16F628 on-chip eeprom problem
Results 1 to 17 of 17
    atomski's Avatar
    atomski Guest
    Question 16F628 on-chip eeprom problem
    Hello everyone,
    I'm new to the group and I'd like to ask a question. I've recently
    moved all my projects from 16F84 to 16F628 mcu's. Yesterday I've
    tried to write data to the internal (on-chip) eeprom of 16F628 with
    little (or no sucess. Would anyone care to explain why the same
    code works on 16F84 and 16F876/877 but not on 16F628? I used the
    most common method:
    EEPROM 0, 127 ' Store 127 into eeprom location 0
    [code]
    READ 0, W ' Put contents of memory location 0 into W
    [code]
    WRITE 0, W ' Put contents in W into eeprom location 0
    And neither of the commands work! I've tried all locations from
    0 - 11 for example and no luck. What am I doing wrong? Any help is
    appreciated! Thanks in advance.
    Sincerest regards,
    YZ7REA Vladimir M Skrbic
    4N7ATV Repeater Administrator
    YU7GHZ Radio Club President
    USA - Arizona
    What version of PBP are you using?
    I quote:
    "Ver 2.32 had a Bug would not write to the EEPROM of 16F628..."
    Read on http://list.picbasic.com/forum/messages/3064/3247.html
    and/or search in this list.
    atomski's Avatar
    atomski Guest
    It's 2.42, I think
    Oct 2003
    Australia
    Try this,
    B0 VAR BYTE
    CHAR VAR BYTE
    FOR B0 = 0 to 15
    LOOKUP B0,["EEPROMS ARE COOL"],CHAR
    WRITE B0, CHAR
    NEXT B0
    I'm using V2.43
    Squibs
    atomski's Avatar
    atomski Guest
    Squibcakes,
    thanks for the reply. However that's exactly what I have done only it has
    a for next loop... My 16F628's just
    wan't store anything at locations
    0 trough 11 if I use just:
    WRITE location, value
    EEPROM and DATA don't work either...
    Vlad
    USA - Arizona
    Maybe if you posted the code you're using (to write to EEPROM), along with defines and port settings.
    Oct 2003
    Australia
    I'm probably stating the obvious here, but try erasing the Chip a few times in a row.. I have found that these chips get a bit flakey with numerous re-writes.
    Is the supply voltage VDD high enough?
    atomski's Avatar
    atomski Guest
    Talking
    I'll post the code later today,as I'm at work right now. The supply voltage is
    5.2V / 20A
    Vlad
    PS I'll try to erase the chip several times and see where that takes me...
    Posting what you're doing with your code and telling us what version PBP you're using may help us see what's going wrong. Additionally I'll draw your attention to...
    http://www.picbasic.co.uk/forum/show...=&threadid=171
    I've seen this problem now with several families of PIC's. As Microchip migrates products to micropower technology problems like this are starting to appear. If your application writes to EEPROM right at the start of your program, this can start executing WHILST STILL IN YOUR PROGRAMMER! You may need to adjust your program if this is happening in your case.
    Melanie
    atomski's Avatar
    atomski Guest
    Melanie,
    Thanks for the reply. I've read the whole:
    thread and found it most informative. I'll post my code later this afternoon. Thanks a lot!!!
    Vladimir
    Vladimir, What type of programmer are you using to get the hex file into the PIC?. Are you making sure that the DATA CODE PROTECTION BIT (bit 8) is set to 1 in the configuration word. This bit maps to the WREN (EEPROM Write Enable) at location 9C hex. Check if this option is being set during the burn process as the configuration between F84 and an F628 are different. It may have been over looked. As for the code the only thing I see wrong is the missing brackets[ ] after the location. I use the 16F628 for my link controllers and use the EEPROM statement for storing the CWID characters. I hope this helps?
    atomski's Avatar
    atomski Guest
    Hello everybody,
    I'm sorry for not sending this earlier but my kid got sick yesterday and was chasing doctors all day long
    Here's what I've done so far:
    @ device WDT_ON, MCLR_OFF, HS_OSC, BOD_OFF, PWRT_ON, CPD_OFF, LVP_OFF
    DEFINE OSC 20
    CMCON = 7
    VRCON = 0
    TRISB = %11111111
    TRISA = %00000000
    OPTION_REG.7 = 0
    Tx var portb.2
    Rx var portb.1
    C var word
    T1 var word
    T2 var word
    T3 var word
    T4 var word
    T5 var word
    Tmp_T var word
    D var word
    RT con 2110
    P var byte
    eeprom 0, [100]
    eeprom 1, [350]
    eeprom 3, [1981]
    eeprom 5, [1860]
    eeprom 7, [1860]
    eeprom 9, [1860]
    eeprom 11, [1860]
    init:
    read 0, Period
    read 1, D
    read 3, T1
    read 5, T2
    read 7, T3
    read 9, T4
    read 11, T5
    if portb.3 = 1 then main
    SEROUT2 tx,16780,["ENTER 5-DIGIT VALUE",13,10]
    get_c:
    C = 0
    SERIN2 rx,16780,[dec5 C]
    If C = 0 Then get_c
    SEROUT2 tx,16780,["C ",dec C," ACCEPTED, THANK YOU!",13,10]
    gosub convert
    SEROUT2 tx,16780,["T1= ",dec T1,13,10]
    SEROUT2 tx,16780,["T2= ",dec T2,13,10]
    SEROUT2 tx,16780,["T3= ",dec T3,13,10]
    SEROUT2 tx,16780,["T4= ",dec T4,13,10]
    SEROUT2 tx,16780,["T5= ",dec T5,13,10]
    get_p:
    SEROUT2 tx,16780,["D (xxx)?",13,10]
    P = 0
    SERIN2 rx,16780,[dec3 P]
    If P = 0 Then get_p
    SEROUT2 tx,16780,["P SET TO: ",dec P,", THANK YOU!",13,10]
    get_d:
    SEROUT2 tx,16780,["D (xxxx)?",13,10]
    D = 0
    SERIN2 rx,16780,[dec4 D]
    If D = 0 Then get_d
    SEROUT2 tx,16780,["D SET TO: ",dec D,", THANK YOU!",13,10]
    write 0, P
    write 1, D
    write 3, T1
    write 5, T2
    write 7, T3
    write 9, T4
    write 11, T5
    '[code]
    GOTO main
    convert:
    '[converts each digit from C to 4-digit word sized value]
    '[i.e 1 = 1234, 2 = 5678, 3 = 9999 etc.]
    I guess Dave's remark regarding CPD stands... Thanks Dave. Everyone please take a look at this piece of code and tell me if you see anything wrong with it?
    PS I use version 2.42
    Sincerest regards,
    You're losing the plot before you start Vladimir...
    eeprom 0, [100]
    eeprom 1, [350]
    eeprom 3, [1981]
    eeprom 5, [1860]
    eeprom 7, [1860]
    eeprom 9, [1860]
    eeprom 11, [1860]
    As I replied to you earlier in the Private Message you can only store BYTES at a time in EEPROM. That's values 0-255 Decimal. At EEPROM address 1, you are trying to store 350, it's not going to happen. Pretend 350 is a 16-bit word, you will store the lower 8-bits into address 1, and NOTHING into address 2 (it will remain unchanged with any previous contents intact). The same at address 3 - you will store the lower 8-bits of the 16-bit value 1981, and address 4 will remain untouched.
    Later on, you are reading words like this...
    read 5, T2
    You are expecting to have a value of 1860, but you won't. T2 will be loaded with the value from EEPROM address 5 ONLY. EEPROM address 6, (which you are expecting to load into the highbyte of T2 will NOT be read). REMEMBER that EEPROM operations work on ONE BYTE ONLY - Not Words - BYTES!
    For example, let's take T2...
    Initially you want to store 1860 (%0000011101000100) into locations 5 and 6, lowbyte into 5, and highbyte into 6. Do it like this...
    DATA @5,%01000100
    DATA %00000111
    I used binary notation specifically to show you how to save a word constant (you can use the EEPROM command rather than DATA if you wish and of course you need not use Binary like I did for this explaination, you can use HEX or Decimals too).
    Later on, when loading T2 do this (same technique when writing to EEPROM)...
    read 5,T2.Lowbyte
    read 6,T2.Highbyte
    Remember BYTE AT A TIME. If you want WORDS you have to construct them out of two bytes - it will NOT be done automatically for you.
    Melanie
    atomski's Avatar
    atomski Guest
    Mel,
    Thanks for the info. Yes I am aware that
    some of my variables use WORDS, however I was under the impression that
    PBP splits WORDS into two BYTE sized
    values and stores them at two consecutive addresses. Oviously I was wrong. I'll do it the Mel way from now on Thanks Melanie!
    PS will let you know how it works...
    Sincerest regards,
    YU7GHz Radio Club President
    You CAN store WORDS as CONSTANTS, but you have to delfine them... to my previous example storing 1860 at locations 5 and 6...
    DATA @5,%01000100
    DATA %00000111
    can (according to the manual) also be written as...
    DATA @5, WORD 1860
    although personally I always use my original method.
    However, you still need two individual byte operations to READ and WRITE.
    Melanie
    As Melanie has mentioned so many times in the past, Please send a code snipit of where you might think the problem is. It wasn't untill the last 3 reply's to this thread that the problem was uncovered only after a code snipit was revealed. Thank you.
    atomski's Avatar
    atomski Guest
    Talking
    Well,
    to conclude this thread, I would have to
    say thank you everyone, especially you
    Mel! I've made all the necessary changes
    to my code (as Melanie suggested) and
    it worked like a charm! I had a few minor
    bugs in the code as well but I've managed
    to sort 'em out. I appreciate your help...
    Sincerest regards,
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 04:17
  3. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 07:26
  4. Problem with saving to EEPROM...
    By Tear in forum mel PIC BASIC Pro
    Last Post: - 1st July 2005, 01:10
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
