Over-voltage protection
Results 1 to 28 of 28
    Default Re: Over-voltage protection
    That was my first idea, but I don't know just how far a 7805 can take abuse, compared to the TVS, NTC and MOV?
    they are pretty tough, i don't go much for linear regs due to their low efficiency and heatsink requirements [ for batt powered stuff].
    for low power mains powered roles they served well for years and still can
    absolute vin max is 35v but dropping 20v or so across the reg @250mA makes a lot of heat whereas for a switching reg , no heat
    Maybe I missed the scope but, why are you so worried?
    If you have a low current circuit, a 7805 is just fine for up to 35 or so voiltages.
    If you have higher currents, then a smps like the expensive Recom that Richard uses or the cheaper https://gr.mouser.com/ProductDetail/490-VXO7805-1000 I use is good enough.
    And last but not least, the circuit that you posted for reverse polarity protection with the p-mosfet in post #14 is the best protection with no voltage drop.
    I get crazy power surges and spikes here in thunderstorms, lots of trees messing with lines and transformers.
    I might end up using a combination of devices.
    Yeah, that diode was costing me .7V and was bugging me like crazy, but with that boost circuit, that's not really a problem. That boost circuit also gives me the choice of splitting my power source: 5V for PIC and other ICs, and what ever I need for more power-hungry circuits.
    I have only one major concern, whatever I chose, I have to be able to provide at least 100 within a year, hopefully 1000 over the next few years (gotta have goals in life ).
  1. Replies: 8
    Last Post: - 21st March 2015, 18:21
  2. Replies: 7
    Last Post: - 22nd January 2012, 05:50
  3. High voltage protection
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2010, 09:26
  4. Over Voltage protection
    By George in forum mel PIC BASIC Pro
    Last Post: - 17th July 2006, 22:16
