PAUSE for a variable time? Using MAX and MIN
Results 1 to 4 of 4
    Mar 2023
    Cape Town, South Africa
    Default PAUSE for a variable time? Using MAX and MIN
    In my program I have LC as a variable word ranging from 0 to 57000. It is the mainloop counter
    In a subroutine I want to pause a variable amount of time in the 0 to 5000 part of the mainloop counts. I have tried to use:
    pause 0 min 5000-LC
    in other words, if LC is 5000 to 57000 don't pause at all. and between 0 and 5000, pause for a proportional length of time.
    I think my pause pause and min statement is missing some syntax?
    Any hints please?
    Default Re: PAUSE for a variable time? Using MAX and MIN
    5000-57000 will give negative number
    Maybe you want to use ABS(5000-LC)
    so:
    a=abs(5000-LC)
    a=a min 5000
    Pause a
    might help?
    But then I am not very sure about the maths to calculate the needed delay.
    Does this provide the functionality you want?
    IF LC < 5000 THEN
      PAUSE (5000 - LC)
    Mar 2023
    Thank you Ioannis and Henrik, both your suggestions would be suitable for me. I apologise for posting this amateur question. In my defence, I had just started a section a code when the grandchildren arrived and that put a sudden stop to it . . . . .
  1. Array variable access time
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 25th April 2020, 08:48
  2. MAX MIN vs IF
    By netstranger.nz in forum PBP3
    Last Post: - 3rd March 2013, 11:24
  3. pause 1 min in osc 48 ?
    By dala01 in forum USB
    Last Post: - 12th December 2011, 16:22
  4. defining max pulsin time with duty cycle 100%
    By hkpatrice in forum mel PIC BASIC Pro
    Last Post: - 5th April 2010, 11:58
  5. ADCIN > HPWM but with min/max limits - i failed maths
    Last Post: - 29th November 2009, 03:02
