fatal error [301] out of memory with 4 lines of code????
Results 1 to 7 of 7
    http://www.microengineeringlabs.com/...4.htm#02070858
    what happen if you install MPASM and use it instead of PM or PBPW
    New Zealand
    might give it a go tomorrow thanks, but it's weird cos I've done quite big programs in the past and never had an such issue letalone turning a port on and off, the computer I'm using has 512MB ram - not way powerful but I would have thought good enough
    New Zealand
    I've modified the code and ripped out everything except the "start: and Goto Start"
    It compiled with 4 words successfully - yay.
    However I need a program with a bit more in it than start and goto start.
    I tried on different chips but have the same problem - however when I use v2.42 it compiles fine. I've deleted v2.46 and reinstalled it however still no joy. So I'm assuming it's a problem with v2.46 but would think other people would have come across the same issue. I might also try on a diff computer tonight to see what happens.
    my biggest issue is that 2.42 doesn't support the 16F88
    maybe, i said maybe, the update patch could help. Look on the MELABS website for that.
    Out of memory errors like this are normally due to using PBP.EXE instead of PBPW.EXE which is the Windows executable, and it handles memory much better than the DOS command line executable PBP.EXE.
    Be sure you're pointing your editor to PBPW.EXE VS PBP.EXE. Should cure the problem.
    I just got version picbasic Pro 2.46
    If you have an older version of PBP installed on the same machine, make sure your using the new version.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    New Zealand
    Talking
    FIXT IT!!!
    With help from Charles at MeLabs,
    Under PBPW.EXE properties in windows, set compatibility to windows 98/me and all solved.
  1. decoding quadrature encoders
    By ice in forum mel PIC BASIC Pro
    Last Post: - 28th February 2017, 10:02
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. Making Program Code Space your playground...
  4. Spooked code lines
    By POLA in forum General
    Last Post: - 27th March 2005, 21:40
  5. character lcd 4 lines
    By jojokatada in forum PBP Wish List
    Last Post: - 4th February 2005, 16:35
