SHIFTOUT with PIC12F675?
Results 1 to 12 of 12
    Feb 2022
    Default SHIFTOUT with PIC12F675?
    Hello to the Community.
    Is the Shiftout command possible for a PIC12F675?
    I ride a program using this command but my logic analyzer does not show me any pulse of Data and Clock!
    Thanks.
    Feb 2022
    Default Re: SHIFTOUT with PIC12F675?
    Here is the test program...
    '   Programme: Shiftout Test PBP   (c)Roger LEGAT 07-2023
    '   RX Tester---> PIC 12F675
    ' PicBasicPro Compiler V:2.40   ---> 393 Words used
    '*** PIC Pinouts/Specifications
    '            PIC 12F675
    '                   __ __
    '           Vcc +|  U  |- Gnd
    '        GPIO.5 x|     |< GPIO.0
    '        GPIO.4 >|     |> GPIO.1 _DIO
    '        GPIO.3 >|     |> GPIO.2 _CLK
    @ Device Pic12F675, intrc_osc, wdt_off, pwrt_on, mclr_off, protect_off
    DEFINE OSC 4    ' Pulsin/Pulsout Resolution    =10µsec    => 1ms=100
    '   (Pulse Value of 1msec x10 =1000)    [x10]
    '  Pause =1msec => 1msec=1    1sec=1000
    Include "modedefs.bas"   ;for shiftout command
    CMCON  = 7   'Comparator Off
    ANSEL  = 0   'Set Port to Digital i/o
    ADCON0 = 0   'All ADC Off
    Asm
     bsf STATUS      ;Bank 1
     call 3FFh       ;Get the CAL value from 3FF addresse YOU WRITE BEFORE !
     movwf OSCCAL    ;Calibrate
     bcf STATUS, RP0 ;Bank 0
    Endasm
    '*** In/Out pins ..................................................
     Output 1 : _DIO var GPIO.1
     Output 2 : _CLK var GPIO.2
    '*** Variables/Constants
      Pack       VAR BYTE        ;Byte to send
     '=== MAIN PROGRAM =====================================================
     Pack = 255
    MainLoop:
       Shiftout _DIO,_CLK,LSBFIRST,[Pack\8] 'Send Byte
    Goto MainLoop
    ;=========== END OF PBP =================================================
    Maybe it is better to define the output register more convenitional.
    Try
    TRISIO = 0
    DIO VAR GPIO.1
    CLK VAR GPIO.2
    and report back how is doing.
    Feb 2022
    I'm trying to understand and learn:
    What might be the consequences if I set my ports as follows:
    Dio var GPIO.0
    or
    Symbol Dio = GPIO.0
    Does this make a difference to the way the program is processed?
    Originally the problem I think was this syntax:
    I do not see how this can compile.
    Feb 2022
    Hello,
    And yet the compiler didn't give any errors!?
    I'm going to keep your suggested syntax anyway.
    Concerning my problem with the Shiftout command, I note that a problem existed with this command for the Picaxe 08M2 (which is in fact a PIC12F1840).
    The Shiftout command was not possible for this Picaxe and it was necessary to create a small routine explained in the Picaxe manual.
    Before continuing my tests, I wondered if such a problem could also be encountered with my Pic12F675... ?
  1. Pic12f675
    By Andre_Pretorius in forum Serial
    Last Post: - 6th April 2009, 00:27
  2. PIC12F675 not working
    Last Post: - 26th March 2009, 17:40
  3. SERIN with a PIC12F675
    By ewandeur in forum Serial
    Last Post: - 30th July 2007, 15:04
  4. Pic12f675
    By perides in forum mel PIC BASIC Pro
    Last Post: - 11th July 2007, 20:37
  5. PIC12F675 and ADCIn
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 19th February 2005, 07:42
