Infrared HPWM setup
Results 1 to 20 of 20
    Default Re: Infrared HPWM setup
    I worked somehow but not always reliable.
    the series resistor for the led is wat too big, it will make range / reliability pretty low. it could go as low as 39 ohms safely [probably lower even] in a non continuously on configuration otherwise 100 ohm would be better
    Oct 2010
    I will try to change that as well before i go for the RC5.
    The following 15 days i will be in a business trip in Abu Dhabi so i will get back as soon as i have time to check this out.
    Many thanks.
    Aug 2011
    You can get rid of the transistor and associated resistors and just connect the OUT directly to RB7.
    If you need to, you can invert the RX sign with the DTRXP bit in the baudcon register.
    OK
    For most LEDs or SSRs, I found 470 ohms offers a good compromise between response time and effectiveness.
  1. Replies: 3
    Last Post: - 23rd October 2011, 13:53
  2. InfraRed Data Com
    By rayzrocket in forum Off Topic
    Last Post: - 29th March 2010, 16:42
  3. Infrared x PIC
    By ewandeur in forum mel PIC BASIC Pro
    Last Post: - 29th December 2009, 19:30
  4. infrared help
    By griffin in forum mel PIC BASIC Pro
    Last Post: - 30th December 2008, 06:34
  5. infrared
    By bmohnsen in forum General
    Last Post: - 2nd May 2007, 17:35
