Can't find my .hex file - timestamps confusing?
Results 1 to 6 of 6
    Mar 2023
    Cape Town, South Africa
    Default Can't find my .hex file - timestamps confusing?
    I wonder if I am going nuts or if others experience this too . . . . . . .
    MCSX 5.0.0.5 If I compile a program at 9.00am I easily find the hex file with the timestamp of 9.00am. But then, compiling the same program, with same name, at 9.30am does not give me a new hex with a 9.30 timestamp. Even if I delete the previous hex first. If I then search my PC for *.hex I cannot find a new one at 9.30.
    MCSX runs this little window successfully and quickly every time:
    Some days it works, some days it doesn't, and I can't see the reason it changes from day to day.
    Any help appreciated, thanks
    Default Re: Can't find my .hex file - timestamps confusing?
    Are you saving the source file on your local C: disk or on a flash disk, Dropbox, OneDrive or Google drive?
    Once I had similar issues with external drives.
    Mar 2023
    Hi, sometimes Dropbox and sometimes C:
    That might explain my erratic problem. Will be back at my desk on the weekend to try again.
    Mar 2023
    My .pbp file is in a Dropbox folder. The first .hex I make on a day also goes to that Dropbox folder. Any subsequent .hex goes to the Documents > PBP3 > EXAMPLES folder. Newer saves of the .pbp stay in the Dropbox folder as expected. But the .hex goes wandering off through the day. Weird, but I can live with it.
    I also use the dropbox but have no such issue.
    Just, from time to time, it needs more time to update the dorpbox folder and seems that MCS does not have accesss to the folder. I just recompile and the problem goes away.
    I noticed that microcode studio changes timestamp of the files whenever you open them, even if you have not made any change to it or compiled it.
  1. Can't seem to find DT's Ansi.INC file
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 20th February 2014, 02:47
  2. Where can I find the PIC18 .INC file for device definitions?
    By LinkMTech in forum mel PIC BASIC Pro
    Last Post: - 6th December 2010, 01:46
  3. can't find include file!
    By jimbostlawrence in forum mel PIC BASIC Pro
    Last Post: - 10th November 2009, 09:44
  4. convert .HEX file to .ASM or .BAS file ???
    By iugmoh in forum General
    Last Post: - 31st March 2008, 20:19
  5. MCSP - Cannot find include file
    By Andy Wood in forum mel PIC BASIC Pro
    Last Post: - 21st January 2008, 02:37
