3,$C3,$C3,$C3,$7E,$3C,$00,$00,$3F,$7F,$C0,$C0,$C0,$C0,_
            $C0,$C0,$70,$30,$00,$00,$FF,$FF,$03,$03,$03,$03,$03,$03,$FF,$FF,_
            $00,$00,$C0,$C0,$C0,$C0,$FF,$FF,$C0,$C0,$C0,$C0,$00,$00,$FF,$FF,_
            $0C,$0C,$03,$03,$00,$00,$FF,$FF,$00,$00,$3F,$7F,$C0,$C0,$C0,$C1,_
            $C1,$C1,$79,$39,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00],lcd_data
            GOSUB SEND_DATA
        NEXT I
        X = 0 : Y = 4 : GOSUB SET_XY
            lookup i,[$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$30,$38,$0C,$0C,$0C,$0C,_
            $0C,$0C,$F8,$F0,$00,$00,$F8,$FC,$0C,$0C,$0C,$0C,$0C,$0C,$0C,$0C,_
            $00,$00,$FC,$FC,$80,$80,$80,$80,$80,$80,$FC,$FC,$00,$00,$FC,$FC,_
            $80,$C0,$60,$30,$18,$0C,$04,$00,$00,$00,$F0,$F8,$0C,$0C,$0C,$0C,_
            $0C,$0C,$38,$30,$00,$00,$FC,$FC,$00,$00,$00,$00,$00,$00,$FC,$FC,_
            $00,$00,$0C,$0C,$0C,$0C,$FC,$FC,$0C,$0C,$0C,$0C,$00,$00,$FC,$FC,_
            $00,$00,$00,$00,$C0,$C0,$FC,$FC,$00,$00,$F0,$F8,$0C,$0C,$0C,$8C,_
            $8C,$8C,$F8,$F0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00],lcd_data
            GOSUB SEND_DATA
        NEXT I
        X = 0 : Y = 5 : GOSUB SET_XY
            lookup i,[$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$1F,$3F,$30,$30,$30,$30,_
            $30,$30,$30,$30,$00,$00,$0F,$1F,$30,$30,$30,$30,$30,$30,$1F,$0F,_
            $00,$00,$1F,$3F,$30,$30,$30,$30,$30,$30,$1F,$0F,$00,$00,$00,$00,_
            $00,$00,$00,$0F,$1F,$30,$30,$30,$30,$30,$30,$1C,$0C,$00,$00,$30,_
            $30,$30,$30,$3F,$3F,$30,$30,$30,$30,$00,$00,$0F,$1F,$30,$30,$30,_
            $30,$30,$30,$1E,$0E,$00,$00,$3F,$3F,$03,$03,$00,$00,$00,$00,$3F,_
            $3F,$00,$00,$1F,$3F,$30,$30,$30,$30,$30,$30,$3F,$1F,$00,$00,$3F,_
            $3F,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00],lcd_data
            GOSUB SEND_DATA
        NEXT I
        X = 0 : Y = 6 : GOSUB SET_XY
            lookup i,[$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$FF,$FF,$C0,$C0,$C0,$C0,_
            $C0,$C0,$00,$00,$00,$00,$FC,$FE,$03,$03,$03,$03,$03,$03,$FE,$FC,_
            $00,$00,$FF,$FF,$E0,$F0,$D8,$CC,$C6,$C3,$81,$00,$00,$00,$00,$00,_
            $00,$00,$00,$0C,$8E,$C3,$C3,$C3,$C3,$C3,$C3,$7E,$3C,$00,$00,$03,_
            $03,$03,$03,$FF,$FF,$03,$03,$03,$03,$00,$00,$FC,$FE,$03,$03,$03,_
            $63,$63,$63,$7E,$7C,$00,$00,$FF,$FF,$00,$00,$C0,$C0,$30,$30,$FF,_
            $FF,$00,$00,$FF,$FF,$60,$60,$60,$60,$60,$60,$FF,$FF,$00,$00,$FF,_
            $FF,$03,$03,$03,$03,$03,$03,$03,$03,$00,$00,$00,$00,$00,$00,$00],lcd_data
            GOSUB SEND_DATA
        NEXT I
    '======= SET_XY ====================================================================================
    SET_XY:
        COM = $21 : GOSUB SEND_COMMAND
        COM = X   : GOSUB SEND_COMMAND
        COM = 71  : GOSUB SEND_COMMAND
        COM = Y   : GOSUB SEND_COMMAND
        COM = 41  : GOSUB SEND_COMMAND
    Originally, this code is made for a larger display so I need to adapt it.
    Roger
    Is it worth it the effort to spend much time on this LCD's?
    It tried it and seems a lot of waste of time. Also too small for my age
    Up to now, I couldn't find any pixel map for the 72x40 display so I'm relying on information for the 128x64 one.
    This is the information I have found in the 72x40 datasheet:
    Can anybody tell me how I should convert this in "pages" if I have to do so? I don't understand how data has to be displayed...
    This is the example from the 128x64's datasheet (to be found in attachment):
    Roger
  1. big char oled display
    By mombasa in forum mel PIC BASIC Pro
    Last Post: - 19th September 2020, 07:02
  2. SSD1306 start display problem
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 14th December 2016, 19:16
  3. Cannot drive I2C Oled :(
    By elcrcp in forum mel PIC BASIC Pro
    Last Post: - 20th August 2016, 12:19
  4. OLED Display Noise problem
    By gunayburak in forum mel PIC BASIC Pro
    Last Post: - 5th July 2016, 10:15
  5. Help With OLED Display / 128X64 SSD1306
    By Denner in forum General
    Last Post: - 25th May 2013, 15:40
Members who have read this thread : 23
