Leaves the mainloop???
Results 1 to 40 of 46
    Apr 2016
    Plainfield, Illinois
    Default Re: Leaves the mainloop???
    SCHEMATIC1 _ PAGE1.pdf
    here's rough schematic again - sorry for the wild goose chase guys - really appreciate the help.
    Q2 is only driving the gate of some P channel mosfets. With the load attached to the drain of the mosfets, pin 3 on PIC wont drive the base - the program leaves the main loop - it resets.
    If I release the load and turn on NPN and then turn on load, it stays on.
    I was aslo thinking of changing the circuit to a double npn and reverse the logic - thus the PIC wouldnt see the 2nd NPN, but I'd like to know why its behaving this way.
    My dad never liked you...
    0 out of 1 members found this post helpful. Did you find this post helpful? Yes | No
    you are making this very difficult,
    every schematic so far is different some are worse than others
    the latest is doubtful r17 is too big 3k3 would be more realistic
    this is very bad
    given that vin high is vdd*0.8 and vin low is vdd*0.2
    a 12 volt input lands slap bang in the middle nowhere land , the slightest bit of noise could swing it either way
    r8 should be about 27k
    you keep posting code snippets or incomplete fragments that are impossible to evaluate
    this is a nonsense , and will continually reset because it has no loop it just wander off into lala land
    __config _CONFIG1, _FEXTOSC_OFF & _RSTOSC_HFINT32 & _CLKOUTEN_OFF & _CSWEN_ON & _FCMEN_ON
    __config _CONFIG2, _MCLRE_ON & _PWRTE_OFF & _LPBOREN_OFF & _BOREN_ON & _BORV_LO & _ZCD_OFF & _PPS1WAY_OFF & _STVREN_ON
    __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_OFF & _WDTCWS_WDTCWS_6 & _WDTCCS_SC
    __config _CONFIG4, _BBSIZE_BB512 & _BBEN_OFF & _SAFEN_OFF & _WRTAPP_OFF & _WRTB_OFF & _WRTC_OFF & _WRTSAF_OFF & _LVP_OFF
    __config _CONFIG5, _CP_OFF
    OSCCON1=%00000011
    OSCCON2=%00000011
    trisa = %11101100
    trisc = %11111111
    ANSELC = 0
    ANSELA = 4
    FET var LATA.4 ' FET output
    IG VAR PORTA.5 ' Ignition input
    GREEN VAR LATA.0 ' TIMING LED
    RED VAR LATA.1 ' FAULT LED
    MAIN:
    IF ig = 1 THEN
    FET = 1
    GREEN = 1
    FET = 0
    GREEN = 0
    i'm going to let it stew for a few days till you get your act together
    Apr 2016
    uncle.... do they have that expression down under? It means enough...
    if the problem is spikes, bad earth loop, filtering etc, then by posting here I feel it will ever be nailed down.
    Can you post a video of the process, connections etc? Also an oscilloscope on that offending pin as you say that flatters, may show other things. Do you have an oscilloscope?
  1. Time taken to do mainloop
    By Gerald in forum mel PIC BASIC Pro
    Last Post: - 29th March 2023, 14:16
  2. Outside the Mainloop
    By pescador in forum General
    Last Post: - 26th April 2016, 17:34
