Using same button for entering/exiting some part of code?
Results 1 to 18 of 18
    OK
    Default Re: Using same button for entering/exiting some part of code?
    You could create a bit Flag. When the Button is pressed, the Flag is toggled. When you get to a reasonable point in Code1 Routine, check your Flag. If it has toggled (is now a 1 for example), use GOTO to jump to Code2. Put "IF Flag = 0 THEN : GOTO Code1" in convenient spots throughout in Code2, etc.
    debounce button check... and instead of while-wend .... use for/next pause here is 2 second check so if holding button > 2 seconds, can advance MENUitem then check again for release
    HERE:
    IF UPBT=0 THEN
    pause 50
    IF UPBT=0 THEN ..............................#debounce check
    MENUITEM=MENUITEM+1
    IF MENUITEM>6 THEN MENUITEM=1
    PAUSE 20
    for a=1 to 20
    pause 50................................................ ............# if 2 second press, advance item and wait again
    IF UPBT=1 THEN ---leave to somewhere .................# XXXXX WHILE UPBT=0:WEND
    next a
    goto HERE
    First I would read all button input at once. Debounce and then decide what to do.
    This is like a state machine coding and you will not loose any keypress, especially if it is interrupt driven. Or if you do not want interrupts, then a tight loop can do the job just fine.
    Spaghetti coding unfortunately leads to such results.
    Thanks everyone. I've modified that code in the way that it now works - there is additional check for MENUITEM value inside a button press loop, but the question is still active - why the code above slows down in that way? That's simply not logical.
    if there is room, you could put some 'temporary' code to serout or debug at a few locations and see where it isn't doing what is expected ! looks like there are quite a number of 'states' your program could be looping through.
  1. Final Button Code
    By WarPony in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2008, 15:14
  2. Help with code, button
    By xobx in forum mel PIC BASIC Pro
    Last Post: - 15th July 2007, 18:52
  3. Entering the number from keypad...
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 27th April 2007, 10:02
  4. Code entering endless loop
    By Blackhawk in forum mel PIC BASIC
    Last Post: - 26th November 2006, 10:12
  5. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
