Do PICs goto sleep?
Results 1 to 18 of 18
    Feb 2005
    Essex, UK
    The pull-down resistors didn't make any difference, the LED keeps in the 'error' flash routine. I didn't have and 5K, so i used a 2k2, would this still perform the task? If not i have 47k?
    However, i have inserted:
        MaskSwitch=PORTC & $07
            Select Case MaskSwitch
              Case 1 '%00000001 or SW1
                Gosub Procedure_SW1
              Case 2 '%00000010 or SW2
                Gosub Procedure_SW2
              Case 4 '%00000100 or SW3
                Gosub Procedure_SW3
              Case Else
                Goto Main
        End Select
    Goto Main
    Adding the Goto Main routine now seems to work.
    Although this is a work around, its still strange that some other signal is being received into the PIC which i would like to find.
    Cheers.
    Post
    After looking at the HiRK-433 datasheet(assuming this is the one you use http://www.okwelectronics.com/datasheets/DS.0010-2.pdf ), i say that there is no need for pulldowns(or ups). Just make sure your JP1 and 2 are not linked. This would make the outputs latching, you want them to be momentary.
    /Ingvar
    Feb 2005
    Essex, UK
    Yup, thats the exact one.
    Ok, i'll remove the pull-down resistors.
    It must be something else that is making the CASE ELSE statement true then.
    Cheers,
    Aug 2005
    When I am developing a project I always have a serial port available ,even if the project will not use it.Being able to check variables and ports is invaluable for debugging,versus debugging blind.
    Feb 2005
    Essex, UK
    OK, i'm ready for a slap !!
    I failed to put a pull-up on the MCLR port. The thing is, i put it on my diagram, but failed to put it on the vero circuit.
    Thanks again to all those that helped. I did solve another a couple of issues at the same time. So all was not wasted.
    Talking
    Here comes the ruler ......... Nah, that's to easy on somebody who forgot something as serious as a pullup on MCLR. It's time for Melanie to get into her leather outfit and teatch you real good, that way it'll surely never happen again. It might, however, make me want to forget all about resistors .... and their proper use
  1. Making a menu
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 12th November 2008, 20:54
  2. Replies: 14
    Last Post: - 26th September 2007, 06:41
  3. Problems with RC2 and RC3
    Last Post: - 29th May 2006, 18:19
  4. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
  5. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
