with the following configuration i got this on the scope. So i guess we are in a good path.
To mention that the main OSC is at 64Mhz using HPWM on the PIC18f26K22 on portc.2
Code:TRISC.2 = 0 ' CCP1 (PortC.2 = Output) PR2 = 104 ' Set PWM Period for approximately 38KHz CCPR1L = 52 ' Set PWM Duty-Cycle to 50% (011010010) 210>>2 = 00110100 = 52 T2CON = %00000101 ' Timer2 ON + 4 prescale CCP1CON = %00001100 ' Mode select %00001100 = PWM
all thanks to Richard.
now im going on the next step.
