I/O pin default low.
Results 1 to 16 of 16
    Apr 2016
    Plainfield, Illinois
    Default I/O pin default low.
    How do I set an output digital pin low by default?
    16f15324 - pin PORTA.4
    My dad never liked you...
    Default Re: I/O pin default low.
    this will do it
    ansela = ~ 16
    lata     = ~ 16
    trisa    = ~ 16
    but i doubt its the actual problem, i suspect you are most likely driving the mosfet improperly
    Apr 2016
    Electronically I am driving it correctly.. its actually only driving an npn transistor..
    Somehow my program is restarting when I introduce an input.
    Apr 2016
    this will do it
    ansela = ~ 16
    lata     = ~ 16
    trisa    = ~ 16
    you are correct - with transistor out, it works - the transistor turns on the fet which has a load. With no load the code works - with load the program resets because the PIC output pin cant drive it on startup. Once its on and a load is then applied it works...
    So I guess the question is how do I get the PIC to work with load already on.
    provide more detail and a schematic to begin with
    Apr 2016
    attached pdf
    that's a fairly standard sort of high-side switch that I would expect to be ok.
    given that pic i/p leakage current is typically 100nA~ish MAX either R4 is not what is depicted
    or your code is not as described [bootloader maybe].
    you could try a smaller R4
    Thats about all i can see
    is a different story, a big heavy load needs a good power supply and adequate filtering
    together with a proper layout to prevent noise affecting the logic circuits
    Please ...
    - provide your full config section ( ports config included )
    - provide your full schematics ( Pic + Supply + Power sections )
    No way to give you a decent answer without those infos ...
    Apr 2016
    I'll give more infor in a bit - but my guess while sleeping is filtering - I need a few caps on inputs and output - which are next to the reset pin. I'll try that tonight. - and maybe a larger one on the PIC itself.
    I'll provide a better schematic and my code for ports etc later today.. I'm sure my code is different than what the good programmers use. I didnt use LAT for example - just ports.
    thanks ahead of time...
    Apr 2016
    ok - no insults please... - if someone wants to clean my code up for $ I'm all ears... - seriously...
    16f15324PIC-SCHEM.pdf
    schematic says it s 16f616 - its not - its a 16f15324 ********************
    __config _CONFIG1, _FEXTOSC_OFF & _RSTOSC_HFINT32 & _CLKOUTEN_OFF & _CSWEN_ON & _FCMEN_OFF
    __config _CONFIG2, _MCLRE_ON & _PWRTE_ON & _LPBOREN_OFF & _BOREN_ON & _BORV_LO & _ZCD_OFF & _PPS1WAY_OFF & _STVREN_ON
    __config _CONFIG3, _WDTCPS_WDTCPS_11 & _WDTE_ON & _WDTCWS_WDTCWS_6 & _WDTCCS_SC
    __config _CONFIG4, _BBSIZE_BB512 & _BBEN_OFF & _SAFEN_OFF & _WRTAPP_OFF & _WRTB_OFF & _WRTC_OFF & _WRTSAF_OFF & _LVP_OFF
    __config _CONFIG5, _CP_ON
    OSCCON1=%00000011
    OSCCON2=%00000011
    INLVLA = %11111
    INLVLC = %1111111
    TRISC = %11111111
    OSCFRQ_4MHZ
    ANSELA = PORTA.2
    ANSELC = %00000
    OUTPUT PORTA.1 ' FAULT LED
    OUTPUT PORTA.0 ' TIMING LED
    OUTPUT PORTA.4 ' FET
    INPUT PORTA.5 ' IGNITION
    INPUT PORTC.5 ' V UNDER TRIP POINT - 11 OR 11.75
    input PORTC.4 ' CHOICE BIT OF HOW THIS TURNS ON
    SW1 - SW6 are inputs
    green and red - outputs to leds
    "Battery sense" is an analog in
    "I sense" is a 12V in (broken down to <5v)
    FET - output
    whats happeing is when IG comes on the program resets when there is a load on FET - with no load it works. (I'm trying more filtering on IG AND FET output and make sure C3 is .1)
    btw - insult it all you want...
    Again - I'm all ears on someone helping me - lmk I'll giv emy email and set it up.
    Top secret electronic ignition ??? ....
    MC3334P clone ?
    - ADC inputs have a maximum input feed impedance to respond as fast as required ... see Pic datasheet for details.
    so, I presume @ first sight your current detection is wayyyy too slow, and your coil enters saturation ...
    add to that your IPB protection is wayyy too weak and slow !!! be prepared for in-use failures, after some running time.
    Now, automotive circuits need lots of filtering to avoid pic supply surges ...
    Apr 2016
    Quote Originally Posted by Acetronics2 View Post
    MC3334P clone ?
    No current detection - just if IG is on (12V) and monitors battery voltage - this all working for past 5 years. Discovered the issue of no load it starts right up - with load it resets program. In other words I can turn it on with Ignition and then apply load - works. But I can tell the program gets reset because I put a turn on/off red led before the main and it comes on when IG is applied. I'll try caps later tonight on signals.
    I also do not think code is correct setting up registers. Thats what I want help on.
    Apr 2016
    MC3334P clone ?
    no - not a clone of MC3334P - it just turns on a load if IG is present.
    by the time I get the IG signal its been filtered.
    What coil?
    IPB?
    Aug 2011
    0 out of 1 members found this post helpful. Did you find this post helpful? Yes | No
    Your ANSELA statement is incorrect... you don't set it that way.
    Apr 2016
    ok - please elaborate..
    Aug 2011
    ANSELA is an 8-bit register... you set it just like any register, 0-255
    If you want RA2 to be analog but all others digital then ANSELA = %00000100
    You have something very different... ANSELA = PORTA.2, which will read the value of the port pin and assign it to ANSELA (whatever that results in).
  1. How to set pin to digital by default? PIC18F24J50
    By picmilan in forum mel PIC BASIC Pro
    Last Post: - 29th May 2016, 22:27
  2. Replies: 10
    Last Post: - 14th April 2014, 21:47
  3. Can't keep a pin low
    By bartman in forum mel PIC BASIC Pro
    Last Post: - 6th January 2006, 15:04
  4. Trouble pulling pin Low
    By pdegior in forum mel PIC BASIC Pro
    Last Post: - 9th August 2005, 21:49
  5. Reading if Pin is High or Low?
    By Spindle in forum mel PIC BASIC Pro
    Last Post: - 1st August 2005, 18:39
