Using same button for entering/exiting some part of code?
Results 1 to 18 of 18
    Default Re: Using same button for entering/exiting some part of code?
    I made a multi-function timer that deals with that and does different things according to how long sw is pressed ( and improved it to a touch sw using a/d)...... simply loops through routines using counts of pauses between sw presses.
    part of sw press checks......
    FOR B5= 1 TO 10 '.1 SECONDS FOR TIMER
    PAUSE 6
    if GPIO.1= 1 then start
    NEXT B5
    read 1,b6 :PAUSE 10: W0=60*B6:W1=W0
    HIGH 4 ': HIGH 2
    FOR B5 = 1 TO 100 '2 SECONDS FOR 6 HR
    PAUSE 10
    if GPIO.1=1 then TIMER
    NEXT B5
    W0=28800 '8 HRS
    HIGH 2
    You might do something like this:
    Obvioulsy you can't have code that takes a long time to exectute in each section or you'll miss the button press. If that's the case, move the code that handles the button to a subroutine and call that routine multiple times from within the section(s) that takes the longest time.
    ButtonPressed          CON 0
    FirstPieceOfCode       CON 1
    LastPieceOfCode        CON 3
    CodeToRun              VAR BYTE
    ButtonHasBeenPressed   VAR BIT
    ChangeButton           VAR PortB.2
    CodeToRun              = FirstPieceOfcode
    ButtonHasBeenPressed   = 0
      If ChangeButton = ButtonPressed THEN
        ButtonHasBeenPressed = 1
      IF (ButtonHasBeenPressed = 1) AND (ChangeButton <> ButtonPressed) THEN  ' But was pressed but is now released
        CodeToRun = CodeToRun + 1             ' Advance to next code section
        If CodeToRun > LastPieceOfCode THEN   ' Wrap around and start over
          CodeToRun  = FirstPieceOfCode
      Select Case CodeToRun
        Case 1
           'Some code
       Case 2
           'Some other code
        Case 3
           'Yet some other code
      END SELECT
    Goto Main
    This is not tested or even compiled so use it as an idea.
    I think, there is some misunderstanding.
    Here what I need
    code1:
    if button=0 then goto code2
    'somecode here
    goto code1
    code2:
    if button=0 then goto code1
    'somecode here
    goto code2
    So all I need is when user presses the button in code1, execution won't jump to code2 until he releases the button. And same for code2.
    The code I posted should do exactly with that, with the advantage that the section of code you're currently in will continue to run UNTIL you release the button. What you're proposing will HANG the current program section until you release the button. But here you go:
    code1:
    if button=0 then     'check if button is pressed
      PAUSE 5                       'allow some contact bounce
      WHILE button=0 : WEND  'wait for it to be released
      goto code2
    'somecode here
    goto code1
    code2:
    if button=0 then
      WHILE button = 0 : WEND
      goto code1
    'somecode here
    goto code2
    and obviously, button is a reserved word.
    Thanks!
    No problem for code to "Hang", since this is for going from main menu to sub-menu and back.
    my experience with button press usage is to have to wait for button release, can either stay in present routine and wait before switching OR moving to other routine and wait for release before looking for new press and going back.
    Here is the practical code I'm using, but it sometimes behaves strangely.
    Say, button was pressed, action was made once, user still holds button, so no advance in code. But when user releases the button, sometimes it acts as button was pressed once again. Any ideas how to fix it?
    MENULOOP: 'MAIN CONFIG SCREEN
    IF UPBT=0 THEN
    MENUITEM=MENUITEM+1
    IF MENUITEM>4 THEN MENUITEM=1
    GOSUB CENTRAL
    pause 200 'debounce
    WHILE UPBT=0:WEND
    IF DNBT=0 THEN
    MENUITEM=MENUITEM-1
    IF MENUITEM<1 THEN MENUITEM=4
    GOSUB CENTRAL
    pause 200 'debounce
    WHILE DNBT=0:WEND
    if menuitem=1 and rbut=0 then
    pause 5
    while rbut=0: wend
    goto clockconfig
    GOTO MENULOOP
  1. Final Button Code
    By WarPony in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2008, 15:14
  2. Help with code, button
    By xobx in forum mel PIC BASIC Pro
    Last Post: - 15th July 2007, 18:52
  3. Entering the number from keypad...
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 27th April 2007, 10:02
  4. Code entering endless loop
    By Blackhawk in forum mel PIC BASIC
    Last Post: - 26th November 2006, 10:12
  5. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
