Using same button for entering/exiting some part of code?
Results 1 to 18 of 18
    Default Re: Using same button for entering/exiting some part of code?
    Here is the practical code I'm using, but it sometimes behaves strangely.
    Say, button was pressed, action was made once, user still holds button, so no advance in code. But when user releases the button, sometimes it acts as button was pressed once again. Any ideas how to fix it?
    MENULOOP: 'MAIN CONFIG SCREEN
    IF UPBT=0 THEN
    MENUITEM=MENUITEM+1
    IF MENUITEM>4 THEN MENUITEM=1
    GOSUB CENTRAL
    pause 200 'debounce
    WHILE UPBT=0:WEND
    IF DNBT=0 THEN
    MENUITEM=MENUITEM-1
    IF MENUITEM<1 THEN MENUITEM=4
    GOSUB CENTRAL
    pause 200 'debounce
    WHILE DNBT=0:WEND
    if menuitem=1 and rbut=0 then
    pause 5
    while rbut=0: wend
    goto clockconfig
    GOTO MENULOOP
    There does not seem to be any debounce on button release. Try
      IF UPBT=0 THEN
        MENUITEM = MENUITEM+1
        IF MENUITEM > 4 THEN MENUITEM = 1
        GOSUB CENTRAL
        ' PAUSE 20          ' May be needed if subroutine CENTRAL executes very fast.
        WHILE UPBT = 0 : WEND
        PAUSE 20 'debounce
    read switch a few times to be sure and debounce......
    IF UPBT=0 THEN
    PAUSE 20 ' or 40 or 50
    IF UPBT=0 THEN 'go ahead........
    do same for release check .... if upbt=1 then.....
    For couple of buttons this code works fine, but when I increase number of button handling operations, some weird things occur - the further from beginning is the button handling routine, more rarely it responds to user.
    The code below has 8 "blocks" of button handling.
    first 3 work fine, 4th one works only maybe on 10 or 15th press. 5th and further - do not work at all.
    And this is not issue of particular code - if I move say "5th block" to 1st place of this code, then it works fine.
    PIC18F45K80 @64mhz.
    IF UPBT=0 THEN
    MENUITEM=MENUITEM+1
    IF MENUITEM>6 THEN MENUITEM=1
    pause 200
    WHILE UPBT=0:WEND
    IF DNBT=0 THEN
    MENUITEM=MENUITEM-1
    IF MENUITEM<1 THEN MENUITEM=6
    pause 200
    WHILE DNBT=0:WEND
    IF LBUT=0 AND MENUITEM=2 THEN
    RICXVI=RICXVI+1
    IF RICXVI>31 THEN RICXVI=1
    pause 200
    GOSUB SETTIME
    WHILE LBUT=0:WEND
    IF RBUT=0 AND MENUITEM=2 THEN
    RICXVI=RICXVI-1
    IF RICXVI<1 THEN RICXVI=31
    pause 200
    GOSUB SETTIME
    WHILE RBUT=0:WEND
    IF LBUT=0 AND MENUITEM=1 THEN
    TVE=TVE+1
    IF TVE>13 THEN TVE=1
    pause 200
    GOSUB SETTIME
    WHILE LBUT=0:WEND
    IF RBUT=0 AND MENUITEM=1 THEN
    TVE=TVE-1
    IF TVE<1 THEN TVE=13
    pause 200
    GOSUB SETTIME
    WHILE RBUT=0:WEND
    IF LBUT=0 AND MENUITEM=3 THEN
    DGE=DGE+1
    IF DGE>7 THEN DGE=1
    pause 200
    GOSUB SETTIME
    WHILE LBUT=0:WEND
    IF RBUT=0 AND MENUITEM=3 THEN
    DGE=DGE-1
    IF DGE<1 THEN DGE=7
    pause 200
    GOSUB SETTIME
    WHILE RBUT=0:WEND
    I tried to reduce PAUSE 200 to 20 or even 2 - no change.
    Aug 2011
    what about something like this instead?
    IF UPBT=0 THEN
        MENUITEM=MENUITEM+1
        PAUSE 20
        WHILE UPBT=0:WEND
        PAUSE 20
    IF DNBT=0 THEN
        MENUITEM=MENUITEM-1
        PAUSE 20
        WHILE DNBT=0:WEND
        PAUSE 20
    IF LBUT=0 THEN
        IF MENUITEM=1 THEN
            TVE=TVE+1
            GOSUB SETTIME
        IF MENUITEM=2 THEN
            RICXVI=RICXVI+1
            GOSUB SETTIME
        IF MENUITEM=3 THEN
            DGE=DGE+1
            IF DGE>7 THEN DGE=1
            GOSUB SETTIME
        PAUSE 20
        WHILE LBUT=0:WEND
        PAUSE 20
    IF RBUT=0 THEN
        IF MENUITEM=1 THEN
            TVE=TVE-1
            GOSUB SETTIME
        IF MENUITEM=2 THEN
            RICXVI=RICXVI-1
            GOSUB SETTIME
        IF MENUITEM=3 THEN
            DGE=DGE-1
            IF DGE<1 THEN DGE=7
            GOSUB SETTIME
        PAUSE 20
        WHILE RBUT=0:WEND
        PAUSE 20
    it could be simplified even more, but...
    OK
    You could create a bit Flag. When the Button is pressed, the Flag is toggled. When you get to a reasonable point in Code1 Routine, check your Flag. If it has toggled (is now a 1 for example), use GOTO to jump to Code2. Put "IF Flag = 0 THEN : GOTO Code1" in convenient spots throughout in Code2, etc.
  1. Final Button Code
    By WarPony in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2008, 15:14
  2. Help with code, button
    By xobx in forum mel PIC BASIC Pro
    Last Post: - 15th July 2007, 18:52
  3. Entering the number from keypad...
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 27th April 2007, 10:02
  4. Code entering endless loop
    By Blackhawk in forum mel PIC BASIC
    Last Post: - 26th November 2006, 10:12
  5. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
