Going backwards, can't even get a basic blinky working now
Results 1 to 27 of 27
    Default Re: Going backwards, can't even get a basic blinky working now
    Eeeep, 20V That's a tad beyond max rating for a 16F877.
    Name:  16F877 max elect char.png
    Reading up on Zener Transient Suppression:
    https://www.electronics-tutorials.ws...ppression.html
    And then off to Digikey for a supply of Zs.
    EDIT: These look nice:
    https://www.digikey.ca/en/products/detail/onsemi/1N5243BTR/977601
    Looked up the 18F4550, and it's not better.
    Voltage on MCLR with respect to VSS (Note 2) .......................... 0V to +13.25V
    Note 2: ... a series resistor of 50-100Ω should be used when applying a “low” level to the MCLR/VPP/RE3 pin, rather than pulling this pin directly to VSS.
    Maybe I've just been lucky, or my PK4 has a thing against 16F pics.
    Either way, a little prevention added to my circuits shouldn't hurt; like a zener on MCLR, and 50-100R when pulled low.
    It's not letting me EDIT that post so I can fix the hyperink to the diodes.
    Zener Diode 13 V 500 mW ±5%
    I guess you have biased the MCLR pin, right?
    Why don't you get rid of the crystal and use the pic internal oscillator ? That should stop your hand capacitance causing problems on the crystal circuit.
    Aug 2011
    2 out of 2 members found this post helpful. Did you find this post helpful? Yes | No
    Regarding the overshoot issue, if your PICkit 4 is serial number BUR20xxxxxxx or later (-R2) then it has a mod in it to reduce the overshoot so it's not as much of a problem. Before that, they used to recommend using a 470R in series with the PK4 MCLR connection to the target.
    From ETN37:
    Some PIC16/18 devices have options to use high voltage on VPP or NMCLR to program the device. On some
    devices, the VPP/NMCLR pin has special ESD protection. Overshoot on the pin can result in a reset condition or
    current consumption outside of the specification. To avoid this situation, the data sheets for these devices
    recommend the use of an RCR network with a pull-up, a power up charge capacitor and a series resistor
    configuration into VPP. A series resistor of 470 ohms is used to dampen any overshoot and to limit current into
    VPP/NMCLR
    From ETN37:
    BUR223673449
    Do you mean -R like a command line? Taken from the IPECMD docs:
    R<on><off>
    Safe/Restricted mode (Applicable only for MPLAB PM3)
    Default = None
    I'm running the PK4 from MCS+5.
    I don't know the term "bias" in relation to the MCLR pin; but if you mean put a zener upside down so it breaks down over a given voltage, then yes, I'm biasing the pin.
    Scroll down here to the paragraph called Zener Transient Suppression.
    I'm going to go one step further with zener diodes. I'm gonna add a 1N5243BTR on MCLR to break down at 13 volts, and a ‎1N5232BTR on VDD to break down at 5.6 volts (specs say 5.5V is "max" - but I figure they're leaving a small margin for safety).
    Unless someone has a good reason why I shouldn't...?
    I'm not seeing an internal oscillator on the 16F877: LP, XT, HS and RC. If you mean RC, it uses a capacitor as well. Won't that cause the same issues? They also mention other issues, like accuracy/tolerance of the resistor and capacitor, as well as temperature.
    This will ultimately run a USB or USART connection as fast as I can.
    I've tested the new breadboard using two gold pins from a header as probes (those pins are thick, clean and square) and I'm still getting a lot of "looshish" spots in some areas. The much thinner pins on capacitors, oscillators and some resistors must definitely be messing up my circuit.
    Also, I think I have some capacitor/interference issue with my Lab X1 as well (probably not even related with my breadboard issues, just bad timing). Waving my hand over the X1 should not affect operations. It's possible it now has a defect; I bought it when they came out.
    I'm looking at using fiberglass breadboards and soldering my components. I've been thinking of making my own Arduino-ish circuits for testing for a very long time. This might be the time to give that a try.
    Side note: the tips on my Aoyue 738 soldering station are garbage. Bought some new ones on Amazon and they just don't last. One comment on the listing was "I've had packs of gum that lasted longer"; he wasn't exaggerating.
    I bought new soldering paste since mine was 20 years old and had spent winter in unheated garage. I've just received today one of those brass brush balls to clean the tip; hoping that works better than that water sponge (never liked that).
  1. DT_INTS-14 (Blinky Light) Help ?
    By andybarrett1 in forum mel PIC BASIC Pro
    Last Post: - 4th November 2015, 22:28
  2. Replies: 3
    Last Post: - 15th April 2015, 05:58
  3. 12F683 - basic code not working
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 12th February 2014, 01:29
  4. Blinky not working with TOGGLE
    By AndrewC in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 09:45
  5. My first Blinky!
    By nomad in forum mel PIC BASIC Pro
    Last Post: - 25th September 2007, 18:29
