12F675 - How to configure the INTCON command to activate the various interrupts?
Results 1 to 14 of 14
    Feb 2022
    Default Re: 12F675 - How to configure the INTCON command to activate the various interrupts?
    Hi, Richard,
    I will carefully read your .txt files.
    But I really only master Basic... not really ASM
    not sure if I have to point out the obvious but
    what sort of file would "ZORB.pbp.txt" if you took the ".txt" off the end ?
    [the pbp forum will not allow a pbp file to be uploaded , you need to mask its type with a .txt extension]
    such a limited outlook
    good luck employing interrupts in any other way with such limited chips as 12f675
    " not sure if I have to point out the obvious" but you often have some degrading, demeaning cutting comment to people seeking help. Basically a reflection of yourself......
    please delete this
    i read that as either a lack of understanding on how files are uploaded onto the forum or
    a intimation that i have uploaded something weird, unusual or incorrect. i don't know which
    but either way since it was specifically pointed out an explanation was warranted
    not sure if I have to point out the obvious but...
    makes it clearer why the txt extension is there and how to deal with it, just in case an explanation was
    necessary
    really
    OK
    To activate a single I/O pin as IOC (Interrupt on Change) you use the "IOC" Register; Register 3.4 in the Data Sheet:
    IOC.0 = 1  'Enables IOC on GPIO 0
    If you want to enable IOC interrupts on multiple GPIO pins you can use the IOC Register in binary mode. Assume you want an IOC Interrupt on GPIO pins 0 & 1:
    IOC = 000011  'Enables IOC on GPIO 0 & 1
    Then you must enable IOC interrupts using the INTCON Register:
    INTCON.3 = 1  'Enables IOC Interrupts
    Next, you need to create an Interrupt Handler (See PBP Manual) so when you get the Interrupt, you can do something with it. In your Interrupt Handler, when you get an IOC interrupt you have to clear the Interrupt Flag:
    INTCON.0 = 0  'Clears IOC Interrupt Flag
    If you need more than one GPIO IOC Interrupt (2 or more Port Pins), you will have to Poll which GPIO triggered the IOC Interrupt:
    IF GPIO.0 = 1 THEN
      <Interrupt Handler Code for GPIO.0>
    ELSE IF GPIO.1 = 1 THEN
      <Interrupt Handler Code for GPIO.1>
    The above code assumes that a low-to-high transition triggers your IOC interrupt. You may need to change that depending on your goals.
    <edit> I tried to write "IOC = 000011 'Enables IOC on GPIO 0 & 1" but the forum keeps changing it to "IOC = 000011 'Enables IOC on GPIO 0 & 1"
    not forgetting :-
    A mismatch condition will continue to set flag bit GPIF.
    Reading GPIO will end the mismatch condition and
    allow flag bit GPIF to be cleared.
  1. Basic problem with interrupts and sleep command
    By Davidmarks in forum mel PIC BASIC Pro
    Last Post: - 21st February 2012, 01:21
  2. CONFIGURE & OSCCON & meProg configure
    By SUNFLOWER in forum mel PIC BASIC Pro
    Last Post: - 19th February 2011, 21:25
  3. How to activate ccp3 on portB.5 of 16f777 ?
    By abdullahsavas in forum mel PIC BASIC Pro
    Last Post: - 16th June 2010, 08:17
  4. EEPROM Write command with interrupts??
    By Elnino in forum General
    Last Post: - 23rd November 2009, 06:44
  5. intcon?
    By jonas2 in forum mel PIC BASIC Pro
    Last Post: - 23rd September 2009, 11:07
