Depending on value, SOUND statement leaves port output high
Results 1 to 5 of 5
    Aug 2011
    Default Re: Depending on value, SOUND statement leaves port output high
    I think it's just the way it works, and probably depends on the timing since SOUND just toggles the IO pin to produce the output.
    The manual shows using an inline capacitor to block the DC output.
    Or if you do not want to use a capacitor, being brave enough, after the command use LOW to drive the pin at zero level.
    I guess that "feature" worth mentioning in manual
    Well, it shows a capacitor. So, you have to use a capacitor. It is that simple...
  1. Replies: 11
    Last Post: - 19th June 2014, 10:00
  2. Replies: 11
    Last Post: - 13th January 2013, 10:25
  3. Replies: 5
    Last Post: - 17th May 2012, 10:14
  4. 16F883 and Problems with HIGH statement
    By aaanekre in forum mel PIC BASIC Pro
    Last Post: - 29th October 2009, 01:09
  5. Duplicating port input to port output
    By lwindridge in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 21:43
