Leaves the mainloop???
Results 1 to 40 of 46
    Default Re: Leaves the mainloop???
    BTW ...
    What kind of load do you intend to drive ???
    Apr 2016
    Plainfield, Illinois
    The schematic shows it drives 2 P channel Mosfets which supply power to a resistor load. - the 10k and 6k on the collector drive the gate when the npn is on.
    The odd thing about this is when it powers up with resistor load attached - it will not drive the base of the npn. Release load and re-apply load - it stays on and works..
    I tried this code this w same results - it tries to turn on the npn but cant, green led flutters on and off - release the load - green led turns on steady - re-apply load - it drives the npn. WTH...
    MAIN:
    FET = 1
    GREEN = 1
    GOTO MAIN
    My dad never liked you...
  1. Time taken to do mainloop
    By Gerald in forum mel PIC BASIC Pro
    Last Post: - 29th March 2023, 15:16
  2. Outside the Mainloop
    By pescador in forum General
    Last Post: - 26th April 2016, 18:34
