SHIFTOUT with PIC12F675?
Results 1 to 12 of 12
    Feb 2022
    Default Re: SHIFTOUT with PIC12F675?
    Ah?
    This unnderscore character has an influence for PBP?
    I usually used this character to identify my entries or outputs on the MCU!
    Feb 2022
    To come back to my original question about the SHIFTOUT command, here's the program I'm trying to run.
    Unfortunately, I've noticed that the SHIFTOUT command doesn't produce any signals on the SDA and SCK output ports!
    Any idea why?
    '*  Name     : Pulsin to TM1637.PBP                              *
    '*  Author   : RGL                                               *
    '*  Date     : 01/08/2023                                        *
    '*  Version  : 1.0                                               *
    '*  Compiler : PBPro 2.6                                        *
    '*  Notes    : 415 words used                                    *
    '*** PIC Pinouts/Specifications
    '             PIC 12F675
    '                 __ __
    '           Vcc +|  U  |- Gnd
    '        GPio.5  |     |  GPio.0
    '  Pulse GPio.4 >|     |> GPio.1 SDA (Data)
    '        GPio.3  |     |> GPio.2 SCK (Clock)
    @ Device Pic12F675, intrc_osc, wdt_off, pwrt_on, mclr_off, protect_off
    'DEFINE OSC 4    ' Pulsin/Pulsout Resolution    =10µsec    => 1ms=100   DEFAULT VALUE
    '   (Pulse Value of 1msec x10 =1000)    [x10]
    '  Pause =1msec => 1msec=1    1sec=1000
    Include "modedefs.bas"
    CMCON  = 7   'Comparator Off
    ANSEL  = 0   'Set Port to Digital i/o
    ADCON0 = 0   'All ADC Off
    'OSCCAL = $4C (344C placed manually in the hex file at 3FF address)
    Asm
     ;bsf STATUS      ;Bank 1
     call 3FFh       ;Get the CAL value from 3FF addresse YOU WRITE BEFORE !
     movwf OSCCAL    ;Calibrate
     ;bcf STATUS, RP0 ;Bank 0
    Endasm
    '*** In/Out pins ..................................................
     TRISIO = %010000    'GPIO.4 Input=1.  All other Output=0
     SDA    Var GPIO.0    'Serial Data pin
     SCK    Var GPIO.1    'Serial Clock pin
     Pulse   Var GPIO.4   'Pulsin pin
    '*** Variables/Constants
     CHR1 VAR BYTE             ;4 Byte to send
     CHR2 var Byte
     CHR3 var Byte
     CHR4 var Byte
     Value VAR WORD        ;Average Pulsin Value to display
     Measure VAR word        ;Intermediate and successives readings
     i  VAR BYTE        ;Working variable (20 successive measurements)
    ' TM1637 Commands
     ;CMD1 CON $40       'CMD1=$40 Write command Auto-increment Mode (Default Mode)
     CMD2 CON $C0       'CMD2=$C0 Start 1st digit position(left most = 1st digit)
     CMD3 CON $8C       'CMD3=$8A is the end command that turns the display ON and sets brightness to 69%
    ; Definition of the 10 characters in the EEPROM : 0-9 +Blank
    ; (Eeprom Starting address at 0)
    ; EEPROM(0   1   2   3   4   5   6   7   8   9   10 ) Pos10 = Blank
    DATA @0,$3F,$06,$5B,$4F,$66,$6D,$7D,$07,$7F,$6F,$00 ; Write to Eeprom
    '=== INIT TM1637 =====================================================
    Gosub StartSeq
     SHIFTOUT SDA, SCK, 0, [CMD3]      'SHIFTOUT brightness
    Gosub AckSeq
    gosub StopSeq
    '=== MAIN PROGRAM =====================================================
    MainLoop:
     Value = 0 : Measure = 0 'Initialize Value and Measure
      For i=1 to 20 '20 successive measurements for stabilisation of the display
        Pulsin Pulse,1,Measure
        Value = Value + Measure
      Next
      Value = Value /20                     ;Average PULSIN value
      Value = Value * 10                    ;Conversion to uS @4Mhz
    ;  Decomposition Method:
       CHR1 = Value / 1000
         If CHR1 = 0 then
          CHR1 = 10 'Blank Char.
         Else
          CHR1 = CHR1+$80 '+Decimal point
         Endif
       CHR2 = Value / 100 // 10
       CHR3 = Value / 10 // 10
       CHR4 = Value // 10
    'This sequence outputs now all 4 characters to the Display
    Gosub StartSeq   'SHIFTOUT Mode 0 - LSB First, Clock normally low
        SHIFTOUT SDA, SCK, 0, [CMD2]    '1st Digit Adrress
     Gosub AckSeq
        SHIFTOUT SDA, SCK, 0, [CHR1]    '1st Digit value
      Gosub AckSeq
        SHIFTOUT SDA, SCK, 0, [CHR2]    '2e Digit value
      Gosub AckSeq
        SHIFTOUT SDA, SCK, 0, [CHR3]    '3e Digit value
      Gosub AckSeq
        SHIFTOUT SDA, SCK, 0, [CHR4]    '4e Digit value
      Gosub AckSeq
    Gosub StopSeq
    Goto MainLoop
    '=============    SUBROUTINES    ====================================
    StartSeq:
     High SCK
     High SDA
     Low SDA
    ACKSeq:
     Low SCK
     High SCK
     Low SCK
    StopSeq:
     Low SCK
     Low SDA
     High SCK
     High SDA
    '===============  END OF PBP PROGRAMME =========================================================
  1. Pic12f675
    By Andre_Pretorius in forum Serial
    Last Post: - 6th April 2009, 00:27
  2. PIC12F675 not working
    Last Post: - 26th March 2009, 17:40
  3. SERIN with a PIC12F675
    By ewandeur in forum Serial
    Last Post: - 30th July 2007, 15:04
  4. Pic12f675
    By perides in forum mel PIC BASIC Pro
    Last Post: - 11th July 2007, 20:37
  5. PIC12F675 and ADCIn
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 19th February 2005, 07:42
