SSD1306 OLED (72x40) I2C display from scratch
+ Reply to Thread
Results 1 to 40 of 74
    Default Re: SSD1306 OLED starts up 10 times out of 11 or so
    For any reason, my OLED module won't start up once out of ten or twenty times.
    I have no clue why.
    Since the module you are using has no provision made for the user to be able to reset it you are totally dependent on how the on board POR circuitry applies the reset signal. The board will have a very definite absolute minimum off period and minimum on time before a successful reset will occur. If you don't adhere to those times then its matters not what you code is trying to do the chip won't necessarily be receptive. If your code still does not work reliably after suitable POR conditions have been met then you code is incorrect. Simply resetting your pic is not enough.
    The data sheet gives no clue re command execution time or even if i2c clock stretching is in play, anecdotally there is some support for a small delay after executing an $ae command being beneficial
  1. big char oled display
    By mombasa in forum mel PIC BASIC Pro
    Last Post: - 19th September 2020, 08:02
  2. SSD1306 start display problem
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 14th December 2016, 20:16
  3. Cannot drive I2C Oled :(
    By elcrcp in forum mel PIC BASIC Pro
    Last Post: - 20th August 2016, 13:19
  4. OLED Display Noise problem
    By gunayburak in forum mel PIC BASIC Pro
    Last Post: - 5th July 2016, 11:15
  5. Help With OLED Display / 128X64 SSD1306
    By Denner in forum General
    Last Post: - 25th May 2013, 16:40
Members who have read this thread : 18
