Hi Alan.
Thanks for your interest in my question.
This is a system used in RC sailing to control the genoa of a radio-controlled sailboat.
The sail is controlled by two winches.
The RC Transmitter has :
1) a three-position switch which determines the side on which the sail will be set (port or starboard).
If the switch is in the middle position, the two winches each take up a specific end-of-travel position to make it easier to move the sail from one side of the boat to the other.
2) A potentiometer that adjusts the tension of the sail's sheet.
Finally, a small configuration jumper allows 4 different winch positioning configurations depending on how the sheeting circuits have been designed in the boat.
A more detailed explanation can be found in the appendix.
Note: In fact, the logic of my programme seems OK and the different servo winch positions obtained are correct. I just have a little instability in the positioning of the servos, which 'wiggle' a bit.
RC Genoa Driver.pdf
