Hello Unregistered ,
Originally Posted by Richards In your screenshot I can only see the "Default Path and Find Manually" of the PBP compiler and not, as you mentioned, path to the MPLABX assembler. I am not sure what you want to see in the path. You just select either manually or by default. You will not see the actual path. Ioannis
www.signalcom.gr
Forum Rules
