Can such interface be handled with SHIFTOUT? (Macroblock MBI5026 LED driver)
Results 1 to 10 of 10
    Default Re: Can such interface be handled with SHIFTOUT? (Macroblock MBI5026 LED driver)
    variable is already WORD.
    I tried to add \16 to shiftout, but still nothing...
    Aug 2011
    What value of REXT do you have?
    Just to be sure... it's a sink driver so you do have the LEDs connect the right way around - anode to +V, cathode to 5026 output pin), right?
    Rext is 2.2K
    LEDs are connected in a proper way - I tried to ground the LED pin going into the chip via 220 ohm resistor - it came on.
    So I guess, maybe I need to change state of the OE pin too? Currently I have it grounded.
    Aug 2011
    That all looks right according to the datasheet... OE is low-active so grounding it should be ok.
    So, back to basics then.
    Make sure you don't have anlog functions enabled on the pins you're trying to use. Verify that you can control the state of each indivivual pin that you're using.
    After that (or before if you'd rather) it's time to hook up the scope or logic analyzer to verify that what you get is what you want.
    yes, checked all that
    tried to pull CLK, SDI, LE pins high/low - all work fine. Checked all wirings and contacts - everything is fine.
    A little note - voltage on all output pins is about +3V regarding to GND, and does not change whatever command I send.
    Tried to play with OE pin - no change, it does not care whenever pull it high or low...
  1. i2c interface with LED driver PCA9532
    By koodiifin in forum mel PIC BASIC Pro
    Last Post: - 13th July 2012, 19:04
  2. RGB led driver ic lpd6803
    By m_flfl in forum General
    Last Post: - 29th May 2012, 19:49
  3. Using MAX 7221 LED driver
    By Nick in forum mel PIC BASIC
    Last Post: - 21st October 2010, 19:31
  4. Help with LED driver fade on/off
    By dfort in forum mel PIC BASIC Pro
    Last Post: - 25th July 2009, 00:39
  5. MM5451 35way LED driver example
    By J_norrie in forum Code Examples
    Last Post: - 12th May 2008, 09:16
