Infrared HPWM setup
Results 1 to 20 of 20
    Oct 2010
    Default Re: Infrared HPWM setup
    Please find the schematic as follows.
    I hope i didnt forget anything. In any case is very simple.
    Name:  Schematic_IR TX_2023-06-02.png
    if you look at the data sheet for a tsop4838 you will see that you have a numbers of issues to contend with
    1. @9600baud the bit time is 100uS or approx 4 cycles of 38khz , about 2 to three times faster than the tsop4838 can cope with
    2. the max burst rate is 800/sec a 9600baud stream can exceed that
    3. after a 70 cycle transmission a 12 cycle min tx gap must be made [some devices can lock up if u don't and need a pwr cycle to recover]
    4. the device will do its very best to reject a continuous transmission and go mute till a min tx gap in tx is observed, which is what you are doing.
    overall tsop4838 is not particularly suitable for serial tx from a uart, you could try a much lower baud rate and you will need to
    invert the transmission logic so that there no transmission at idle
    i would also wire tx to rx directly to verify code works before trying ir link, also have a look at Manchester encoding and check out ir tx protocols like RC5/6 NEC etc
    Oct 2010
    Hi Richard,
    you are right, i have decreased the speed and manage to play a lit bit with the delay in useconds.
    I worked somehow but not always reliable.
    I think i will try the RC5 method.
    the series resistor for the led is wat too big, it will make range / reliability pretty low. it could go as low as 39 ohms safely [probably lower even] in a non continuously on configuration otherwise 100 ohm would be better
    Oct 2010
    I will try to change that as well before i go for the RC5.
    The following 15 days i will be in a business trip in Abu Dhabi so i will get back as soon as i have time to check this out.
    Many thanks.
    Aug 2011
    You can get rid of the transistor and associated resistors and just connect the OUT directly to RB7.
    If you need to, you can invert the RX sign with the DTRXP bit in the baudcon register.
    OK
    For most LEDs or SSRs, I found 470 ohms offers a good compromise between response time and effectiveness.
  1. Replies: 3
    Last Post: - 23rd October 2011, 13:53
  2. InfraRed Data Com
    By rayzrocket in forum Off Topic
    Last Post: - 29th March 2010, 16:42
  3. Infrared x PIC
    By ewandeur in forum mel PIC BASIC Pro
    Last Post: - 29th December 2009, 19:30
  4. infrared help
    By griffin in forum mel PIC BASIC Pro
    Last Post: - 30th December 2008, 06:34
  5. infrared
    By bmohnsen in forum General
    Last Post: - 2nd May 2007, 17:35
