Window Comparator and Direction
Results 1 to 5 of 5
    Default Re: Window Comparator and Direction
    If your ADC is the ADC inside the PIC then it is a possitive value.
    If you use external ADC then I guess it can be negative also.
    Dec 2021
    Illinois, USA
    Red face Re: Window Comparator and Direction
    I am using the internal ADC on the PIC18F45K80 but the question I was having was determining if I was inside a window of +/- 40 counts. I was concerned that RefPosition - CurPosition could give me a negative result but I see how to handle it now. Thanks for all the help.
  1. Replies: 2
    Last Post: - 31st May 2013, 18:19
  2. Check within a 16 bytes window
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 29th November 2012, 11:54
  3. trying to do a scroll window
    By AvionicsMaster1 in forum Test Area
    Last Post: - 7th September 2011, 14:00
  4. Button Push within 3 second Window
    Last Post: - 22nd December 2005, 10:06
  5. Time window
    By Franko in forum mel PIC BASIC Pro
    Last Post: - 9th August 2005, 16:42
