Tips and tricks
+ Reply to Thread
Results 1 to 7 of 7
Thread: Tips and tricks
    Default Re: Tips and tricks
    I think JLCPCB has saved our (engineering) life many times!!!
    I'm addicted now.
    Modular circuits; a CD jack on the right with a 7805 voltage regulator. I bought a bunch of breadboards over on amazon, so I just leave them on the breadboard and can quickly test something related with "power". Just make sure your pins are spaced like on your breadboards (2.54mm usually).
    Name:  Modular circuits.jpg
    Tip #1: I sacrificed my worst breadboard and use it to solder my modules. That way the header pins are always perfectly straight.
    Tip #2: Instead of using double-pins cause singles are annoying to hold (like on my DC jack module), use a full-length header but remove the unneeded pins (7805 module):
    Name:  Power modules.jpg
    Tip#3: you can determine where JLCPCB puts their order # on your PCB, just add JLCJLCJLCJLC wherever you want (see bottom of 7805 module above).
    Need drawer separators and are fed up with crappy cardboard?
    1mm plexi from amazon:
    https://www.amazon.ca/dp/B09XV459GR?th=1
    And get a cutter for plexi and a steel ruler; don't try with an exacto, they tend to wander a bit more.
    Now I wished I had fabricated a small cutting table last summer.
    Name:  drawer seperator.jpg
    The front one is an original.
    I use 100grit sandpaper to round out the bottom corners.
    Just be warned, the sheet isn't exactly 8x10in.
    Name:  Drawer separator results b.jpg
    Name:  Drawer separator results c.jpg
    I didn't measure first and started cutting. I could have gotten at least 31 separators of 1x2in, but I only got 27 cause I wasn't paying attention to cutting that last slice in the other direction.
    Name:  Drawer separator results a.jpg
    There's 1/6in plexi available to simulate the real separators, but it's a bit thicker to cut and I don't think it's worth it.
    1mm plexi only takes 3 good slices, bend and you get a clean break, then pass an exacto in the bend to slice off the other layer of protective film. At worse, take 4 slices if you don't want to press hard.
    I have a lot spare but you are too far away ...
    Nice job anyway!
  1. Microchip Tips ‘N Tricks Guide
    By Heckler in forum Documentation
    Last Post: - 6th January 2015, 05:24
  2. Microchip Tips n Tricks
    By tasmod in forum mel PIC BASIC Pro
    Last Post: - 19th April 2014, 08:09
  3. Microchip "Tips and Tricks" guide
    By Byte_Butcher in forum Documentation
    Last Post: - 30th January 2010, 11:38
  4. 3 Volts Design Tips and Tricks
    By sougata in forum Documentation
    Last Post: - 5th October 2009, 18:51
  5. Tricks for monitoring RX
    By JoelMurphy in forum Serial
    Last Post: - 28th March 2008, 00:16
Members who have read this thread : 8
