no , you may appear to get away with inserting pbp statements in an ASM interrupt but it is a delusion.Is it ok to use interrupts like this?
pbp statements set many internal variables to enable complex statements to be evaluated , executing foreign statements from an isr will pollute this process. thats why dt-ints exists.
use asm code in asm interrupts like this
Code:#CONFIG __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_ON & _FCMEN_ON __config _CONFIG2, _WRT_OFF & _PLLEN_ON & _STVREN_ON & _BORV_19 & _LVP_OFF #ENDCONFIG DEFINE INTHAND myINT DEFINE NO_CLRWDT 1 DEFINE OSC 4 OSCCON = %01101010 TRISA = %011000 ; RA4 input for battery measurement, RA3 input on change, rest output ANSELA = %0000 ; ADC Disable OPTION_REG = %10000111 ; Disable internal pull-ups, TMR0 On, prescaller to 256 FVRCON = %10011000 ; Internal reference to 2048mV CM1CON0 = %10100110 ; Comparator output to C1OUT, switch on LED if voltage is below ref. 2,048V CM1CON1 = %00100001 ; C1IN1- pin is RA4, comparator voltage input, C1IN1+ positive input to FVR set to 2,048V LATA = %000001 ; init state of pin RA0 and RA1, LEDs connected to these pins T1CON = %00110001 ; TMR1 On, prescaller 1:8, Fosc/4 INTCON = %11001000 ; Enable GIE, PEIE, IOCIE PIE1.0 = 1 ; Enable TMR1IE Owerflow interrupt IOCAN.3 = 1 ; Enable RA3 negative edge OnChange interrupt ; ------------ With TMR1 and interrupt, oscilator 4MHz --------------- Main: ; pause 10000 ; some stuff here goto main ; ------------ INT Handler Routine --------------- asm myINT movlw 0 banksel PIR1 btfsc PIR1,0 movlw 3 bcf PIR1,0 banksel IOCAF btfsc IOCAF,3 iorlw 32 bcf IOCAF,3 banksel LATA xorwf LATA,f RETFIE endasm
