New project - MSFS C++ USB interface
+ Reply to Thread
Results 1 to 40 of 170
    Default Re: New project - MSFS C++ USB interface
    I am done with the DIY pcb, chemicals and drilling... Enough fumes, dust and stains!
    A CNC machine is nice to have, for various other uses also, among pcb and drilling, but not for me anymore.
    Now I use the dirty cheap and ultra fast JLCPCB for any pcb needs.
    I'm gonna check out JLCPCB once I have a circuit ready.
    Right now I'm finishing up buying parts; just need those rocker switches and some graphic overlay for backlit text.
    On the positive side, I'm well on my way repossessing my basement from all that junk I've accumulated.
    Finally got to work on my new workbench debugging why that LED wasn't turning on as it should.
    I'm a visual person, I like to see what I'm doing as opposed to relying exclusively on drawings and schematics (although I do enjoy making them).
    This is what I'm doing right now; the communication & navigation panel (COM1, COM2, NAV1 and NAV2).
    This is a quick layout of the parts I've bought (that's about 9 inches wide, 8 inches tall).
    The TEST button was integrated in the volume button in-game. I couldn't afford potentiometers with a push-button, so I added a separate black button
    The rotary encoders I'm using to change frequency have a built-in push-button switch; that way I don't need a dual knob arrangement (again, more expensive).
    Yeah, those squiggly pink circles will be LEDs later in life.
    All these pots, displays, switches etc, will be inerfaced to PIC microcontrollers and then to the PC running the simulator?
    That's the plan.
    Wish I was closer to your location. An amazing project this will be!
    I've been up to my eyeballs with little time to browse the forum. I've been researching parts, accumulating inventory, learning C++ and the MS Flight Sim SDK, and now XML, finding decent software to convert Gerber RS-274-X to G-code (turns out my Gerber format is obsolete, but the dude modified his software for me).
    I've settled on all the controls for my console, and have all the variables and events to interface with the MSFS SDK. Cost forced me to make a compromise for this first model (targeting budget gamers); I've removed all gauges and displays and moved over to on-screen in-game XML gauges. So I'm back to a "button box" design. That lower screen is all the XML gauges I will be using; some downloaded, some tweaked, and some my own.
    I've just starting designing my first "real" circuits; hoping to machine them real soon (I've done basic router and drilling on the mini-CNC). So far I'm seeing about 0.001" to 0.002" vertical tolerance on 3/4 of the bed, with a slight warp in one corner moving up to 0.005". That could be anything on a budget machine; bed, bearings, rails, tidal forces.
    And of course I see StarField is about to launch on kickstarter on the 18th; 25μm XY precision, 350x200x350 resin 3D printer. My SLA 3D printer is ok, but I wouldn't print ABS on it and prints are gonna need a LOT of hand-finishing, then I have to mold cases (not a simple process). With a resin printer, I could go straight to ABS finished cases, removing a LOT of steps in my fabrication process, and removing all the costs with mold-making (need to get a vacuum chamber).
    Hoping to have nice pics of PCBs to share soon.
    I went the chemical way 14 years ago; not doing that again. I had SOIC SMD parts and it worked, but I'm too old to breath fumes.
    This is my 2nd attempt on my mini-CNC. I royally screwed up the mirror operation on the 1st attempt.
    Top:
    Bottom:
    Still need to get fine steel wool to finish the job, dip in silver nitrate, and test text with inkjet printer transfer paper.
    I think the secret to making nice double-sided PCBs on a mini-CNC is to establish a procedure. This is what I do on the mini-CNC:
    1. Install 3.175mm drill bit.
    2. Home X, Y and Z axis.
    3. Probe Z-axis.
    4. Drill Left Alignment Holes.
    5. Drill Right Alignment Holes.
    6. Install 30deg V-bit.
    7. Probe Z axis.
    8. Height-map PCB, if required.
    9. Route Top layer.
    10. Install 0.8mm endmill bit.
    11. Probe Z axis.
    12. Route Top layer Cutout.
    13. Flip PCB using Alignment Pins.
    14. Install 30deg V-bit.
    15. Probe Z axis.
    16. Route Bottom layer.
    17. Install drill bit.
    18. Probe Z axis.
    19. Drill Bottom layer.
    ... repeats steps 12 - 14 for all Drill files
    20. Install 2 Retention Pins in Screw Holes.
    21. Install 0.8mm endmill bit (Make sure drill clears Retention Pins).
    22. Probe Z axis.
    23. Route Bottom layer Cutout.
    I take notes while I'm using the machine, and improve on the process.
    This is what I do to generate the G-code files from FlatCAM:
    =========================== FlatCAM ===========================
    Start WinPythonPowershell
    cd ..
    cd ..
    cd flatcam
    python .\flatcam.py
    ========== Do Height Map before drilling, if required. ==========
    	*** do not import Drill file for 3 Fiducials ***
    ****************** Alignment Holes and Mirror ******************
    Generate Drill files and Mirror Bottom:
    	- select MechanicalNofiducial file.
    	- click on 2-Sided.
    	- Axis = X.
    	- Reference = Box.
    	- click on Gerber.
    	- Select Bottom layer.
    	- click on Mirror.
    	- click on Excelon.
    	- Select Drill file.
    	- click on Mirror.
    	- repeat for all Drill files.
    	- Drill Dia = 3.175mm.
    	- point on desired coordinates Upper Left above Outline.
    	- Shift + Left Click.
    	- click Create Excelon Object.
    	- point on desired coordinates Upper Right above Outline.
    	- select 1st Alignment Hole Drill file.
    	- click Properties.
    	- rename to "1 - Alignment_Holes_L_3.175mm".
    	- click Drilling.
    	- Cut Z = -10.0mm.
    	- Travel Z = 1.0mm.
    	- Feedrate = 25mm/min.
    	- SpindleSpeed = 7500rpm.
    	- Start Z = 1mm.
    	- EndMove Z = 1mm.
    	- EndMove X,Y = 0,0.
    	- Preprocessor = GRBL_11_No_M6.
    	- Click GenerateCNCjob Object.
    	- select new Alignment CNC Job.
    	- Save CNC job (include drill dia and side in file name).
    	- repeat for 2nd Alignment Hole Drill file with:
    	  - "2 - Alignment_Holes_R_3.175mm",
    	  - EndMove Z = 25mm.
    	- Save Project.
    ************************ Milling Layer ************************
    Generate Geometry file:
    	- hide all other layers.
    	- select Gerber file for Top layer.
    	- click Properties.
    	- click Isolation Routing - Advanced.
    	- click Calculators, if necessary:
    		- Tip Diameter = 0.1mm
    		- Tip angle = 30deg.
    		- Cut Z = -0.1mm
    		- click Calculate.
    		- Copy Tool Diameter of 0.1536mm.
    	- Paste Tool Diameter.
    	- Shape = C1, circular with 1 flute.
    	- Passes = 2.
    	- Overlap = 20%.
    	- Enable Combine.
    	- Click Generate Geometry.
    	- Save Project.
    Generate CNC file:
    	- Select Geometry file.
    	- click Properties.
    	- click Milling - Advanced.
    	- Tool Dia = 0.1536mm.
    	- Job = Isolation.
    	- Cut Z = -0.1mm
    	- Travel Z = 1mm.
    	- Feedrate X-Y = 120mm/min - 140mm/min.
    	- Feedrate Z = 10mm/min - 12mm/min.
    	- Spindle Speed = 9500rpm - 12000rpm.
    	- EndMove Z = 25mm.
    	- Preprocessor = GRBL_11_no_M6.
    	- click Generate CNCjob Object.
    	- Save CNC job (include mill shape in file name).
    	- Save Project.
    	- repeat 2 steps for Bottom layer.
    *************************** Holes ***************************
    Generate Drill file:
    	- select excelon file for alignment holes.
    	- click Properties.
    	- click Drilling - Advanced.
    	- Cut Z = -2.0mm (small), -3.0 (large), -10.0 (Retention Pins).
    	- Travel Z = 1.0mm; height above PCB for traveling.
    	- Feedrate = 25mm/min (large) to 40mm/min (small).
    	- Start Z = 1mm; height when operation starts.
    	- EndMove Z = 25mm; height to raise after operation.
    	- EndMove X,Y = 0,0; return to origin.
    	- Save CNC job (include drill dia in file name).
    	- Save Project.
    ************************** Cut-out **************************
    	- select Gerber file for MechanicalNofiducial.
    	- click Properties.
    	- click Cutout - Advanced.
    	- Tool Diameter = 0.8mm.
    	- Cut Z = -0.5mm (top layer), -1.3mm (bottom layer).
    	- Passes = 0.10mm.
    	- Margin = 0.
    	- Gaps = None.
    	- Save Project.
    Generate CNC file:
    	- click Properties.
    	- Job = Finishing.
    	- Multi Depth = enabled, 0.1mm - 0.15mm.
    	- Margin = 0mm.
    	- Gaps = None.
    	- Travel Z = 1mm.
    	- Feedrate X-Y = 100mm/min - 360mm/min.
    	- Feedrate Z = 10mm/min - 30mm/min.
    	- EndMove Z = 25mm.
    	- Save CNC job (include endmill shape in file name).
    	- Save Project.
    There's been a lot of tweaking and adjusting since day 1. Most of those values are now set as the default values in FlatCAM. I have a lot less room for errors, except in things like trace isolation and PCB cut-outs; I use Milling operation for both of them, but use a V-bit for isolation, and an endmill for cutting out the board. Those 2 bits don't use the same speeds.
    Nice PCB, though it needs sanding as you noted.
    The steps to reach your goal will be valuable for a newbie on the field of CNCing a pcb.
    For one off is great. Do you know what is the smallest part you can do with your CNC?
    Thanks.
    Well, I know this can handle SOIC easily. I'm sure this could handle SSOP. The only limitation is me; my hands shake a bit now. I got some of that low-melt solder and a new hot-air gun to test some SSOP.
    Last weekend I found out that QCAD doesn't have any means of milling slots; so that meant finding another PCB design software. After 30 minutes of research, I had already decided KiCAD was the one to try first. Reviews on the web gave it very high marks, and deservedly so. Took me only 2 days to get "comfy" with it; I love it, very powerful. I had to redo that circuit above from scratch; which was a good learning experience. It gave me a chance to put the 2 screws in a diagonal arrangement, with 2 headers in the opposite corners for stability.
    I uploaded my new design to JLCPCB for the fun of it; just to get an idea on the upcoming costs. 26mm x 18.5mm, panelized 10 rows x 10 columns (even 100 per sheet), 5 sheets. Check this out, $22 excluding shipping. I'm not even gonna bother shopping elsewhere.
    (updated with the silkscreen, paste and mask files for both sides; turns out that's all included in the price)
    I have 6 of these "switch/pot/encoder adapter circuits", 4 secondary boards (maybe 4" x 6"), and one USB master (that won't be very big). It looks possible to keep that under or close to $10 with JLCPCB.
    3D PCB viewer included in KiCAD.
    Wow! :O
    Wow from me too!
    You got all that in a few days? Well, KiCAD will be my next try on PCB software then!
    I use JLCPCB for a long time now and while other competitors may have better quality sometimes, I stick to them because they have DDP option to send in my country. That means I do not have to worry about import taxes and proceedures for this. Love it.
  1. USB interface
    By Frozen001 in forum mel PIC BASIC Pro
    Last Post: - 28th December 2011, 20:37
  2. Host for USB interface?
    By Carrasco in forum Off Topic
    Last Post: - 4th August 2007, 00:59
  3. USB Interface using PIC
    Last Post: - 22nd May 2006, 17:04
  4. USB interface from PIC16F877 to PC
    By headshouter in forum USB
    Last Post: - 26th February 2006, 05:58
  5. USB project
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 18th January 2005, 22:59
Members who have read this thread : 7
