GOTO statement causing jitter in output frequency, can be this fixed?
Results 1 to 7 of 7
    Default Re: GOTO statement causing jitter in output frequency, can be this fixed?
    No it is not obvious, because it takes DIFFERENT times on each iteration of GOTO statement.
    Aug 2011
    If you reduce the timebase of your analyzer so you can capture an entire set of the FOR-NEXT loop, you'll see that it's not jitter but the increased time when the FOR-NEXT loop exits and the GOTO loop occurs. You have a few extra cycles there to do the GOTO and the exit/initialization of the FOR-NEXT loop so every 16 iterations you get a small gap.
    The code I posted takes advantage of the fact that incrementing a byte from 255 just rolls over to 0, so it has the same effect as your FOR x=0 to 15 loop without the extra loop involved.
    Obviously, your pic can't do anything else but this, otherwise the timing will change. Your other option would be to setup a timer and do this in an interrupt routine but you won't be able to get exact timing with that since there can be a slight difference in the timing of when the ISR runs.
    And since the four pins are on the same port you could do away with the individual RMW-instructions for each pin and just do
    x = 0
    masfrk:
      PortC = x
      x = x + 16
      pauseus 194
    goto masfrk
    Or even
    PortC = 0
    masfrk:
      PortC = PortC + 16
      pauseus 194
    goto masfrk
    Obviously this will cause the bottom 4 bits of PortC to be 0 but it doesn't look like you're using those for anything.
  1. Depending on value, SOUND statement leaves port output high
    Last Post: - 5th October 2023, 13:05
  2. Replies: 3
    Last Post: - 14th October 2016, 23:07
  3. frequency meter output
    Last Post: - 26th August 2015, 11:20
  4. Replies: 10
    Last Post: - 30th November 2009, 16:58
  5. Unwanted output signal jitter
    By LinkMTech in forum mel PIC BASIC Pro
    Last Post: - 18th January 2008, 03:31
