PIC12F675 triso question?
Results 1 to 3 of 3
    May 2023
    Texas
    Default PIC12F675 triso question?
    Good day all
    I'm pretty new to the fancy PIC world and I feel that I'm understanding most of what I'm reading. One of the things that is confusing me is triso.
    For the PIC12F675 I have seen example code with triso=%00000000 and
    triso=%000000
    The code I'm playing with has outputs on gpio.0 and gpio.1, the rest are digital inputs.
    Would triso=%111100 be correct or am I missing the way 1's and 0's work.
    Default Re: PIC12F675 triso question?
    First of all it is TRISIO and not TRISO. You missed the I.
    Then the general case is that registers are 8 bit wide. But in the 12F675 case you have access to only the least 5 bits.
    So the best way to define TRISIO is to use the 8 bit format, although 5 bits will work fine too like this:
    TRISIO=%00011100 is the same as TRISIO=%11100 and that would set GPIO.0 and GPIO.1 as outputs while GPIO.2, GPIO.3 and GPIO.4 as inputs.
    The rest does not matter since 675 does not have that pins I/O.
    It is like the numbers, 05 is the same as 5, right?
    Hope this is clear.
    May 2023
    Texas
    That makes perfect sense, thank you.
  1. PIC12F675 - config
    By Vezito in forum mel PIC BASIC Pro
    Last Post: - 8th June 2011, 20:29
  2. Math question relating to AD input on PIC12F675
    By rfetech in forum mel PIC BASIC Pro
    Last Post: - 9th November 2010, 03:35
  3. Pic12f675
    By Andre_Pretorius in forum Serial
    Last Post: - 6th April 2009, 00:27
  4. SERIN with a PIC12F675
    By ewandeur in forum Serial
    Last Post: - 30th July 2007, 15:04
  5. Pic12f675
    By perides in forum mel PIC BASIC Pro
    Last Post: - 11th July 2007, 20:37
