Time taken to do mainloop
Results 1 to 5 of 5
    Mar 2023
    Cape Town, South Africa
    Default Time taken to do mainloop
    Okay, I have now got a functional program and don't need to do any further programming till I have tested on a real life scenario. But I am curious about how the internal clock of the PIC12F683 decides when to repeat the mainloop: (sub-routines omitted for clarity)
    __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    clear
    TRISIO.4 = 0 ' GPIO.4 as output
    ANSEL = 0
    CMCON0 = 7
    OPTION_REG.7 = 0 ' Enable individual pullups
    WPU=%000101 ' Enable weak pullups on GPIO.0 & GPIO.2
    LEDIN VAR GPIO.3 ' Assign name "LEDIN" to GPOI 3 INPUT (yoctop green led)
    RECPB var GPIO.4 ' Assign name "RECPB" to GPIO 4 OUTPUT
    CYCLE var GPIO.0 ' Assign name "CYCLE" to GPIO 0 INPUT
    TRIG var GPIO.2 ' Assign name TRIG to GPIO 2 (from manual trigger) INPUT
    LC var word ' timing auto loop counter 0 - 60000
    k var word
    TT var word ' TRIG hold down time
    high RECPB
    low gpio.1
    Mainloop:
    pause 1 'run cycle at approx 1.73 ms intervals (I thought 1 = 1 second intervals?)
    if LEDIN = 0 then 'Invert green LED of yoctop
    low gpio.1 'to new red LED
    endif '
    if LEDIN = 1 and LC > 4500 then 'only show red LED in 57s silent phase
    high gpio.1 '
    endif '
    TT = 0 ' Reset trigger timer
    If CYCLE = 0 then ' START ONE MINUTE LOOP
    LC = LC+1
    if LC > 1 and LC < 500 then 'press RECPB to start snippet recording
    low RECPB
    if LC > 499 and LC < 1900 then '1900 counts give 3.0 sec recording
    high RECPB
    if LC > 1899 and LC < 2400 then 'press RECPB to end snippet recording
    low RECPB
    if LC > 2399 then 'release RECPB
    high RECPB
    if LC > 34650 then ' 34650 loop counts over 1 minute (this equates to 60 seconds)
    LC = 0
    if CYCLE = 1 and LC > 1 and LC <1950 then '
    low RECPB ' Switch off CYCLE while recording
    Pause 500 ' hold button down a little
    high RECPB
    LC = 0
    if TRIG = 0 and LC < 2400 then ' Press TRIG while already recording
    LC = 0
    gosub ManRecordExtend 'Extend an active recording
    if TRIG = 0 and LC > 2399 then 'Manual record in silent phase
    LC = 2401
    gosub ManRecordSilent
    GOTO Mainloop ' END ONE MINUTE LOOP
    Mar 2023
    Default Re: Time taken to do mainloop
    PS. How should one paste code into this forum?
    The program runs as fast as it can and the execution time of each iteration thru the loop depends on the code that is executed at that iteration. In other words, which IF statements evaluates to true and which doesn't.
    For example:
      TOGGLE GPIO.0
      PAUSE 1
    GOTO Main
    This will take the same amount of time each iteration and it's 1ms (which is the PAUSE statement) + however long the TOGGLE command takes (a couple of instruction cycles) + another two instruction cycles for the GOTO command.
    If the PIC runs at 4MHz each instruction cycle is 1us. Most ASM commands executes in one cycle, some (like jumps) takes two. Each PBP statements gets translated into several ASM instructions and there's no list of how many that is because it varies depending on various things.
    If you want to KNOW how fast your program runs the easiest way is to measure it. If you NEED it to run at specific pace you should resort to using a timer.
    To add code in a frame use:
    [ code ]
    code....
    [ /code ]
    but without the space characters that I added for obvious reasons.
    Mar 2023
    For example:
      TOGGLE GPIO.0
      PAUSE 1
    GOTO Main
    For those that sent private messages; I have a trigger button near my hand. A short press makes an immediate 3.5 second video and restarts the mainloop at the beginning of the 57 sec "mute" time. A long press records until the trigger is released. If mainloop is busy recording, the trigger extends that recording.
    Thank you Henrik. I get a very repeatable 3 seconds of video recording every minute. I used a video of a "stopwatch" to calibrate the numbers:
    This does not need to be very precise. I just wanted to understand it better. When I get back from a long roadtrip in May, I will experiment further with the code, primarily to add watchdogs for things going wrong. Eg. No recording for 2 minutes, a recording longer than 20 seconds. The primary purpose of the system is to be able to use one SD card in the camera for 3 weeks and not fill it in a day or two.
  1. Outside the Mainloop
    By pescador in forum General
    Last Post: - 26th April 2016, 18:34
  2. PIC 18F1330 - first time, hard time - blink that LED
    Last Post: - 1st March 2015, 23:33
  3. How best to time a pin state for extended periods of time
    By Hylan in forum mel PIC BASIC Pro
    Last Post: - 10th March 2011, 12:20
  4. DS1904 RTC - How to Convert Binary Time into Real Time/Date?
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2010, 11:45
  5. Linx RF -> HSERIN time delay / time critical app...
    By batee in forum mel PIC BASIC Pro
    Last Post: - 15th October 2004, 16:04
