12F675 - How to configure the INTCON command to activate the various interrupts?
Results 1 to 14 of 14
    Feb 2022
    Default 12F675 - How to configure the INTCON command to activate the various interrupts?
    Good morning
    As I am new to understanding and using Interrupts, could you explain to me the configuration of the INTCON command for a small PIC12F675?
    The PBP manual gives as an example:
    INTCON = %10010000 ' Enable RB0 interrupt
    But I don't know for which PIC this command is valid (because I imagine it varies depending on the PIC used?).
    Unless I am mistaken, the 6 ports of the PIC12F675 would make it possible to cause interrupts.
    What would then be the commands to activate the various interrupts on GP0,1,2,3,4 and5 ?
    Thanks all.
    Default Re: 12F675 - How to configure the INTCON command to activate the various interrupts?
    intcon is not a command, its a special function register
    while the intcon reg is fairly similar in operation across the pic spectrum you need to always consult the data sheet for your chip
    to ensure correct usage for the type/s of interrupt in question
    the data sheet also has a section on interrupt types and how to configure them
    the data sheet also will spell out how to save and restore mcu context to incorporate in your isr [interrupt service routine]code
    the data sheet also has a section on ioc [int on change] for the gpio on that chip
    there is no pbp command for that you need to set the appropriate registers yourself , properly of course
    trisio,ioc, intcon
    Feb 2022
    Indeed, INTCON is not strictly speaking a "command" but a configuration of the bits of the INTCON register obtained by a "line of code" of the style INTCON = 10010000.
    I obviously consulted the datasheet of the PIC12F675 on the page relating to the INTCON register. (see attached jpg)
    However, I do not see how to configure the six available ports.
    At first, I would already be well advanced for my project if I could define an interrupt on the GP0 port.
    For the others, we will see later with the assistance of the available specialists of this forum whom I already thank in advance.
    Name:  12F675 INTCON Register .jpg
    Name:  12F675 INTCON pin functions.jpg
    REGISTER 3-4: IOC: INTERRUPT-ON-CHANGE GPIO REGISTER (ADDRESS: 96h)
    Feb 2022
    In fact, I'm more of a PICAXE user and I transform my "simple" codes with PBP to program small PICs.
    I was trying to use interrupts...
    The subtleties of the PICs are therefore quite nebulous for me and my English is not flexible and subtle enough to understand the mysteries of the data sheets.
    In fact what I wanted to do initially seemed easy to me... but it doesn't seem to be the case
    I just want to vary a variable named MODE from 0 to 3, 0 to 3, ..., when port GP0 (which has a pull-up resistor to Vcc) goes to zero state.
    If someone could help me out with just this little routine, that would be great.
    Thanks in advance.
    '*  Name    : ioc-demo-12f675.BAS                               *
    '*  Author  : richard                                           *
    '*  Notice  : Copyright (c) 2023 caveat emptor                  *
    '*  Date    : 22/04/2023                                        *
    '*  Notes   : 12f675 ioc gpio.0                                 *
    cfg = _INTRC_OSC_NOCLKOUT
    cfg&= _WDT_ON
    cfg&= _PWRTE_OFF
    cfg&= _MCLRE_ON
    cfg&= _BODEN_ON
    cfg&= _CP_OFF
    cfg&= _CPD_OFF
      __CONFIG cfg
    DEFINE INTHAND    poll
    wsave VAR BYTE    $20     SYSTEM
    ssave VAR BYTE    BANK0   SYSTEM
    mode  var byte
    DUMMY VAR BYTE
    INPT  VAR GPIO.0
    LED   VAR GPIO.1
    cmcon = 7
    ANSEL = 0
    TRISIO.0 = 1
    TRISIO.1 = 0
    IOC.0 = 1
    MODE = 3
    DUMMY = GPIO
    INTCON = 001000
    LED = 1
    MAIN:
        IF  ! MODE THEN
            LED = 0
            LED = 1
            mode = 3
            DUMMY = GPIO
            INTCON = 001000
        PAUSE 10
    GOTO MAIN
    asm
    poll
        MOVWF wsave
        SWAPF STATUS,W
        BCF STATUS,RP0
        MOVWF ssave
        BANKSEL _mode
        clrf _mode
        SWAPF ssave,W
        MOVWF STATUS
        SWAPF wsave,F
        SWAPF wsave,W
    Feb 2022
    Thank you all.
    I will try to assimilate all these notions.
    Have a good day.
  1. Basic problem with interrupts and sleep command
    By Davidmarks in forum mel PIC BASIC Pro
    Last Post: - 21st February 2012, 01:21
  2. CONFIGURE & OSCCON & meProg configure
    By SUNFLOWER in forum mel PIC BASIC Pro
    Last Post: - 19th February 2011, 21:25
  3. How to activate ccp3 on portB.5 of 16f777 ?
    By abdullahsavas in forum mel PIC BASIC Pro
    Last Post: - 16th June 2010, 08:17
  4. EEPROM Write command with interrupts??
    By Elnino in forum General
    Last Post: - 23rd November 2009, 06:44
  5. intcon?
    By jonas2 in forum mel PIC BASIC Pro
    Last Post: - 23rd September 2009, 11:07
