wrong positive and negative voltages on lcd 20x4
Results 1 to 14 of 14
    Default Re: wrong positive and negative voltages on lcd 20x4
    I think you gonna have to post the code, otherwise it's kind of hard...
    Jul 2022
    'Config for 16f886
        __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_ON & _LVP_OFF & _CP_ON & _CPD_ON
    include "fp2032.bas"    ' Include file for 14-bit core with RAM at $20 (32-bit)
    define OSC  8
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTC
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTC
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 3
    DEFINE ADC_ SAMPLEUS 50
    LED VAR PORTC.4
    TXD VAR PORTC.6
    B1 VAR WORD
    B2 VAR WORD
    VALOR1 VAR BYTE
    VALOR2 VAR BYTE
    fpplaces  var  byte     ' Used to define number of decimal places in fpdisplay,fpdisplayr
    ahold    var   word     ' Required by fpdisplay
    bhold    var   word     ' Required by fpdisplay
    INICIO:
             TRISC.6 = 0          'in
             TRISC.7 = 1          'out
             TRISA = 255          'Port_A = in
             ADCON1 = %11000010   'left alignment
             TRISB.6 = 0          'out
             LCDOUT  $FE,2,"  FUENTE SIMETRICA  "     '1_line
             LCDOUT  $FE,$C0," JOSE LUIS COMAS LL "   '2_line
             LCDOUT  $FE,$94,"VOLT.NEGATIVO:-"        '3_line
             LCDOUT  $FE,$D4,"VOLT.POSITIVO:+"        '4_line
    COMENZAR:
             ADCIN 1, B1    'read negativ via chanal_1_ADC
             ADCIN 2, B2    'read positiv via chanal_2_ADC
             'send ADC to terminal
             SEROUT2  TXD,188,["$", "$", DEC4 B1,"$", "$",DEC4 B2,10,13]
             aint = B1      'read -volt_to+B1
             gosub itofa    'Conviertelo a punto flotante
             bint = 2000    'Carga el valor 2000 (5*400)
             gosub itofb    'Conviertelo en punto flotante
             gosub  fpmul   'ADCres * 2000
             bint = 52224   'Carga el valor de la cuenta maxima del ADC * 51
             GOSUB  fpdiv   '(ADCres * 2000)/52224
    'pv         LCDOUT  $FE,$A3,"     "    'Limpia el espacio donde se coloca el voltaje negativo
             LCDOUT  $FE,$A3
             fpplaces = 2 : Gosub fpdisplayr    ' Call display routine
             aint = B2      'Transfiere el valor del ADC del voltaje positivo
             bint = 35      'Carga el valor 35 (5*7)
             gosub  fpmul   'ADCres * 35
             bint = 1024    'Carga el valor de la cuenta maxima del ADC
             GOSUB  fpdiv   '(ADCres * 35)/1024
    'pv         LCDOUT  $FE,$E3,"     "    'Limpia el espacio donde se coloca el voltaje positivo
             LCDOUT  $FE,$E3
             HIGH LED
            GOTO COMENZAR
    ' The fpdisplayr routine checks for number of places, then adds the appropriate
    ' value to achieve rounding.  To save RAM space, the values are hard coded
    ' in floating point format.
    fpdisplayr: If fpplaces=0 Then                  ' Set floating point barg to 0.5
                            bexp = $7E
                            bargb0 = $00
                            bargb1 = $00
                            bargb2 = $01
                      Endif
                      If fpplaces=1 Then                  ' Set floating point barg to 0.05
                            bexp = $7A
                            bargb0 = $4C
                            bargb1 = $CC
                            bargb2 = $CD
                      Endif
                      If fpplaces=2 Then                  ' Set floating point barg to 0.005
                            bexp = $77
                            bargb0 = $23
                            bargb1 = $D7
                            bargb2 = $0B
                      Endif
                      If fpplaces=3 Then                  ' Set floating point barg to 0.0005
                            bexp = $74
                            bargb0 = $03
                            bargb1 = $12
                            bargb2 = $6F
                      Endif
                      If fpplaces=4 Then                  ' Set floating point barg to 0.00005
                            bexp = $70
                            bargb0 = $51
                            bargb1 = $B7
                            bargb2 = $17
                      Endif
                      Gosub fpadd                         ' add barg to aarg
    ' The fpdisplay routine outputs the signed value of aarg in decimal floating point format. It
    ' can display a positive value of 65535, and decimals to 4 places. The number of decimal
    ' places should be stored in fpplaces before calling the routine. The routine reads the
    ' floating point value of aarg. This value should NOT be converted to an integer before
    ' calling fpdisplay. The integer conversion will be perfomed as part of this routine, and
    ' aint will be returned to the calling program just as from the itofa routine.
    fpdisplay:  bexp = aexp                         ' Store the FP value of aarg to the barg variables
                      bargb0 = aargb0
                      bargb1 = aargb1
                      bargb2 = aargb2
                      Gosub ftoia                   ' Convert aarg to integer
                      ahold = aint                        ' Save this value for the final display
                      Gosub itofa                   ' Convert integer back to float
                      Swap aexp,bexp                      ' Swap the FP values of aarg and barg before subtraction
                      Swap aargb0,bargb0
                      Swap aargb1,bargb1
                      Swap aargb2,bargb2
                      Gosub fpsub                   ' Subtract the integer portion from the full number
                      bint = 10                     ' Make bint = 10 E fpplaces
                      If fpplaces=2 Then
                            bint = 100
                      Endif
                      If fpplaces=3 Then
                            bint = 1000
                      Endif
                      If fpplaces=4 Then
                            bint = 10000
                      Endif
                      bhold = bint                        ' Save the integer value of bint for zeros loop
                      Gosub itofb                   ' Convert bint to integer prior to FP multiply
                      Gosub fpmul                   ' Multiply the decimal portion x 10 E fpplaces
                      Gosub ftoia                   ' Convert result to aint integer
                      Lcdout dec ahold              ' Display integer portion
                      If fpplaces > 0 Then                            
                            Lcdout "."              ' Display decimal point
    zeros:                  bhold = bhold / 10                                          ' Set bhold to be next place to right
                            If (aint < bhold) AND (bhold > 1) Then          ' Check for leading zero in decimal
                                  Lcdout "0"                                            ' Display leading zero
                                  Goto zeros                                            ' loop to check for another zero
                            Endif
                            Lcdout dec aint               ' Display the rest of the decimal portion
                      Endif
                      aint = ahold                        ' Restore the original value of aint
    'pv         LCDOUT  $FE,$A3
    'pv         LCDOUT  $FE,$E3
    thanks for answering
    I attach the code
    Jul 2022
    https://drive.google.com/file/d/11pN...uhMMrPdIk/view
    I attached a video link where you will see the code failure.
    You will see in the ldc 20x4 the negative voltage is displayed very quickly, the lcd will register voltage 12.45 and in the proteus dc voltmeter it registers 12.5V
    in the 20x4 lcd it registers a positive voltage of 12.58, it displays normal and in the dc voltmeter of proteus it will register a voltage of 12.6V.
    You will see that the decimals record different values of both positive and negative voltages.
    I hope that the video can serve you better to see and correct the code.
    thank you
  1. Monitoring negative voltages
    Last Post: - 16th August 2014, 05:17
  2. Pic18f452 with 20x4 LCD Help
    By djmachine in forum mel PIC BASIC Pro
    Last Post: - 6th November 2008, 23:43
  3. Measuring negative voltages
    By sammy in forum mel PIC BASIC Pro
    Last Post: - 13th June 2006, 02:36
  4. 20x4 LCD and P18F2680
    By microuser in forum mel PIC BASIC Pro
    Last Post: - 9th June 2006, 20:26
  5. LCD 20X4 connect with DS1820
    By jojokatada in forum mel PIC BASIC Pro
    Last Post: - 9th March 2005, 12:04
