Hef/saf eeprom
Results 1 to 8 of 8
Thread: Hef/saf eeprom
    Default Hef/saf eeprom
    Anybody used HEF/SAF memory are with PBP ?
    Default Re: Hef/saf eeprom
    Do not bother. I found the Richards great posts.
    I only wish it was not so ... assembly!
    Care to a link to the thread/post in question?
    Sure!
    Post #4
    https://www.picbasic.co.uk/forum/sho...rking-with-HEF
    Needs to be adapted to your eeprom I guess. Have not tested yet.
    be aware that I made use of the full 14 bit width of the flash in that code, the data sheet says that only the low byte is high endurance.
    the repercussions of making use the high byte too is not known to me. i have never used hef in any strenuous way, ever.
    Thanks for the warning.
    I do not have an alternative as the chip I need to use (16F1779) does not have other EEPROM. Only HEF.
    If I can spare a couple of pins, maybe an external EEPROM will save the day.
    use the hef by all means , preferably as bytes ie the low byte . just mask off the high byte and leave it set to 255
    so you don't keep trashing it
    I understand, its just gets too complicated to use the HEF area.
  1. HEF EE OK with WRITE ?
    By dsicon in forum PBP3
    Last Post: - 6th February 2021, 07:41
  2. Working with HEF
    By mpgmike in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2017, 17:16
  3. HEF (High Endurance Flash) What to do?
    By mehmetOzdemir in forum mel PIC BASIC Pro
    Last Post: - 6th June 2016, 06:25
  4. Eeprom
    By atwoz in forum General
    Last Post: - 20th December 2007, 04:05
  5. EEprom
    By lerameur in forum General
    Last Post: - 23rd November 2006, 05:30
