SSD1306 OLED (72x40) I2C display from scratch
Page 1 of 2 12 LastLast
Results 1 to 40 of 74
    SWITZERLAND (french speaking)
    Default SSD1306 OLED (72x40) I2C display from scratch
    Hi there,
    I juste received a bunch of very small (72x40) OLED displays driven by a SSD1306 controller.
    Name:  2023-11-13 17_51_05-Mini OLED 72x40 front_200x200.png
Size:  42.6 KBName:  2023-11-13 17_51_51-Mini OLED 72x40 back_200x200.png
    I have absolutely never used those displays, in particular the SSD1306 controller.
    After a few searches in the forum, I got some examples but these don't really help unless I first understand the very basics.
    So, would anyone of you have a code snippet I could start with and ready to share it or a good reference to understand the SSD1306 please?
    For example, it starts right at the beginning: there seems to be a "display" address. Is this standard for I2C displays or should I get it from the manufacturer?
    Voilą, that's the low I'm right now...
    So again, if somenone has basic stuff to share, I would really appreciate
    Roger
    Default Re: SSD1306 OLED (42x40) I2C display from scratch
    i would initialize the display as per my posts to start with and work from there
    a simple i2c scan such as this will reveal the address
    '****************************************************************'*  Name    : UNTITLED.BAS                                      *
    '*  Notice  : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 9/23/2014                                         *
    '*  Notes   : pic16f1825                                        *
    '*          :  scan i2c bus                                     *
       __config _CONFIG1, _WDTE_ON    & _FOSC_INTOSC   &_MCLRE_ON    &_PWRTE_ON
       __config _CONFIG2,              _LVP_OFF   & _PLLEN_ON
             DEFINE OSC 32
      DEFINE I2C_SLOW 1
         osccon=$70    '8 mhz
             anselA=0        'dig i/o
             ANSELC=0
          TRISC= %11111111
           TRISA= %11111110
    SCL                 var Portc.1                     ' I2C Clock  PortA.3
    SDA                 var Portc.0                     ' I2C Data   PortA.2
    I                   VAR BYTE
    buff                var byte[10]
    addr                var byte
        porta.0=1
        DEFINE DEBUG_REG PORTA
        DEFINE DEBUG_BIT 0      ;
        DEFINE DEBUG_BAUD 38400
        DEFINE DEBUG_MODE 0
        pause 2000
        Debug "Start",13 ,10
    addr=$E3
    for I = $02 to $fe step 2
    I2Cwrite SDA,SCL,i,addr,[0],nak
    ARRAYWRITE buff[1], [ "found",0]
    Debug str buff , 9
    Debug "ack ",hex2 i , 13,10
    nak:
    Next I
    okay, first step done!
    Name:  2023-11-14 17_59_52-Clipboard.png
    Roger
    Richard,
    I'm not sure to find your initialisation example.
    I found the one from Tim (https://www.picbasic.co.uk/forum/sho...nclude-example).
    I'll try this one if it is okay.
    Roger
    Thanks Ioannis.
    I saw them all but there are many files and includes (...) that Tim's example seemed "easier" to start with.
    Not knowing what I really need to keep among them for a start, it's a little bit more confusing.
    I need help so I'll go back to the post you mentionned and (try to) compose/compile what I need to run on a 16F
    Roger
    I really appreciate anyone's help but maybe to help me get my head out of the myst, could someone roughly tell me at at least how these displays work?
    Appart from the easiest part which is to connect them to ą µC, how does it basically work like:
    - connect it
    - on power-up, initialize it (seems there's a bunch of parameters to send to the display)
    - will it already light-up something (backlight or any dot on the screen?)
    - prepare a bunch of data to actually define the caracters you will want to display in a LOOKUP table
    - call-up and send this or that caracter to display
    - does the display need to be refreshed every x time or is it a one-shot command that will suffice to have something displayed
    When I mean "basics", I really mean it.... I have absolutely no clue how this little things work....
    Roger
    These LCD's are difficult to use. Indeed there are too many parameters to set and also you have to design the characters to display.
    The good thing is that you have flexibility in designing the characters, the bad is that you have to do it!
    The good member Richard has done much of the dirty work to use these LCD's and gave us the libraries. But you have to do your part too, especially if you have different LCD. You need to adapt to the dimensions of the screen, design your graphics etc...
    Powering up the display may not light any LED's and display nothing. All are software controlled.
    I tried an 0.9" LCD and with the support of the Richard managed to display text in various sizes. But I admit I have not fully mastered the beast.
    The latest version of the include is on post #90 of the link posted by ionnis reposted here for your convenience
    this display is not something you can sneak up on easily , you really need a 100% solution before you can get anywhere
    your 42x40 version will very likely need a few tweaks to match the way the oled array has been mapped onto the segment/com pins
    and represented on the graphic memory overlay of the driver chip, i don't have one to experiment with
    there is an alternative version here for p18 chips only that is more versatile, it would still need the same tweaks too
    https://www.picbasic.co.uk/forum/sho...lays-with-PBP3
    the init routine is fairly well commented if you read it in conjunction with the ssd1306 data sheet
    '****************************************************************'*  Name    : ssd1306_I2C.INC                                   *
    '*  Author  : richard                                           *
    '*  Notice  :                                                   *
    '*  Date    : 8/2/2022                                          *
    '*  Version : 1.2                                               *
    '*  Notes   : font address banksel fixed                        *
    '*          :FOR pic 16/18       SSD1306                        *
     goto overglcd
    ; adjust to suit and  place these in main prg
    ;use this define for hw i2c
    ;#define hwi2c 1
    ;#DEFINE PIC16 1    ;IF PIC 16 USED  [USE PIC16 FONT TOO}
    ' ssdheight con 7       ; 7 = 8 PAGES  64*128 ,  3 = 4 pages 32*128
    ' ssdwidth  con 127     ; 128 PIXELS WIDE
    ' SCL var PortC.3       ' I2C Clock
    ' SDA var PortC.4       ' I2C Data
    ' sdd1306_addr con $78
     USERCOMMAND "GLCDC"     ; X,Y,CHR  0 <  X < 127  ,   0 <  Y < 7    31 < CHR > 127
     USERCOMMAND "GLCD_CLR"  ;clear area x,y,W,H
     USERCOMMAND "GLCDSTR"   ;STRING @ X,Y  or   Constant String
     USERCOMMAND "GLCDDHL"   ; x,y,L ,bit-patten
     USERCOMMAND "GLCDDVL"   ; x,y,H
     USERCOMMAND "SSDC"      ;cmd BYTE TO SSD1306
     USERCOMMAND "SSDBM"     ;x,y,w,h,label
     ;----------------------VERT LINE------------------------------------
    GLCDDVL?CCC  macro Xin ,Yin , Hin
        MOVE?CB  Xin ,_gx
        MOVE?CB  Yin,_gy
        MOVE?CB  Hin ,_gl
        L?CALL _xyy
     ;----------------------HORIZ LINE------------------------------------
    GLCDDHL?CCCC  macro Xin ,Yin , Win ,Cin
        MOVE?CB  Xin ,_gx
        MOVE?CB  Yin,_gy
        MOVE?CB  Win ,_gl
        MOVE?CB  Cin ,_glcdData
        L?CALL _xyx
      ;----[const String]---------------------------------------------------------------
    GLCDSTR?CCS  macro Xin ,Yin,Cin
     IFNDEF  TBLPTRL
        local TheString, OverStr ; define local labels so you can call macro multiple times
        goto OverStr ; goto over string stored in FLASH, so processor can't execute that
    TheString ;label to get address of your string
        da Cin, 0 ;add string to flash at TheString address and end string with 0
    OverStr
        MOVE?CW  TheString, _glcd_bigaddress
        MOVE?CB Xin , _gx
        MOVE?CB Yin , _gy
        L?GOTO  _GlcdUnpackStr
        data Cin, 0 ;add string to flash at TheString address and end string with 0
    OverStr
        movlw   UPPER TheString
        movwf   TBLPTRU
        movlw   HIGH TheString
        movwf   TBLPTRH
        movlw   LOW TheString
        movwf   TBLPTRL
        MOVE?CB Xin , _gx
        MOVE?CB Yin , _gy
        L?CALL  GLCD_Cstr_out
    SSDBM?CCCCL   macro Xin ,Yin ,Win,Hin,BMin
     IFNDEF  TBLPTRL
        ERROR BITMAPS ONLY SUPPORTED ON PIC18
         MOVE?CB Xin , _gx
         MOVE?CB Yin , _gy
         MOVE?CB Hin/8-1 , _gy_
         MOVE?CB Win+Xin-1 , _gx_
         MOVE?CW Win*Hin/8 , _glcd_rad
         banksel   _glcdbm
         movlw low BMin
         movwf _glcdbm
         movlw high BMin
         movwf _glcdbm +1
         BANKSEL 0
         L?CALL  _ssd_bitmap
     ;----------------------Strings------------------------------------
    GLCDSTR?CBB  macro Xin ,Yin ,Bin
        MOVE?CB Xin , _gx
        MOVE?BB Yin , _gy
        MOVE?CB high Bin, FSR1H ;load highbyte
        MOVE?CB low  Bin, FSR1L ;load low byte
        L?CALL  GLCD_str_out
    GLCDSTR?CCB  macro Xin ,Yin ,Bin
        MOVE?CB Xin , _gx
        MOVE?CB Yin  ,_gy
        MOVE?CB high (Bin), FSR1H ;load highbyte
        MOVE?CB low  (Bin), FSR1L ;load low byte
        L?CALL  GLCD_str_out
    GLCDSTR?BBB  macro Xin ,Yin ,Bin
        MOVE?B  Xin, _gx
        MOVE?B  Yin, _gy
        L?CALL  GLCD_str_out
    GLCDSTR?WBB  macro Xin ,Yin ,Bin
        MOVE?WB Xin, _gx
        MOVE?BB Yin, _gy
        L?CALL  GLCD_str_out
    GLCDSTR?WWB  macro Xin ,Yin ,Bin
        MOVE?WB Xin, _gx
        MOVE?WB Yin, _gy
        L?CALL  GLCD_str_out
    SSDC?C  macro Cin
        MOVE?CB  Cin , _glcdData
        L?CALL   _cmd_byte
    SSDC?B  macro Cin
        MOVE?BB  Cin , _glcdData
        L?CALL   _cmd_byte
    GLCD_CLR? macro
        MOVE?CB  0, _gx
        MOVE?CB  0, _gy
        MOVE?CB  _ssdwidth, _gx_
        MOVE?CB  _ssdheight, _gy_
        L?CALL   _glcd_clrxy
    GLCD_CLR?CCCC macro   Xin ,Yin,X1in ,Y1in
        MOVE?CB  Xin, _gx
        MOVE?CB  Yin, _gy
        MOVE?CB  X1in, _gx_
        MOVE?CB  Y1in, _gy_
        L?CALL   _glcd_clrxy
     ;----------------------Character @ X,Y ------------------------------------
    GLCDC?BBB  macro Xin ,Yin , Bin
        MOVE?BB  Xin, _gx
        MOVE?BB  Yin, _gy
        MOVE?BB  Bin, _glcdCh
        L?CALL   _gcga
    GLCDC?WBB  macro Xin ,Yin , Bin
        MOVE?WB  Xin, _gx
        MOVE?BB  Yin, _gy
        L?CALL   _gcga
    GLCDC?WWB  macro Xin ,Yin , Bin
        MOVE?WB  Xin, _gx
        MOVE?WB  Yin, _gy
        L?CALL  _gcga
    GLCDC?BBC  macro Xin ,Yin , Cin
        MOVE?BB  Xin, _gx
        MOVE?BB  Yin, _gy
        MOVE?CB  Cin ,_glcdCh
        L?CALL   _gcga
    GLCDC?WBC  macro Xin ,Yin , Cin
        MOVE?WB  Xin, _gx
        MOVE?BB  Yin, _gy
        L?CALL   _gcga
    GLCDC?CCC  macro Xin ,Yin ,Cin
        MOVE?CB  Xin ,   _gx
        MOVE?CB  Yin,    _gy
        MOVE?CB  Cin,   _glcdCh
        L?CALL   _gcga
    GLCDC?CCB  macro Xin ,Yin ,Bin
        MOVE?CB  Xin ,  _gx
        MOVE?CB  Yin,    _gy
        L?CALL   _gcga
    GLetAddress macro Label, Wout
        BANKSEL Wout
        movlw low Label          ; get low byte
        movwf Wout
        movlw High Label         ; get high byte
        movwf Wout + 1
        BANKSEL 0
     IFDEF    TBLPTRL
    GLCD_Cstr_out
        tblrd   *+
        movf   TABLAT,w
        bz	GLCD_exit_Cstr_out  ; EXIT ON Null char
        CHK?RP  _glcdCh
        MOVWF   _glcdCh
        CHK?RP  _glcd_bigaddress
        movff   TBLPTRU,_glcd_bigaddress
        movff   TBLPTRH,_glcd_bigaddress+1
        movff   TBLPTRL,_glcd_bigaddress+2
        L?CALL  _gcga
        movff   _glcd_bigaddress   ,TBLPTRU
        movff   _glcd_bigaddress+1 ,TBLPTRH
        movff   _glcd_bigaddress+2 ,TBLPTRL
        bra     GLCD_Cstr_out
    GLCD_exit_Cstr_out
        BANKSEL 0
    GLCD_str_out
        movf POSTINC1, W	; Get a character
        bz	GLCD_exit_strout  ; EXIT ON Null char
        CHK?RP  _glcdCh
        MOVWF _glcdCh
        BANKSEL 0
        L?CALL _gcga
        bra    GLCD_str_out
    GLCD_exit_strout
        BANKSEL 0
    GLCD_str_out
        IFDEF BSR
            MOVIW FSR1++	; Get a character
            BTFSC STATUS,Z
            BRA	GLCD_exit_strout  ; EXIT ON Null char
            movf INDF, W	; Get a character
           BTFSC STATUS,Z
            GOTO	GLCD_exit_strout  ; EXIT ON Null char
            INCF FSR,F
        CHK?RP  _glcdCh
        MOVWF _glcdCh
        MOVE?BB FSR1L,_glcd_bigaddress
        MOVE?BB FSR1H,_glcd_bigaddress+1
        BANKSEL 0
        L?CALL _gcga
        MOVE?BB _glcd_bigaddress,FSR1L
        MOVE?BB _glcd_bigaddress+1,FSR1H
        GOTO  GLCD_str_out
    GLCD_exit_strout
        BANKSEL 0
    endasm
        glcd_bigaddress  VAR BYTE[3]
        glcd_buff        VAR BYTE[32]
        BIG_TEXT    var byte
        glcd_rad    var word
        glcdCh      var byte  'chr  DATA
        glcdData    VAR byte  'DATA
        glcdBC      VAR word  'gca  var
        glcdDC      VAR BYTE  'gca  var
        glcdFont    var word  bank0'font address
        glcdOffset  VAR word  'font offset
        glcdbm      VAR word  'bitmap offset
        gl          var byte  'width/height
        gy          var byte  'gca  pg   address
        gy_         var byte  'gca  pg   address
        gx          var byte  'gca  row  address
        gx_         var byte  'gca  row  address
        GRX         var byte  'DATA
        ctemp       var word
        ctemp1      var word
        ssd_add     var byte
        glcdStrAddr var word ext
    @glcdStrAddr =   _glcd_bigaddress
    GlcdUnpackStr:
        readcode glcdStrAddr,CTEMP
        glcd_bigaddress[2]  = CTEMP&$7f
        ctemp=ctemp<<1
        glcdCh = CTEMP.HIGHBYTE
        glcdStrAddr=glcdStrAddr+1
        if   glcdCh then
            gosub gcga
            glcdCh =  glcd_bigaddress[2]
        if   glcdCh then
            gosub gcga
        goto   GlcdUnpackStr:
    glcd_init:
    #ifdef hwi2c
        SSPSTAT = 0 'High Speed Filter
        SSPADD = $26'400 kHz @32 MHz
        SSPCON1 = %00101000 'I2C Master Mode Enable
        SSPCON3 = 0
    #endif
        @ GLetAddress _font7x5,_glcdFont
        ssd_add = sdd1306_addr
        SSDc $AE ' Display OFF
        SSDc $d5
        SSDc $80
        SSDc $a8 : SSDc $3f
        SSDc $D3 : SSDc $00 ; Set Display Offset Mode Set 0
        if ssdheight > 3  then
            SSDc $40   ' Set display start line 0
            SSDc $60   ' Set display start line 4
        SSDc $8D : SSDc $14 ' Set Charge Pump Internal
        SSDc $20 : SSDc $00 ' Adressing mode Horizontal
        SSDc $A1   ' set segment remap column 127 as start
        SSDc $C8   ' Com Scan Direction, Flip display vertically
        SSDc $DA   ' set COM pins
            SSDc$12  ' set COM pins = 128x64=$12
            SSDc$02  ' set COM pins = 128x32=$02
        SSDc $81 : SSDc$7F  ' Set brightness to $01 to $FF  ($7F is default, $01 is faint)
        SSDc $DB : SSDc$40  ' Set VCOM Deselect Level
        SSDc $B0  ' Set Page Address From $B0 to $B7
        SSDc $2e  ; scroll off
        SSDc $A4  ' display ON continue
        SSDc $A6  ' $A6=NORMAL MODE;  $A7=INVERSE MODE
        SSDc $AF  ' Display ON
    xyx:  ;draw HORIZ LINE @X,Y for W len   0<X>127   1<W>127
        FOR GRX = 0 TO 31
            glcd_buff[GRX] = glcdData  ;uses this var to set which bit/s is used to generate line
        NEXT
        gx = gx&ssdwidth
        gx_= gx + gl
        gy = gy&ssdheight
        gy_= gy
        gosub   setxy
        GRX = gl/32
        glcd_rad = 32
        WHILE GRX
            gosub ssd_data
            GRX = GRX-1
        WEND
        glcd_rad = gl//32
        IF glcd_rad  THEN
            gosub ssd_data
    xyy:       ;draw VERT LINE @X,Y for W len   @X 0<X>127   1<W>7
        FOR GRX = 0 TO ssdheight
            glcd_buff[GRX] = 255
        NEXT
        gx = gx&ssdwidth
        gx_= gx
        gy = gy&ssdheight
        gy_= gy+GL
        gosub   setxy
        glcd_rad = gl
        gosub ssd_data
    glcd_clrxy:    ' clear area  x1y1 to x2 y2
        FOR GRX = 0 TO 31
            glcd_buff[GRX] = 0
        NEXT
        CTEMP = (1 + GX_ - GX)*(1 + GY_ -  GY)
        gosub   setxy
        GRX = CTEMP/32
        glcd_rad=32
        WHILE GRX
            gosub ssd_data
            GRX = GRX-1
        WEND
        glcd_rad = CTEMP//32
        IF GRX THEN
            gosub ssd_data
    gcga:     ;draw a chr
        GY = gy&ssdheight
        GY_= gy + BIG_TEXT
        gx = gx&ssdwidth
        #ifdef PIC16
        glcdOffset = (glcdch-32)*3 + glcdFont  ; point to cga data
        #ELSE
        glcdOffset = (glcdch-32)*6 + glcdFont  ; point to cga data
        #ENDIF
        gosub unpack
        IF BIG_TEXT THEN
            GOSUB SSD_BIG
            glcd_rad = 24
            gx_= gx + 11
            glcd_rad = 6
            gx_= gx + 5
        gosub setxy
        gosub ssd_data
        gx = gx_+ 1 + BIG_TEXT
        IF GX > 121  THEN  gx=0    ;wrap
    ssd_data:   ;send data block
    #ifdef hwi2c
     glcdBC=0
     SSPCON2.0 = 1 ; SEN - Start Condition Enable Bit
     WHILE SSPCON2.0 = 1 : WEND ; Wait for Start to complete
     SSPBUF = ssd_add ; Move data to SSPBUF
     WHILE SSPSTAT.2 = 1 : WEND ; SSPSTAT = 1 Transmit in progress
     While SSPCON2.6 = 1 : WEND ; Wait for Acknowledge from slave
     SSPBUF = $40 ; Move data to SSPBUF
     while  glcdBC < glcd_rad
         SSPBUF = glcd_buff[glcdBC] ; Move data to SSPBUF
         glcdBC=glcdBC+1
     wend
     SSPCON2.2 = 1 ; PEN - send stop bit
     While SSPCON2.2 = 1 : Wend ; Wait for SSP to complete
    #else
     i2Cwrite SDA,SCL,ssd_add,[$40,str glcd_buff\ glcd_rad]
    #endif
    #ifndef PIC16
    ssd_bitmap:   ;send graphic block from flash
     gosub setxy
     glcdBC=0
         readcode glcdbm+glcdBC,CTEMP
         SSPBUF = ctemp.LOWBYTE ; Move data to SSPBUF
         SSPBUF = ctemp.highBYTE ; Move data to SSPBUF
         glcdBC=glcdBC+2
     wend
    #endif
    SSD_BIG:     ;create a big chr from a small one
       for glcddc = 5 to 0 STEP -1
       ctemp = 0
       ctemp1 = 3
       gL = glcd_buff[glcddc]
       for glcdBc = 0 to 7
           IF  GL & 1 THEN ctemp = ctemp|ctemp1
           ctemp1 = ctemp1<<2
           GL = GL>>1
       NEXT
       gL = glcddc*2
       glcd_buff[GL]   =ctemp.LOWBYTE
       glcd_buff[GL+1] =ctemp.LOWBYTE
       glcd_buff[GL+12]=ctemp.HIGHBYTE
       glcd_buff[GL+13]=ctemp.HIGHBYTE
       NEXT
    unpack:      ;unpack font from flash
       for glcddc = 0 to 2
           GL = glcddc<<1
           readcode glcdOffset,CTEMP
    #ifdef PIC16
           glcd_buff[gl]  = CTEMP&$7f
           ctemp=ctemp<<1
           glcd_buff[gl+1]= CTEMP.HIGHBYTE
           glcdOffset     = glcdOffset + 1
    #else
           glcdOffset     = glcdOffset + 2
    #endif
       next
    cmd_byte:  'send command sequence "glcdData "
    #ifdef hwi2c
     ;hw i2c
     SSPBUF = 0 ; Move data to SSPBUF
     SSPBUF = glcdData ; Move data to SSPBUF
     While SSPCON2.2 = 1: Wend ; Wait for SSP to complete
    #else
     ;soft i2c
       I2Cwrite SDA,SCL,ssd_add,[0,glcdData]
    #ENDIF
    setxy:    ;set PAGE  WINDOW
        SSDc $22
        SSDc gy
        SSDc gy_
        SSDc $21
        SSDc gx
        SSDc gx_
    overglcd :
    Thanks a lot guys 👍
    I'll give it a try this week-end.
    And thanks Richard for condensing the information here
    Roger
    Only garbage at this time...but it's alive
    Roger
    Seems that the character size is too big to fit there..
    ...still struggeling with the ssd1306's datasheet to understand the "page" concept and how to display things.
    This is the simplest and shortest code I'm working with for now, composed of different sources I found in this forum and also on ARDUINO's one:
    ' ====== DESCRIPTION ===============================================================================
    ' Use mini OLED 72x40 pixel display
    ' PIC 16F690 Fuses
    ' Internal oscillator  (activate OSCCON register)
    @ __config _FCMEN_OFF &_IESO_OFF &_CPD_OFF &_WDT_OFF &_INTRC_OSC_NOCLKOUT &_BOR_OFF &_CP_OFF &_PWRTE_OFF &_MCLRE_OFF
    @ ERRORLEVEL -306
    @ ERRORLEVEL -202
    '             76543210
    OPTION_REG = %10000000 'PORT A&B Pull-Ups disabled (see WPUA & WPUB)
    OSCCON     = %01100000 'Internal RC set to 4MHZ
    'ANSEL      = %00000000 'Select analog inputs Channels 0 to 7 (AN2 + AN4 selected)
    'ANSELH     = %00000000 'Select analog inputs Channels 8 to 11
    'ADCON0     = %10000000 'A/D Module (Bit5:2 select channels 0:11)
    'ADCON1     = %00000000 'A/D control register
    'CM1CON0    = %00000000 'Comparator1 Module is OFF
    'CM2CON0    = %00000000 'Comparator2 Module is OFF
    'INTCON     = %00000000 'INTerrupts CONtrol (TMR0 OFF)
    'TRISA      = %00000000 'Set Input/Output (0 to 5)
    'PORTA      = %00000000 'Ports High/Low (0 to 5)
    'TRISB      = %00000000 'Set Input/Output (4 to 7)
    'PORTB      = %00000000 'Ports High/Low (4 to 7)
    'TRISC      = %00000000 'Set Input/Output (0 to 7)
    'PORTC      = %00000000 'Ports High/Low (0 to 7)
    'DEFINE NO_CLRWDT 1   'Don't waste cycles clearing WDT
    'DEFINE HSER_CLOERR 1 'Automatic clear overrun error
    ' ====== VARIABLES =================================================================================
    I2CDevice   var byte
    SDA         VAR PORTB.4 ' I2C Data
    SCL         VAR PORTB.6 ' I2C Clock
    TEXT        VAR BYTE[20]
    LENGTH      VAR BYTE[2]
    DC          VAR Byte    ' "DATA OR COMMAND", $40=DATA; $0=COMMAND --> changed from bit to byte
    LCD_DATA    VAR BYTE
    COM         VAR BYTE    ' COMMAND
    I           VAR BYTE
    J           VAR BYTE
    X           VAR BYTE  'LCD POSITION X(0 TO 127)
    Y           VAR BYTE  'LCD POSITION Y(0 TO 7)
    ' ====== INITIALIZE VARIABLES ======================================================================
    I2CDevice = $78
    '======= SSD1306 I2C OLED initialization ===========================================================
    COM = $AE : GOSUB SEND_COMMAND ' turn off oled panel
    COM = $D5 : GOSUB SEND_COMMAND ' set display clock divide ratio/oscillator frequency
    COM = $80 : GOSUB SEND_COMMAND ' set divide ratio
    COM = $A8 : GOSUB SEND_COMMAND ' set multiplex ratio
    COM = $27 : GOSUB SEND_COMMAND ' 1/40 duty
    COM = $D3 : GOSUB SEND_COMMAND ' set display offset
    COM = $00 : GOSUB SEND_COMMAND ' not offset
    COM = $AD : GOSUB SEND_COMMAND ' Internal IREF Setting
    COM = $30 : GOSUB SEND_COMMAND ' --
    COM = $8D : GOSUB SEND_COMMAND ' set Charge Pump enable/disable
    COM = $14 : GOSUB SEND_COMMAND ' set(0x10) disable
    COM = $40 : GOSUB SEND_COMMAND ' set start line address
    COM = $A6 : GOSUB SEND_COMMAND ' set normal display
    COM = $A4 : GOSUB SEND_COMMAND ' Disable Entire Display On
    COM = $A1 : GOSUB SEND_COMMAND ' set segment re-map 128 to 0
    COM = $C8 : GOSUB SEND_COMMAND ' Set COM Output Scan Direction 64 to 0
    COM = $DA : GOSUB SEND_COMMAND ' set com pins hardware configuration
    COM = $12 : GOSUB SEND_COMMAND '
    COM = $81 : GOSUB SEND_COMMAND ' set contrast control register
    COM = $AF : GOSUB SEND_COMMAND '
    COM = $D9 : GOSUB SEND_COMMAND ' set pre-charge period
    COM = $22 : GOSUB SEND_COMMAND '
    COM = $DB : GOSUB SEND_COMMAND ' set vcomh
    COM = $20 : GOSUB SEND_COMMAND '
    COM = $AF : GOSUB SEND_COMMAND ' turn on oled panel
    ' ====== PROGRAM ===================================================================================
    PAUSE 20
    GOSUB CLEAR_LCD
    GOSUB TITLE
    MAIN:
        PAUSE 1000
        GOTO MAIN
    ' ====== CLEAR LCD =================================================================================
    CLEAR_LCD:
        FOR J = 0 TO 7
            FOR I = 0 TO 71 '127
                LCD_DATA = $00 : GOSUB SEND_DATA
            NEXT I
        NEXT J
    ' ====== SEND COMMAND ==============================================================================
    SEND_COMMAND:
        dc = $0
        I2CWrite SDA,SCL,I2CDevice,DC,[COM]
        dc = $40
    SEND_DATA:
        DC = $40
        I2CWrite SDA,SCL,I2CDevice,DC,[LCD_DATA]
    ' ====== SEND DATA =================================================================================
    FILL:
        FOR J = 0 TO 7
                LCD_DATA = $FF : GOSUB SEND_DATA
            NEXT I
        NEXT J
    ' ====== TITLE =====================================================================================
    TITLE:
        X = 0 : Y = 0 : GOSUB SET_XY
            LOOKUP I,[$00,$40,$60,$50,$7E,$50,$60,$40,$02,$06,$0E,$1E,$3E,$00,$00,$00,_
            $00,$00,$00,$00,$00,$1F,$3F,$60,$60,$60,$60,$60,$60,$3C,$1C,$00,_
            $00,$7F,$7F,$61,$61,$61,$61,$61,$61,$3F,$1E,$00,$00,$1E,$3F,$61,_
            $61,$61,$61,$61,$61,$38,$18,$00,$00,$00,$00,$00,$00,$00,$00,$00,_
            $00,$00,$00,$00,$00,$00,$00,$1F,$3F,$60,$60,$60,$60,$60,$60,$3C,_
            $1C,$00,$00,$1E,$3F,$61,$61,$61,$61,$61,$61,$38,$18,$00,$00,$3F,_
            $7F,$60,$18,$06,$06,$18,$60,$7F,$3F,$00,$00,$00,$00,$00,$00,$00,_
            $00,$00,$00,$1C,$63,$41,$5D,$41,$5D,$41,$5D,$41,$5D,$41,$7F,$00],LCD_DATA
            lcd_data = lcd_data rev 8
            GOSUB SEND_DATA
        NEXT I
        X = 0 : Y = 1 : GOSUB SET_XY
        for i = 0 to 71 '127
            lookup i,[$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,_
            $00,$00,$00,$00,$00,$F8,$FC,$06,$06,$06,$C6,$C6,$C6,$FC,$F8,$00,_
            $00,$FE,$FE,$80,$80,$80,$80,$80,$80,$00,$00,$00,$00,$18,$1C,$86,_
            $86,$86,$86,$86,$86,$FC,$78,$00,$00,$00,$00,$00,$00,$00,$00,$00,_
            $00,$00,$00,$00,$00,$00,$00,$F8,$FC,$06,$06,$06,$C6,$C6,$C6,$FC,_
            $F8,$00,$00,$18,$1C,$86,$86,$86,$86,$86,$86,$FC,$78,$00,$00,$FE,_
            $FE,$00,$00,$00,$00,$00,$00,$FE,$FE,$00,$00,$00,$00,$00,$00,$00,_
            $00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00],lcd_data
            lcd_data=lcd_data rev 8
            GOSUB SEND_DATA
        NEXT I
        X = 0 : Y = 3 : GOSUB SET_XY
            lookup i,[$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$3C,$7E,$C3,$C3,$C3,$C3,_
            $C3,$C3,$71,$30,$00,$00,$7F,$FF,$C3,$C3,$C3,$C3,$C3,$C3,$C3,$C3,_
            $00,$00,$7F,$FF,$C1,$C1,$C1,$C1,$C1,$C1,$FF,$7F,$00,$00,$7F,$FF,_
            $C3,$C3,$C3,$C3,$C3,$C3,$7E,$3C,$00,$00,$3F,$7F,$C0,$C0,$C0,$C0,_
            $C0,$C0,$70,$30,$00,$00,$FF,$FF,$03,$03,$03,$03,$03,$03,$FF,$FF,_
            $00,$00,$C0,$C0,$C0,$C0,$FF,$FF,$C0,$C0,$C0,$C0,$00,$00,$FF,$FF,_
            $0C,$0C,$03,$03,$00,$00,$FF,$FF,$00,$00,$3F,$7F,$C0,$C0,$C0,$C1,_
            $C1,$C1,$79,$39,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00],lcd_data
            GOSUB SEND_DATA
        NEXT I
        X = 0 : Y = 4 : GOSUB SET_XY
            lookup i,[$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$30,$38,$0C,$0C,$0C,$0C,_
            $0C,$0C,$F8,$F0,$00,$00,$F8,$FC,$0C,$0C,$0C,$0C,$0C,$0C,$0C,$0C,_
            $00,$00,$FC,$FC,$80,$80,$80,$80,$80,$80,$FC,$FC,$00,$00,$FC,$FC,_
            $80,$C0,$60,$30,$18,$0C,$04,$00,$00,$00,$F0,$F8,$0C,$0C,$0C,$0C,_
            $0C,$0C,$38,$30,$00,$00,$FC,$FC,$00,$00,$00,$00,$00,$00,$FC,$FC,_
            $00,$00,$0C,$0C,$0C,$0C,$FC,$FC,$0C,$0C,$0C,$0C,$00,$00,$FC,$FC,_
            $00,$00,$00,$00,$C0,$C0,$FC,$FC,$00,$00,$F0,$F8,$0C,$0C,$0C,$8C,_
            $8C,$8C,$F8,$F0,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00],lcd_data
            GOSUB SEND_DATA
        NEXT I
        X = 0 : Y = 5 : GOSUB SET_XY
            lookup i,[$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$1F,$3F,$30,$30,$30,$30,_
            $30,$30,$30,$30,$00,$00,$0F,$1F,$30,$30,$30,$30,$30,$30,$1F,$0F,_
            $00,$00,$1F,$3F,$30,$30,$30,$30,$30,$30,$1F,$0F,$00,$00,$00,$00,_
            $00,$00,$00,$0F,$1F,$30,$30,$30,$30,$30,$30,$1C,$0C,$00,$00,$30,_
            $30,$30,$30,$3F,$3F,$30,$30,$30,$30,$00,$00,$0F,$1F,$30,$30,$30,_
            $30,$30,$30,$1E,$0E,$00,$00,$3F,$3F,$03,$03,$00,$00,$00,$00,$3F,_
            $3F,$00,$00,$1F,$3F,$30,$30,$30,$30,$30,$30,$3F,$1F,$00,$00,$3F,_
            $3F,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00],lcd_data
            GOSUB SEND_DATA
        NEXT I
        X = 0 : Y = 6 : GOSUB SET_XY
            lookup i,[$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$FF,$FF,$C0,$C0,$C0,$C0,_
            $C0,$C0,$00,$00,$00,$00,$FC,$FE,$03,$03,$03,$03,$03,$03,$FE,$FC,_
            $00,$00,$FF,$FF,$E0,$F0,$D8,$CC,$C6,$C3,$81,$00,$00,$00,$00,$00,_
            $00,$00,$00,$0C,$8E,$C3,$C3,$C3,$C3,$C3,$C3,$7E,$3C,$00,$00,$03,_
            $03,$03,$03,$FF,$FF,$03,$03,$03,$03,$00,$00,$FC,$FE,$03,$03,$03,_
            $63,$63,$63,$7E,$7C,$00,$00,$FF,$FF,$00,$00,$C0,$C0,$30,$30,$FF,_
            $FF,$00,$00,$FF,$FF,$60,$60,$60,$60,$60,$60,$FF,$FF,$00,$00,$FF,_
            $FF,$03,$03,$03,$03,$03,$03,$03,$03,$00,$00,$00,$00,$00,$00,$00],lcd_data
            GOSUB SEND_DATA
        NEXT I
    '======= SET_XY ====================================================================================
    SET_XY:
        COM = $21 : GOSUB SEND_COMMAND
        COM = X   : GOSUB SEND_COMMAND
        COM = 71  : GOSUB SEND_COMMAND
        COM = Y   : GOSUB SEND_COMMAND
        COM = 41  : GOSUB SEND_COMMAND
    Originally, this code is made for a larger display so I need to adapt it.
    Roger
    Is it worth it the effort to spend much time on this LCD's?
    It tried it and seems a lot of waste of time. Also too small for my age
    Up to now, I couldn't find any pixel map for the 72x40 display so I'm relying on information for the 128x64 one.
    This is the information I have found in the 72x40 datasheet:
    Can anybody tell me how I should convert this in "pages" if I have to do so? I don't understand how data has to be displayed...
    This is the example from the 128x64's datasheet (to be found in attachment):
    Roger
    Some comments
    is the display 72x40 of 42x40 ? you describe it both ways
    the write window should be set to width and page height you require and the pixel/page offset to begin write from for proper operation
    and
    with your attempted title page transmission, sending every byte of data like that as individual senddata transactions is extremely inefficient the entire thing could be sent as a single data block in half the time
     ====== DESCRIPTION ===============================================================================' Use mini OLED 72x40 pixel display
    ' PIC 16F690 Fuses
    @ ERRORLEVEL -306
    @ ERRORLEVEL -202
    '             76543210
    OPTION_REG = 000000 'PORT A&B Pull-Ups disabled (see WPUA & WPUB)
    OSCCON     = 100000 'Internal RC set to 4MHZ
    'ANSEL      = 000000 'Select analog inputs Channels 0 to 7 (AN2 + AN4 selected)
    'ANSELH     = 000000 'Select analog inputs Channels 8 to 11
    'ADCON0     = 000000 'A/D Module (Bit5:2 select channels 0:11)
    'ADCON1     = 000000 'A/D control register
    'CM1CON0    = 000000 'Comparator1 Module is OFF
    'CM2CON0    = 000000 'Comparator2 Module is OFF
    'INTCON     = 000000 'INTerrupts CONtrol (TMR0 OFF)
    'TRISA      = 000000 'Set Input/Output (0 to 5)
    'PORTA      = 000000 'Ports High/Low (0 to 5)
    'TRISB      = 000000 'Set Input/Output (4 to 7)
    'PORTB      = 000000 'Ports High/Low (4 to 7)
    'TRISC      = 000000 'Set Input/Output (0 to 7)
    'PORTC      = 000000 'Ports High/Low (0 to 7)
    I2CDevice   var byte
    TEXT        VAR BYTE[20]
    LENGTH      VAR BYTE[2]
    ;seems a pointless waste if a variable
    LCD_DATA    VAR BYTE
    I           VAR BYTE
    J           VAR BYTE
    I2CDevice = $78
    ; you assume display is mapped from page 0  , this may not be correct ans could be  0,1,2,3
    PAUSE 20
    GOSUB CLEAR_LCD
    GOSUB TITLE
    MAIN:
        PAUSE 1000
        GOTO MAIN
    CLEAR_LCD:
        FOR J = 0 TO 7
            NEXT I
        NEXT J
    ;  cant see this working without setting a "window" to write into properly
    SEND_COMMAND:
        dc = $0
        dc = $40
    ; why not just
    SEND_COMMAND:
    I2CWrite SDA,SCL,I2CDevice,[0,COM]
    SEND_DATA:
        DC = $40
     ; why not just
    SEND_COMMAND:
    I2CWrite SDA,SCL,I2CDevice,[$40,LCD_DATA]
    FILL:
        FOR J = 0 TO 7
            NEXT I
        NEXT J
    ;here you set 6 pages "Y" of data from page 0 to 7  with page 2 missing when a 40 pixel height can have 5 pages maximum
    TITLE:
            GOSUB SEND_DATA
        NEXT I
            GOSUB SEND_DATA
        NEXT I
            GOSUB SEND_DATA
        NEXT I
            GOSUB SEND_DATA
        NEXT I
            GOSUB SEND_DATA
        NEXT I
            GOSUB SEND_DATA
        NEXT I
    SET_XY:
    ;attempt to set page to 41 when it cannot be > than 5 pages
    It's definitively a 72x40 pixel display.
    Thanks Richard for pointing to all changes (and tips) I can/should make in the code
    Now, regarding the way to display data, I still don't get it; I'm completely lost since I have no clue how to do it.
    I'm mostly using serial "common" LCDs in text mode so I don't have to create any font or so.
    In my case, I will use this LCD to display, as big as possible, a number as a percentage (0.0%...99.9%).
    What is the approach? I have a display 72 pixels wide and 40 pixels high (= 2'880 pixels). I assume, the display is divided in what they call "pages" and I should write a data table (LOOKUP) for each page. Is this correct?
    But how do I address the pages? Do I have to do so? Is there a way to send "text" to the display like common LCDs? Is there a way to "design" a font that will in big appear all over the entire display?
    I'm missing fundamentals 😔
    Roger
    Basically the display is 360 bytes of ram where every bit is a oled, the ram is divided into 5 pages each of 72 bytes
    the 5 pages are overlaid onto a larger array that is 8 pages of 128 bytes, precisely where is not known to me [i have never seen one of those modules]
    the ssd1306 is very versatile and allows vertical and horiz offsets to be set along with scan direction and various mem access methods to suit you.
    to write to a byte you must address its x and y position , the width to be written and number of pages is also expected to be set
    ie to write a 10x14 chr 14 high 10 wide at page 1 posn 12
    SET_XY:
    COM = 12 : GOSUB SEND_COMMAND ;x=12
    COM = 22 : GOSUB SEND_COMMAND ;12+10
    COM = 1 : GOSUB SEND_COMMAND ;y=1
    COM = 2 : GOSUB SEND_COMMAND ;1+1
    then send the 20 bytes needed to represent your chr
    easy you need to create a big font with the chrs you need in it
    no not even close
    if you want easy use a pic18 and my code from here
    where you can define the screen size and create fonts as you need
    or use an enhanced core pic16 and my earlier code that can do double size chrs
    Thanks a lot Richard.
    The fog lifts somehow a little bit....
    I'll give it a try with y 18F 👍
    Roger
    is this more clear ?
    draws a 7x5 chr A and 14x10 A in a 72x40 window located @ x=0y=0 after clearing screen [ outside of window is just random noise ]
    here's a pic on a 128x64 screen , there is no telling how it line up for your screen
    #CONFIG __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_OFF & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOD_ON & _IESO_ON & _FCMEN_ON
    define OSC 8
    OSCCON = 110000 'Internal RC set to 8MHZ
    ' ====== VARIABLES ================================================== ===============================
    I2CDevice var byte
    SDA VAR PORTB.6 ' I2C Data
    SCL VAR PORTB.4 ' I2C Clock
    LCD_DATA VAR BYTE
    I VAR BYTE
    J VAR BYTE
    ' ====== INITIALIZE VARIABLES ================================================== ====================
    I2CDevice = $78
    '======= SSD1306 I2C OLED initialization ================================================== =========
    COM = $3F : GOSUB SEND_COMMAND ' 1/40 duty
    COM = $0 : GOSUB SEND_COMMAND
    COM = $7F : GOSUB SEND_COMMAND '
    ' ====== PROGRAM ================================================== =================================
    GOSUB CLEAR_LCD
    MAIN:
    ;7x5 "A"
    X = 15 : Y = 0 : GOSUB SET_7
    I2CWrite SDA,SCL,I2CDevice,[$40,$fc,$12,$12,$12,$fc]
    ;14x10 "A"
    X = 15 : Y = 2 : GOSUB SET_14
    I2CWrite SDA,SCL,I2CDevice,[$40,$f0,$f8,12,12,14,14,12,12,$f8,$f0_
    ,$ff,$ff,6,6,6,6,6,6,$ff,$ff]
    PAUSE 1000
    GOTO MAIN
    ' ====== CLEAR LCD ================================================== ===============================
    CLEAR_LCD:
    COM = 0 : GOSUB SEND_COMMAND
    COM = 4 : GOSUB SEND_COMMAND
    LCD_DATA = $00
    FOR J = 0 TO 4
    FOR I = 0 TO 71
    NEXT I
    NEXT J
    ' ====== SEND COMMAND ================================================== ============================
    SEND_COMMAND:
    '======= SET_XY ================================================== ==================================
    SET_7: '7x5
    COM = x+4 : GOSUB SEND_COMMAND
    COM = y : GOSUB SEND_COMMAND
    SET_14: ;14x10
    COM = x+9 : GOSUB SEND_COMMAND
    COM = y+1 : GOSUB SEND_COMMAND
    I'll give it a try asap
    Roger
    Voilą.
    As no caracter would display, I changed the fill caracter in the CLEAR routine to make someting visible.
    CLEAR_LCD:
        COM = $21 : GOSUB SEND_COMMAND ' set column address
        COM = 0   : GOSUB SEND_COMMAND ' column start address
        COM = 71  : GOSUB SEND_COMMAND ' column end address
        COM = $22 : GOSUB SEND_COMMAND ' set page address
        COM = 0   : GOSUB SEND_COMMAND ' page start address
        COM = 4   : GOSUB SEND_COMMAND ' page end address
        FOR J = 0 TO 4
            FOR I = 0 TO 71
                I2CWrite SDA,SCL,I2CDevice,[$40,$FF]
            NEXT I
        NEXT J
    Roger
    BTW, the number of pixels displayed is 50x20
    Name:  OLED detail.png
    Roger
    are you using my exact code ?
    there are many changes from your orig code including swapping over the scl/sda pins to suit my dev board
    i doubt the pullup resistors are needed most modules have then already installed
    change
    to
    COM = $67 : GOSUB SEND_COMMAND ' set start line address
    it looks like display is mapped onto last 5 pages of ram array
    Default Re: SSD1306 OLED (72x40) I2C display from scratch
    Are you using my exact code ?
    Absolutely!
    With this "untouched" code, I get this display:
    Then, with the new value of $67, here is what I get:
    Roger
    try this, looking for full white screen
    re pull up resistors for i2c bus , looking at the pic in post #1 that module has none on board , every other module i can find on ebay etc has resistors on board
    so you might need them after all
    define OSC 8
    OSCCON = 10000 'Internal RC set to 8MHZ
    I2CDevice var byte
    LCD_DATA VAR BYTE
    I VAR BYTE
    J VAR BYTE
    I2CDevice = $78
    COM = $68 : GOSUB SEND_COMMAND ' set start line address
    GOSUB CLEAR_LCD
    MAIN:
    ';7x5 "A"
    'X = 15 : Y = 0 : GOSUB SET_7
    'I2CWrite SDA,SCL,I2CDevice,[$40,$fc,$12,$12,$12,$fc]
    ';14x10 "A"
    'X = 15 : Y = 2 : GOSUB SET_14
    'I2CWrite SDA,SCL,I2CDevice,[$40,$f0,$f8,12,12,14,14,12,12,$f8,$f0_
    ',$ff,$ff,6,6,6,6,6,6,$ff,$ff]
    PAUSE 1000
    GOTO MAIN
    CLEAR_LCD:
    COM = 20 : GOSUB SEND_COMMAND
    COM = 91 : GOSUB SEND_COMMAND
    LCD_DATA = $ff
    FOR J = 0 TO 4
    FOR I = 0 TO 71
    NEXT I
    NEXT J
    SEND_COMMAND:
    SET_7: '7x5
    SET_14: ;14x10
    Thanks Richard.
    This it looks now, with your code ni post #26.
    https://drive.google.com/file/d/1Ud4...usp=drive_link
    Roger
    These few changes will fill the whole screen in white.
    CLEAR_LCD:
    COM = 28 : GOSUB SEND_COMMAND
    COM = 99 : GOSUB SEND_COMMAND '91
    LCD_DATA = $ff
    FOR J = 0 TO 4
    FOR I = 28 TO 99
    NEXT I
    NEXT J
    ok, then this should be pretty close
    define OSC 8
    OSCCON = %01110000 'Internal RC set to 8MHZ
    I2CDevice var byte
    LCD_DATA VAR BYTE
    I VAR BYTE
    J VAR BYTE
    hshift con 28
    I2CDevice = $78
    GOSUB CLEAR_LCD
    MAIN:
    ;7x5 "A"
    ;14x10 "A"
    PAUSE 1000
    GOTO MAIN
    CLEAR_LCD:
    COM = hshift : GOSUB SEND_COMMAND
    COM = 71 + hshift : GOSUB SEND_COMMAND
    LCD_DATA = 0
    FOR J = 0 TO 4
    FOR I = 0 TO 71
    NEXT I
    NEXT J
    SEND_COMMAND:
    SET_7: '7x5
    COM = X+hshift : GOSUB SEND_COMMAND
    COM = x+hshift+4 : GOSUB SEND_COMMAND
    SET_14: ;14x10
    COM = X+hshift: GOSUB SEND_COMMAND
    COM = x+hshift+9 : GOSUB SEND_COMMAND
    the google drive link is a dud
    I also adjusted your code as:
    GOSUB CLEAR_LCD
    MAIN:
        '7x5 "A"
        X = 28 : Y = 0 : GOSUB SET_7
        '14x10 "A"
        X = 28 : Y = 2 : GOSUB SET_14
        PAUSE 1000
        GOTO MAIN
    Name:  WhatsApp Image 2023-11-24 at 23.38.15.jpeg
    Roger
    Sorry for that.
    How do I post a small video then?
    Roger
    Roger
    link worked.
    all you need to do now is
    1 create a 14x10 font with the chrs you need
    2 workout an efficient way to store and retrieve the font
    3 develop a nice way to plonk it on the screen
    easy as pie
    ps
    if you only need numbers and "%" ,"." it could fit on a 16f690 easily
    hint , pic16 flash memory is 14 bits wide, the ssd1306 can fill memory in vertical mode too
    Thank you so much Richard!!!
    I'll give it a try to create a super big font.
    Let you know for any progress in the next days
    Roger
    First look at what it could look like
    Roger
    It looks great!
    Well done Roger!
    ...credits are all for Richard
    Roger
    something to consider about fonts
    it looks like you want 40x22 size font
    a pic16 has a flash word size of 14 bits therefore a font that size
    will take if encoded horizontally by row take 2x40 words per chr
    it will take 3x22 words if encoded vertically by column a reasonable saving.
    one of the benefits of the ssd1306 controller is that it can address its graphics ram either way with ease
    Richard,
    I'm still trying to understand your previous post but just for now, there's a question burning my mind: how do I address the display pixel by pixel?
    Roger
  1. big char oled display
    By mombasa in forum mel PIC BASIC Pro
    Last Post: - 19th September 2020, 08:02
  2. SSD1306 start display problem
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 14th December 2016, 20:16
  3. Cannot drive I2C Oled :(
    By elcrcp in forum mel PIC BASIC Pro
    Last Post: - 20th August 2016, 13:19
  4. OLED Display Noise problem
    By gunayburak in forum mel PIC BASIC Pro
    Last Post: - 5th July 2016, 11:15
  5. Help With OLED Display / 128X64 SSD1306
    By Denner in forum General
    Last Post: - 25th May 2013, 16:40
