Over-voltage protection
Results 1 to 28 of 28
    Default Re: Over-voltage protection
    - Green LED remains ON while voltage remains under 5.6V.
    Green LED remains ON , it will not extinguish
    - Red LED turns ON when voltage reaches 5.6V, and Green LED turns OFF.
    Red LED turns ON when voltage reaches 5.6V + at least 0.6 v , so more like
    when voltage exceeds 6.3v Red LED turns ON and Green LED remains on.
    - SCR shorts out Fuse and protects everything to the right of this circuit.
    in practice :- just after every semiconductor device is destroyed SCR shorts out Fuse
    Green LED is driven by a PNP. Won't that shut off once the Zener breaks?
    no, there is no mechanism there to make vbe for the pnp tr ever be below the 0.6 v required to switch the tr on
    ... in practice :- just after every semiconductor device is destroyed SCR shorts out Fuse
    What destroys ICs downstream after the SCR shorts to VSS?
    Is it a current surge?
    Or reverse voltage?
    EDIT: Added NTC for current surge protection at output, and extra TVS up front (we get a lot of power surges here, hydro lines are not the most stable with so many trees).
    EDIT SOME MORE: In keeping with Tim The Toolman's philosophy of "cause we can", I added a Varistor on output.
    Name:  Over-voltage protection v5 SMALL.png
    Crowbar protection can be ineffective due to the time taken for it to activate. Everything of value is damaged in the milliseconds before comes in.
    What about Zener/Mosfet design?
    https://theorycircuit.com/over-volta...ction-circuit/
    Darn, not that one either. It protects against reverse polarity.
    I saw some earlier, but can't find them now.
    you could try
    but i feel its a no gain process, a good switch-mode supply is cheaper and smaller
    you could try ... but i feel its a no gain process ...
    I'd really like to learn "something" in this exercise.
    The majority of the over-voltage links on the web either point to the naked zener, or zener-SCR and zener-FET. And a LOT of those threads get taken apart in the comments. It's like amateurs acting like they're gurus now.
    So I resorted to looking at the corporate sites; they usually know what they're doing, but I ignore them in the past cause it's often so much more complicated than my skill level.
    And then I fall on this one from TI:
    Technical specs here:
    https://www.ti.com/lit/an/snoaa20/sn...FCIRCUIT060079
    - 1 IC
    - 4 Resistors
    - 2 Zeners
    - 1 MOSFET
    And it includes all the math to convert for 5V (I think).
    But I'm faced with the same question, will this design have a delay that won't really save anything sensitive downstream?
    Richard, that circuit you buy, doesn't that also have some delay to a certain degree?
    I'd be very interested in this IC, only downside, requires 7V in (without knowing more about it yet).
    https://www.ti.com/lit/ds/symlink/tl714.pdf
    NEVER MIND, 7-12mA.
  1. Replies: 8
    Last Post: - 21st March 2015, 17:21
  2. Replies: 7
    Last Post: - 22nd January 2012, 04:50
  3. High voltage protection
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2010, 08:26
  4. Over Voltage protection
    By George in forum mel PIC BASIC Pro
    Last Post: - 17th July 2006, 21:16
