Using as many internal peripherals as possible.
Results 1 to 12 of 12
    Aug 2011
    Default Re: Using as many internal peripherals as possible.
    bsf Switch                       ; set bit in Switch to 1
    Among other things...
    - that's not the form of an asm 'bsf' instruction
    - you may have issues with the proper bank being selected... you are specifying 'banksel IOCAF', but where is 'Switch' located?
    When writing asm it will do exactly what you specify... correct or not.
    Where is the problem?
    Good luck trying to get pbp to set a bit var where you need it be
    use a byte and place it in access space if you have to
    enabling the timer1 interrupt and not servicing it will not work well
    #CONFIG  __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_ON & _FCMEN_ON
      __config _CONFIG2, _WRT_OFF & _PLLEN_ON & _STVREN_ON & _BORV_19 & _LVP_OFF
    DEFINE INTHAND INT
    DEFINE NO_CLRWDT 1
    OSCCON = %01101010
    TRISA   =    %011000   ; RA4 input for battery measurement, RA3 input on change, rest output
    ANSELA  =    0     ; ADC Disable
    OPTION_REG = %10000111 ; Disable internal pull-ups, TMR0 On, prescaller to 256
    FVRCON  =    %10011000 ; Internal reference to 2048mV
    CM1CON0 =    %10100110 ; Comparator output to C1OUT, switch on LED if voltage is below ref. 2,048V
    CM1CON1 =    %00100001 ; C1IN1- pin is RA4, comparator voltage input, C1IN1+ positive input to FVR set to 2,048V
    LATA    =    %000001   ; init state of pin RA0 and RA1, LEDs connected to these pins
    T1CON = %00110001      ; TMR1 On, prescaller 1:8, Fosc/4
    INTCON = %11001000     ; Enable GIE, PEIE, IOCIE
    PIE1.0 = 0             ; DISable TMR1IE OVerflow interrupt
    IOCAN.3 = 1            ; Enable RA3 negative edge OnChange interrupt
    Switch var BYTE  $7f  SYSTEM
     Switch = 0
    ; ------------  With TMR1 and interrupt, oscilator 4MHz ---------------
    if porta.3=0  and switch=1 then
    LATA = LATA ^ %100000
    pressed:
    pause 20
    if porta.3=0 then pressed   ; if the button is still pressed loop and wait for release
    Switch=0
     asm
    INT
     banksel IOCAF
     btfsc IOCAF,3
     bsf Switch,0                      ; set bit0 in Switch to 1
     bcf IOCAF,3
     RETFIE
    endasm
  1. New cool PIC peripherals
    By HenrikOlsson in forum General
    Last Post: - 21st September 2016, 21:50
  2. Replies: 8
    Last Post: - 21st March 2015, 18:21
  3. Replies: 4
    Last Post: - 11th June 2014, 23:53
  4. Replies: 0
    Last Post: - 7th August 2008, 10:02
  5. Internal Oscillator
    By jhorsburgh in forum General
    Last Post: - 10th December 2007, 03:13
