Leaves the mainloop???
Results 1 to 40 of 46
    Apr 2016
    Plainfield, Illinois
    Default Re: Leaves the mainloop???
    DC electronic load - it works at 1 amp - any higher it fails (PIC cant drive the base).. no noise - PS can handle 20 amps.. The base of the npn must be sinking too much current for the PIC pin to drive at first. Whats strange is if I disconnect the load the PIC pin drives it ok, add the load and it keeps working. Power cycle PIC and it wont turn on the load again unitl I disconnect load and connect again.
    My dad never liked you...
    is this your complete code ?
    __config _CONFIG1, _FEXTOSC_OFF & _RSTOSC_HFINT32 & _CLKOUTEN_OFF & _CSWEN_ON & _FCMEN_ON
    __config _CONFIG2, _MCLRE_ON & _PWRTE_OFF & _LPBOREN_OFF & _BOREN_ON & _BORV_LO & _ZCD_OFF & _PPS1WAY_OFF & _STVREN_ON
    __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_OFF & _WDTCWS_WDTCWS_6 & _WDTCCS_SC
    __config _CONFIG4, _BBSIZE_BB512 & _BBEN_OFF & _SAFEN_OFF & _WRTAPP_OFF & _WRTB_OFF & _WRTC_OFF & _WRTSAF_OFF & _LVP_OFF
    __config _CONFIG5, _CP_OFF
    OSCCON1=%00000011
    OSCCON2=%00000011
    trisa = %11101100
    trisc = %11111111
    ANSELC = 0
    ANSELA = 4
    FET var LATA.4 ' FET output
    IG VAR PORTA.5 ' Ignition input
    GREEN VAR LATA.0 ' TIMING LED
    RED VAR LATA.1 ' FAULT LED
    MAIN:
    IF ig = 1 THEN
    FET = 1
    GREEN = 1
    FET = 0
    GREEN = 0
    Apr 2016
    yes - thats my test code
    with 6k in its collector and a hfe min of 100 the base current required is just a few microamps to drive it into saturation
    the pic will barely know its there
  1. Time taken to do mainloop
    By Gerald in forum mel PIC BASIC Pro
    Last Post: - 29th March 2023, 15:16
  2. Outside the Mainloop
    By pescador in forum General
    Last Post: - 26th April 2016, 18:34
