So most likely, PBP is messing something up.
Of course it does...
Me thinks it's far more likely that the particular controller that's on your display doesn't live up to the specifications in the datasheet. Quite common on cheap HD44780 compatible displays as well so I would no be surprised if this is the case. It could also be electrical, crosstalk, capacitive loading of the outputs due to long wires between PIC and display, RMW issues etc. Have you looked at the signals (with a scope) as they enter the display?
Again, the datasheet specifies 72us for all commands except clear. You're using 900us and executing a LOT of commands so it takes a LOT of time.
