Using as many internal peripherals as possible.
Results 1 to 12 of 12
Threaded View
  1. #9
    Default Re: Using as many internal peripherals as possible.
    What I trying. Omit PBP code from ASM interrupt routine.
    But this try not work, of course.
    Where is the problem?
      __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_ON & _FCMEN_ON
      __config _CONFIG2, _WRT_OFF & _PLLEN_ON & _STVREN_ON & _BORV_19 & _LVP_OFF
    DEFINE INTHAND INT
    DEFINE NO_CLRWDT 1
    OSCCON = %01101010
    TRISA   =    %011000   ; RA4 input for battery measurement, RA3 input on change, rest output
    ANSELA  =    %0000     ; ADC Disable
    OPTION_REG = %10000111 ; Disable internal pull-ups, TMR0 On, prescaller to 256
    FVRCON  =    %10011000 ; Internal reference to 2048mV
    CM1CON0 =    %10100110 ; Comparator output to C1OUT, switch on LED if voltage is below ref. 2,048V
    CM1CON1 =    %00100001 ; C1IN1- pin is RA4, comparator voltage input, C1IN1+ positive input to FVR set to 2,048V
    LATA    =    %000001   ; init state of pin RA0 and RA1, LEDs connected to these pins
    T1CON = %00110001      ; TMR1 On, prescaller 1:8, Fosc/4
    INTCON = %11001000     ; Enable GIE, PEIE, IOCIE
    PIE1.0 = 1             ; Enable TMR1IE Owerflow interrupt
    IOCAN.3 = 1            ; Enable RA3 negative edge OnChange interrupt
    Switch var bit SYSTEM : switch = 0
    ; ------------  With TMR1 and interrupt, oscilator 4MHz ---------------
    if porta.3=0 and switch=1 then
    LATA = LATA ^ %100000
    pressed:
    pause 20
    if porta.3=0 then pressed   ; if the button is still pressed loop and wait for release
    Switch=0
     asm
    INT
     banksel IOCAF
     btfsc IOCAF,3
     bsf Switch                       ; set bit in Switch to 1
     bcf IOCAF,3
     RETFIE
    endasm
  1. New cool PIC peripherals
    By HenrikOlsson in forum General
    Last Post: - 21st September 2016, 21:50
  2. Replies: 8
    Last Post: - 21st March 2015, 18:21
  3. Replies: 4
    Last Post: - 11th June 2014, 23:53
  4. Replies: 0
    Last Post: - 7th August 2008, 10:02
  5. Internal Oscillator
    By jhorsburgh in forum General
    Last Post: - 10th December 2007, 03:13
